Old 04-29-2014, 09:25 PM   #15
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
I believe 250whp n/a can be achieved its just more costly than going forced induction
but if you go higher than stock compression you definitely need supporting mods and probably e85 otherwise things start to break ><
Panda Mao is offline   Reply With Quote
Old 04-29-2014, 09:39 PM   #16
Turdinator
Señor Member
Turdinator's Avatar
I think 250whp is doable. There are already some post suggesting that a little head work opens things up nicely for higher revs, although that has been on FI applications so far. I wouldn't bother with power blocks tho as they will move the torque lower in the rev band which isn't what you want here.
I think at this point in the FA20s development the cams and intake manifold will be the most expensive and hardest to track down and they won't be off the shelf items.
I will be watching where this goes
1974 TA22 Celica
2013 86 GT
Old 04-29-2014, 10:45 PM   #17
Panda Mao
Panda Mao's Avatar
considering the fa20 is a brand new motor built from the bottom up and its only debuted for at least 2-3 years so I wouldn't be surprised there is still so much r&d that needs to be done on these motors and the potential vs durability is still up in smoke
Old 05-01-2014, 01:08 AM   #18
whataboutbob
AutoX-10/10ths every run
Throttle modulation minimizes throttle oversteer @EN2_Squirrel
And the SC isn't as laggy as a turbo would be.
Build thread:Here
Old 05-01-2014, 01:20 AM   #19
EN2_Squirrel
EN2_Squirrel's Avatar
Originally Posted by Jason@DSG View Post
E85 or race fuel will be possible but it requires a full engine build especially if you go up in compression, and major cooling and a REALLY good tuner
I am going e85 and i am looking into bill knoes (the guy who did ken block's subaru) to get the tune
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Old 05-01-2014, 01:21 AM   #20
EN2_Squirrel
Says the man on r-comps. But yoy are right. Our cars are very different. That was my problem
The Following User Says Thank You to EN2_Squirrel For This Useful Post:
whataboutbob (05-05-2014)
Old 05-01-2014, 01:23 AM   #21
EN2_Squirrel
Very true about the r&d. But someone has to do it.
Old 05-01-2014, 03:59 AM   #22
1086
1086's Avatar
Drives: UM86 - 6MT
12.5:1 isn't high enough for you?! duh fuq
1086 is offline   Reply With Quote
Old 05-01-2014, 03:18 PM   #23
xwd
I've built a competitive turbo car for SM before, albeit 6-7 years ago. I'd like to think 250WHP could get it done but I'm not sure the FA20 can get there, not with enough torque to be competitive. Mike Simanyi's 95 M3 is a little under 300WHP in a 2600lb car, but it's a 3.0L inline 6. It makes way more torque than you'll ever see out of an FA20.
I think a 2L NA FA20 could get down to less than 2400lbs, but I'm still not sure it will have the oomph to compete.
If you have an FR-S doing a swap with one of the Toyota V6s might be a better idea than trying to wring out the FA20...
I'm actually contemplating trying the car out in CSP, I think you could hit 210-220WHP on E85 nowadays with the power blocks, right intake, etc. I don't think the car would be competitive against the current Miatas but it would still be a lot of fun, much cheaper than SM, and might get the car moved to DSP where it could be competitive.
The Following 2 Users Say Thank You to xwd For This Useful Post:
EN2_Squirrel (05-05-2014), SirBrass (05-01-2014)
Old 05-01-2014, 03:29 PM   #24
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
if you have seen how the engine is clearanced, i dont think your left much room for bigger pistons. theyre already past the top of the deck at full stroke and the combustion area is small
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following User Says Thank You to Grip Ronin For This Useful Post:
EN2_Squirrel (05-01-2014)
Low Compression Pistons vs New Shortblock SilverTipp Forced Induction 11 04-11-2014 06:45 PM
Why aren't some concerned about putting a turbo on a high compression motor? dave77 Forced Induction 50 01-13-2014 03:22 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 06:46 PM
High compression engine fuel requirements Ben_G Engine, Exhaust, Transmission 3 01-16-2013 12:44 PM
queston about low compression pistons on stock ECU clayrush Engine, Exhaust, Transmission 1 12-04-2012 12:11 AM
