| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: 2003 S2000, 2008 Fit
#30 |
Drives:
Thank you!! Sent from my iPhone using Tapatalk
2014 Ultramarine Scion FR-S facebook.com/86motorsports |
#31 |
Here's what mine looks like.
Basically, each clip uses 2 screws: Image 1 & 2: The first screw holds the clip on your bumper (you can use a screwdriver to drive it in, but be careful of the placement), and passes the big hole through to the small hole (which is the side that will actually hold the clip to the bumper) In the first 2 pics, you can see the back of the clip (which faces the rear of the car), where it is screwed into the soft black plastic of the rear bumper. Image 3 The second screw is put in after you pull the diffuser edge over the long end of the clip (the diffuser tip has a little ridge that should slide right over the bracket/clip) Image 4 & 5 These 2 pics give you and idea of the locations of the 2 screws It should look something like this (pardon the crappy MS paint): |
| The Following 2 Users Say Thank You to daiheadjai For This Useful Post: | BAOVAN (01-04-2017), becauseracecar1 (04-25-2014) |
#32 | |
Drives:
Thank you so much!! I really appreciate it!! Got it done thanks to you! Sent from my iPhone using Tapatalk
#33 |
Beautifully done!
| Tags |
| diffuser, diy |
| FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel | Pekingduck | Interior Parts (Incl. Lighting) | 7 | 02-12-2014 06:59 PM |
| TRD LIP KIT ON EBAY!!! | chopstickz | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 02-03-2014 05:04 PM |
| Ebay JDM insanity | njccmd2002 | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 05-08-2013 10:17 PM |
| BRZ on eBay | nzer | AUSTRALIA | 7 | 10-05-2012 04:24 AM |
| 86 USB drive on ebay | bambbrose | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 01-20-2012 04:46 PM |
