| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 BRZ Limited, 2013 Focus ST
If so, how do I turn it on? I can see at certain angles where it would be, but it doesn't light up. Sorry if this topic has been covered; I didn't see any other threads about it when I did a search, and I know how sensitive folks around here can be about using the search function, lol.
#2 |
Drives: '13 BRZ 6MT WRB
Check out this thread: http://www.ft86club.com/forums/showthread.php?t=8628
#4 |
Drives: 2013 Subaru BRZ
I turned it on for about 3 days and then turned it off. It will only tell you what gear you are in when the clutch is all the way out (guess the sensor is in the pedal?) and not when the shifter is in the gate.. and a little green arrow for when you should shift for fuel economy. Found both annoying.
#5 |
ProCrastinationConsultant
i keep both turned on.. i would prefer it to show the gear all the time, but it doesn't..
and fyi-- there's a delay anyways-- i tried shifting without the clutch a couple times and it still took as long as using the clutch to display the gear being used, so disabling the clutch switch wouldn't 'fix' anything.
#6 |
Drives: DGM BRZ
[ame="https://www.youtube.com/watch?v=EL50fh9-_9A"]2013 BRZ FRS: How To Set Shift Light and More HD - YouTube[/ame]
#7 |
Drives: 2014 BRZ SWP LTD
Funny, I just turned mine on today. Took me a while to figure out, with very little reward
#8 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I had mine on for about a day or so and then turned it back off.
I think the gear indicator works on a speed to RPM algorithm in the computer, which is why its only on when the car is fully in gear with clutch out. Kind of like the Racingmeter thing in the Torque app for Android. |
#9 | |
In the end, I'm sure he had no idea
#10 |
You can do that? How?
#11 |
Drives: none
http://www.ft86club.com/forums/showthread.php?t=16518
Couple different methods. But I used the first one the OP mentioned |
| The Following User Says Thank You to dbrandt01 For This Useful Post: | Bobblehead (04-27-2014) |
| How to set the Shift Light & Gear Indicator Display Settings | EsoBOFH | DIY (Do-It-Yourself) Guides | 76 | 04-21-2020 08:42 PM |
| Reverse light and red triangle reflector housing part number? | dem00n | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-06-2013 02:12 PM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
| Door Light - After the part number for this | DriftEightSix | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-07-2012 03:49 AM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
