Old 04-29-2014, 04:55 PM   #1135
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by phrosty View Post
Shiv has mentioned that transmission-sourced CELs are not currently scanned by OFT. I've ran into this myself. Maybe this is what you're seeing.
This is my thought as well. If you haver a CEL light and the OFT doesn't read any codes, the CEL is likely caused by something non-ECU related. If you have a 6AT, it's likely the TCU that is triggering a code for some reason.
Shiv@Openflash is offline   Reply With Quote
Old 04-29-2014, 05:02 PM   #1136
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
I have a manual, any way of clearing or reading the code?
"Bah Weep Granah Weep Nini Bong"
Old: 2013 Arengto FR-S
Current: 2015 Tacoma/2020 Sequoia Pro
Future: 2022 CWP Limited Est Delivery 06/22
euroshowoff is offline   Reply With Quote
Old 04-29-2014, 05:06 PM   #1137
Shiv@Openflash
Drives: 2013 FRS
The next step would be the take it in to the dealership for the CEL. They should take care of it pretty quickly given that your car is most certainly still under warranty
Old 04-29-2014, 05:51 PM   #1138
euroshowoff
Drives: 2015 Tacoma
Still under 10k lol
Should I flash back to the stock? I will almost certainly throw a code for my catless header before I get there.
Old 04-29-2014, 11:01 PM   #1139
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Is it common to get knock correction of about 1.7 degrees while on the highway cruising at 3 - 4 k? Most of the corrections pull ~.1 degrees but occasionally I will see .5 - 1.7 deg
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 04-29-2014, 11:47 PM   #1140
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
hmm found this just now
Q: When should I be concerned about detonation/knock? What are some things to try or items to
check?
A: This is probably the most difficult question to answer but in general, we consider corrections of ~-2.5
degrees to be “normal” and not of major concern. If DAM is persistently below 1 or 16 and/or corrections 4 | P a g e
greater than -2.5 degrees are repeatedly observed to the “Feedback Knock Correction” or “Fine Knock
Learning” monitors, this is good reason for further inspection.
FRS
Old 04-30-2014, 04:18 AM   #1141
Kodename47
Kodename47's Avatar
Drives: UK GT86
check?
-2.5!?! I dislike anything over -1.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-30-2014, 08:18 AM   #1142
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
I found that reading from COBB tuning for a WRX. Not sure if the parameters are different with that car
FRS
Old 04-30-2014, 01:46 PM   #1143
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Anyone know how to activate flat-foot shifting??
Readytoxplod is offline   Reply With Quote
Old 04-30-2014, 01:50 PM   #1144
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
You need to open the map in RomRaider or Tuner Pro and mofify the FFS Delta Table. It is 0 by default which means disabled. To activate it, you set the net to the difference between fuel cut and desired FFS RPM. This means if you have a Rev Limit of 7600RPM and you want FFS to be 4600RPM, you need to set the table to 3000.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Shiv@Openflash (04-30-2014)
Old 04-30-2014, 02:37 PM   #1145
mid_life_crisis
Drives: FR-S 10 #103 AT
@shiv@vishnu It's understood that you have a lot on your plate right now, what with the upcoming nuptials and trying to wrap up projects for business so you can have a real honeymoon. Having said that, I'm curious what you figure the chances are of the next set of OTS maps being done before your time off? Just curious, not trying to add pressure to your already busy schedule. If they are on the list for when you get back, that's fine, just wondering.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-30-2014, 02:43 PM   #1146
Shiv@Openflash
Drives: 2013 FRS
There is 0% that the new map release will be available prior to my nuptials this Monday. Wifey is tolerant but not that tolerant And seeing that the v1.60 isn't a "fix" to anything that is currently awry, I'd rather hold off and release it when it has plenty of test miles under its belt.
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
Blu-by-U (04-30-2014), FrsDuke (04-30-2014), neutron256 (04-30-2014), robwbright (04-30-2014), Sojhinn (04-30-2014), Turdinator (04-30-2014), wparsons (05-15-2014)
Old 04-30-2014, 03:29 PM   #1147
OnkelC
OnkelC's Avatar
Drives: 2017 Fiesta ST
Wedding 1.0 is a hopefully final and one-time upgrade, so better put all your efforts into this one!
I think everybody will understand if you take a few days off for this.
OnkelC is offline   Reply With Quote
The Following 2 Users Say Thank You to OnkelC For This Useful Post:
Shiv@Openflash (04-30-2014), wparsons (05-15-2014)
Old 04-30-2014, 03:39 PM   #1148
mid_life_crisis
I was hoping for "they're almost done, should be posted tomorrow" or something like that.
Oh well, best wishes that the day is everything she's dreaming of.
As a buddy of mine pointed out years ago, "it's her day: you're only there because she'd look foolish standing up there with just her girlfriends. The sooner you accept that, the better off you'll be."
The Following User Says Thank You to mid_life_crisis For This Useful Post:
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
