#4873 | |
Drives: small
#4874 | |
Drives: small
Next time you want your car to go fast, have Gandhi drive it for you. Same logic, or lack there of. Sorry but you hit one of my car forum pet peeves.... Plus yours and others comments of areas of improvement are not mutually exclusive to my own. Mvoing the controller to the back w/ the pack fixes the cooling issue btw. If you want to settle for less, than that's a perfectly fine choice. When you look at development, one should consider all potential improvements, not just a few. Plus, I said this kit is fine for those that like it as is, I said specifically that Rob should consider offering something for those that want exactly what I mentioned. |
#4875 | |
Drives: DGM BRZ 6MT
If that doesn't work. Can we move the WOT bracket away from the gas petal and use still advantage of the DR at the track without worrying about the system overheating. @waterbison777 said that when he was going WOT with the system in safe mode, it was running noticeably richer. Would the OTS Stage 1 tune work well when the using the ESC system just for DR? Or does the DR make enough difference to a stock car where a Stage 1 tune wouldn't work well for it? I think I remember reading that Shiv's tune is based on engine load to determine when the ESC is activated (I might be wrong). Since the ESC may not be activated all the time during WOT, does this mean that a custom tune would be needed for either the push-to-pass or DR-only option? Just throwing out ideas on how to make it work at the track, even if only sometimes. Or even not using it, but saving the need to swap back to the stock intake tube during track days.
#4876 | |
Drives: small
Don't think I haven't thought about the Phantom hybridized with that rear mount snail... |
#4877 | |
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
And I don't want any more of my tiny trunk taken up - the sub eats up enough of it. LOL.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe 2006 Saab 9-3 2.0t 1997 Honda Accord Coupe 1995 Honda Prelude VTEC |
#4878 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
| The Following User Says Thank You to drewbot For This Useful Post: | DAEMANO (04-30-2014) |
#4879 | |
If so, then summertime = better in trunk and wintertime = better under hood. But someone can comment/clarify.
| The Following User Says Thank You to robwbright For This Useful Post: | DAEMANO (04-30-2014) |
#4880 | |
Drives: small
http://www.ebay.com/itm/like/251509650153?lpid=82 |
#4881 | |
#4882 | |
Time Traveller
I haven't dug much into how Shiv's ESC tune works off WOT vs. using an OTS Stg map so don't feel comfortable commenting on that. I've mostly been concerned with the effects of CA91 pump gas on both NA and ESC performance. I think the push to pass/super pursuit mode is being tested right now by another user + Rob. Don't remember whom. I also don't know if that is a hardware only test or if Shiv has provided custom software for SPM/Push to Pass. Software could definitely be in play there. |
#4883 |
Erected Member
Drives: frs
Kinda off topic on what you are talking about but... for the guys that already had the esc kit installed, what are the major supporting mods that you've done and did they help with trq and hp?
Also, would i benefit from a mfactory 4.67 final drive conversion. Thanks
#4884 | |
Drives: WR Blue BRZ, 240Z
Regarding the 4.67 rear gears, it depends on the type of performance you are after. If 0-60 and 1/4 times are your thing, then yes. But that mod comes at the expense of higher cruise rpm, wear and fuel consumption. It's not a big deal - at 70 mph you'd be turning 3,425 rpm vs 3,000 - but it is real.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#4885 | |
As everyone knows, 2nd gear in the MT maxes out at 58-59mph stock - requiring a second gear change to 3rd gear to get to 60mph and increasing the 0-60 time by (guessing) a couple tenths. I think I recall reading that tuning can be done relatively easily to raise the redline 100-200 rpm, thereby allowing 60 mph in 2nd gear. I don't know how much switching to 4.67 gears would increase the acceleration, but I'm guessing you wouldn't want to raise the redline enough to hit 60mph in 2nd gear using a 4.67 final drive. I suppose what I'm getting at is: If you can change the tune to hit 60mph in 2nd gear and thereby cut, say, 0.2 sec off your 0-60... but you can't do that with a 4.67 final drive, then... Is the difference you gain in acceleration with the 4.67 final drive going to be sufficient to offset the decreased fuel mileage and wear on the engine?
#4886 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
