Old 04-26-2014, 06:33 PM   #1
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Question Is there a gear number dash light on BRZ?
If so, how do I turn it on? I can see at certain angles where it would be, but it doesn't light up. Sorry if this topic has been covered; I didn't see any other threads about it when I did a search, and I know how sensitive folks around here can be about using the search function, lol.
Thrustin is offline   Reply With Quote
Old 04-26-2014, 06:37 PM   #2
slockin
slockin's Avatar
Drives: '13 BRZ 6MT WRB
Check out this thread: http://www.ft86club.com/forums/showthread.php?t=8628
slockin is offline   Reply With Quote
Old 04-26-2014, 07:18 PM   #3
t.chk
Drives: Subaru BRZ Limited
It is the same process on the BRZ as it is on the FRS...we just didnt make a video
t.chk is offline   Reply With Quote
Old 04-26-2014, 09:22 PM   #4
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
I turned it on for about 3 days and then turned it off. It will only tell you what gear you are in when the clutch is all the way out (guess the sensor is in the pedal?) and not when the shifter is in the gate.. and a little green arrow for when you should shift for fuel economy. Found both annoying.
BRZBlack is offline   Reply With Quote
Old 04-27-2014, 12:57 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
i keep both turned on.. i would prefer it to show the gear all the time, but it doesn't..
and fyi-- there's a delay anyways-- i tried shifting without the clutch a couple times and it still took as long as using the clutch to display the gear being used, so disabling the clutch switch wouldn't 'fix' anything.
Old 04-27-2014, 12:58 AM   #6
Odd
Odd's Avatar
Drives: DGM BRZ
[ame="https://www.youtube.com/watch?v=EL50fh9-_9A"]2013 BRZ FRS: How To Set Shift Light and More HD - YouTube[/ame]
Odd is offline   Reply With Quote
Old 04-27-2014, 01:17 AM   #7
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Funny, I just turned mine on today. Took me a while to figure out, with very little reward
Old 04-27-2014, 02:05 AM   #8
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I had mine on for about a day or so and then turned it back off.
I think the gear indicator works on a speed to RPM algorithm in the computer, which is why its only on when the car is fully in gear with clutch out. Kind of like the Racingmeter thing in the Torque app for Android.
Bobblehead is offline   Reply With Quote
Old 04-27-2014, 02:30 AM   #9
kberkel
kberkel's Avatar
I love it. I wondered why my previous owner hadn't turned it on, along with the rev light/beep.. but then again, the alarm wasn't on.. same with one touch unlocking both doors.
In the end, I'm sure he had no idea
kberkel is offline   Reply With Quote
Old 04-27-2014, 12:40 PM   #10
Bobblehead
Bobblehead's Avatar
You can do that? How?
Old 04-27-2014, 01:49 PM   #11
dbrandt01
Drives: none
http://www.ft86club.com/forums/showthread.php?t=16518
Couple different methods. But I used the first one the OP mentioned
dbrandt01 is offline   Reply With Quote
The Following User Says Thank You to dbrandt01 For This Useful Post:
Bobblehead (04-27-2014)
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 09:42 PM
Reverse light and red triangle reflector housing part number? dem00n Cosmetic Modification (Interior/Exterior/Lighting) 0 07-06-2013 03:12 PM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
Door Light - After the part number for this DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 0 07-07-2012 04:49 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
