Old 04-22-2014, 03:39 AM   #1
Anorexic 86
Trim the Fat & add Boost
Anorexic 86's Avatar
Drives: sometimes I fly
Smile >>> 3 New Lightweight Flow Form Wheels <<< 720 FORM Compilation
Update: New pictures on every page!
Just found these...
720 FORM
Made by DAI
All available in 5x100 bolt pattern.
GTF1
17x8 +35 15.5 lbs.
17x9 +35 16.8 lbs.
GTF2
18x9 +35 18.5 lbs.
18x10 +38 19.5 lbs.
GTF3
17x7.5 +42 16.0 lbs. (weight unconfirmed)
18x8.0 +42 18.6 lbs.
GTF1
17x9 +35 16.8 lbs.
GTF2
18x9 +35 18.5 lbs.
Anorexic 86 is offline   Reply With Quote
Old 04-22-2014, 03:39 AM   #2
Anorexic 86
[ame="http://vimeo.com/63204097"]Wide Open Drift Team 2013 Drift Car on Vimeo[/ame]
Old 04-22-2014, 12:35 PM   #3
8R6
8R6's Avatar
Drives: FRS
why does it have two valve stem openings? lol
8R6 is offline   Reply With Quote
Old 04-22-2014, 12:41 PM   #4
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
probably the same reason why Koseis have 2 valves.
one standard and one nitrogen
Old 04-22-2014, 01:05 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Some race teams run dual valves for speed and something else..but basically it helps crews do their jobs faster
Old 04-22-2014, 02:57 PM   #6
DAEMANO
Time Traveller
Great looking addition. Love the tech, price, size, offsets and weights. Nice find!
http://www.daialloys.com/catalogues.php, the calendars aren't bad either http://www.daialloys.com/models.php (NSFW)
Old 04-22-2014, 04:42 PM   #7
jdmblood
jdmblood's Avatar
Drives: white subaru brz
gtf2s look pretty similar to enkei gtc01rr. no eighteen inch on the gtf1s?
jdmblood is offline   Reply With Quote
Old 04-22-2014, 07:23 PM   #8
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
SO these guys are creating a low pressure zone in the cast to elongate the alloy without adding air bubbles? I'm not understanding the science behind their new process. Wouldn't this cause the wheel to become more brittle under impact?
OjiGeorge is offline   Reply With Quote
Old 04-22-2014, 08:01 PM   #9
MR2Chuck
Elder
[Some race teams run dual valves for speed and something else..but basically it helps crews do their jobs faster ]
One valve: air hose
One valve: air pressure gauge
MR2Chuck is offline   Reply With Quote
Old 04-22-2014, 08:42 PM   #10
8R6
8R6's Avatar
Drives: FRS
One valve: air hose
ohhh... i did not know that!
Old 04-22-2014, 10:37 PM   #11
jdmblood
jdmblood's Avatar
these wheels are gorgeous though
Old 04-22-2014, 10:54 PM   #12
stueck9356
Drives: 2015 VW GTI SE
2 valve stems also helps in properly purging all air from the tires when filling with nitrogen I've herd.. put nitrogen in on top, and open up the bottom to release the air.
stueck9356 is offline   Reply With Quote
Old 04-22-2014, 10:58 PM   #13
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
Air is 70% Nitrogen, so you're effectively replacing air with air!
If anything, I could see it used to standardize air pressure across tires on the same side of the vehicle. Connect an air hose between a nipple on the front and rear, then use the other to add or remove air. Still, gimmicky.
sdemo is offline   Reply With Quote
Old 04-23-2014, 03:55 PM   #14
stueck9356
Either way if they make the GTF1 in a Gunmetal color sign me up for a set of 17x9! Hope these fit.
Sent from my Nook HD using Tapatalk
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
FT86 Canada HRE Flow+Form - SimplyTire 2014 Zook@SimplyTire Canada Classifieds 4 06-07-2014 11:05 AM
Your Top Three Form of Automotive Racing, From Two to Ten Wheels. LBC Por Siempre Other Vehicles & General Automotive Discussions 14 02-24-2014 11:09 AM
New SSR Flow Formed wheels available for FRS - Not bad on price! ModBargains.com Wheels and Tires 21 01-13-2014 11:27 AM
Lightweight wheels or wide wheels Moetivegt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-06-2013 10:57 PM
