| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2015 Series.Blue
Yep, you can buy the tools to recalibrate it yourself, or find someone that does it (sears used to do it)
#16 |
Drives: 2013 asphalt scion FRS
I use the snapon tech wrench. its electronic 1/2" drive. works perfectly for me and I got it for 80 bucks brand new...
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#17 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Anyone using those new electric Craftsman ones? I read that those little black square Powerbuilt(HF?) electric torque wrench adapters are pretty accurate/good(even for using as a tool to calibrate your mechanical wrenches)...so I bet the electric craftsman might be even better..? It sure looks decent quality in the packaging.
Do electric wrenches stay in calibration longer, than the standard twist handle mechanical ones? I am curious about the electric wrenches ...as I've read they are much more accurate. But, I'm unsure of their reliability and durability. |
#18 | |
Drives: 2014 FR-S 6MT Monogram Series
#19 | |
did you ever drop it? ive had mine for 4 years now, and never recalibrated.
#20 | |
fyi, just noticed HF has a coupon for torque wrenches right now. 12 dollars each for any mechanical one. limit up to 8. could pick up a whole set for cheaper than you can buy one from other places. coupon code is: 39674432
#21 | |
80% is a very good number for the max accuracy. I have beam style. I've broken more than one bolt due to a clicker failing. |
#22 |
Drives: Whiteout Scion FR-S
This one:
http://www.tooldiscounter.com/ItemDi...up=PREC3FR250F Split beam mechanism does not need to be "turned down" during storage, click type feedback when torque is reached makes it quick. This also makes for a very durable design that will keep working accurately for a long time. Maybe more than you wanted to spend, but worth it in the long run IMHO.
My cars always dress formally. They all wear black tires.
#23 |
#24 | |
#25 |
Drives: t
craftsman was on sale recently.. 50% off.. works good and if you take care of it , they will stay true for a long time..
#26 | |
#27 | |
http://www.tooldiscounter.com/ItemDi...up=PREC2FR100F I use the larger one for wheel lug nuts, and the smaller one for most of the other fasteners.
#28 |
CDI instruments can be had on eBay NIB for reasonable money considering their quality. They are owned by Snap-On and manufacture the torque arms for the beam, click and digital Snap On torque wrenches. The only difference aside from the Snap On ratcheting head design is the cost. I bought mine brand new with warranty for less then half the cost of the equivalent Snap On which would have no accuracy advantage being essentially the same tool.
| Recomend torque wrench | jflogerzi | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 06-08-2017 07:38 AM |
| Socket set and torque wrench | Ty89m | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 07-29-2013 01:46 AM |
| Torque Wrench options | FRiSson | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 17 | 03-14-2013 03:29 PM |
| Torque wrench... Vendors welcome | Freeman | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-23-2013 06:30 AM |
