Old 04-24-2014, 05:47 PM   #29
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by becauseracecar1 View Post
Do you have any pics of the j hooks installed? I'm having a hard time with them. Thanks!!
I'll see what I can do!
Will have to be later tonight!
daiheadjai is offline   Reply With Quote
Old 04-24-2014, 06:12 PM   #30
becauseracecar1
becauseracecar1's Avatar
Drives:
Thank you!!
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
Old 04-24-2014, 11:42 PM   #31
daiheadjai
daiheadjai's Avatar
Here's what mine looks like.
Basically, each clip uses 2 screws:
Image 1 & 2:
The first screw holds the clip on your bumper (you can use a screwdriver to drive it in, but be careful of the placement), and passes the big hole through to the small hole (which is the side that will actually hold the clip to the bumper)
In the first 2 pics, you can see the back of the clip (which faces the rear of the car), where it is screwed into the soft black plastic of the rear bumper.
Image 3
The second screw is put in after you pull the diffuser edge over the long end of the clip (the diffuser tip has a little ridge that should slide right over the bracket/clip)
Image 4 & 5
These 2 pics give you and idea of the locations of the 2 screws
It should look something like this (pardon the crappy MS paint):
The Following 2 Users Say Thank You to daiheadjai For This Useful Post:
BAOVAN (01-04-2017), becauseracecar1 (04-25-2014)
Old 04-25-2014, 01:28 AM   #32
becauseracecar1
Drives:
Image 1 & 2:
Attachment 76134
Attachment 76135
Image 3
Attachment 76136
Image 4 & 5
Attachment 76137
Attachment 76138
Attachment 76142
Thank you so much!! I really appreciate it!! Got it done thanks to you!
Old 04-25-2014, 01:45 AM   #33
daiheadjai
daiheadjai's Avatar
Beautifully done!
diffuser, diy
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 06:59 PM
TRD LIP KIT ON EBAY!!! chopstickz Cosmetic Modification (Interior/Exterior/Lighting) 17 02-03-2014 05:04 PM
Ebay JDM insanity njccmd2002 Scion FR-S / Toyota 86 GT86 General Forum 43 05-08-2013 10:17 PM
BRZ on eBay nzer AUSTRALIA 7 10-05-2012 04:24 AM
86 USB drive on ebay bambbrose Off-Topic Lounge [WARNING: NO POLITICS] 7 01-20-2012 04:46 PM
