Old 04-22-2014, 12:41 PM   #1
brn12345
brn12345's Avatar
91 and 93 octane maps - OFT related
Some time back I thought I read that shiv@vishnu had mentioned that there will be 91 and 93 octane maps. The latest 1.59 files only have one file and nothing to show that there are different 91 and 93 maps.
Shiv would be great if you can clarify.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 04-22-2014, 12:50 PM   #2
Malt
Drives: 2015 WRX
Shiv hasn't released the 93 octane tunes yet
Malt is offline   Reply With Quote
Old 04-22-2014, 01:10 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Just to clarify, our tunes are mapped for 91-93oct. Just like the factory tune. What this means that it's more likely that us 91oct folks will see knock correction from time to time. While 93oct folks will be knock correction free for the most part. At least that is how it is in theory. In the upcoming release of 91 and 93 oct maps (with v1.60 OTS map release), what you will be presented with are two maps. One slightly less aggressive and one slightly more aggressive. Don't expect there to be a substantial power difference between them. Maybe 2-3whp up top
Shiv@Openflash is offline   Reply With Quote
Old 04-22-2014, 01:43 PM   #4
OnkelC
OnkelC's Avatar
Drives: 2017 Fiesta ST
sounds fine for me. RELEEEEAAAAAASSSSEEE NOOOOOOOOOOOOWWW! PLEEEEAAASEEE
OnkelC is offline   Reply With Quote
Old 04-22-2014, 02:36 PM   #5
mid_life_crisis
Drives: FR-S 10 #103 AT
Bummer. So the guy whose virtual dyno shows a gain of 11 horsepower from 2 degrees more timing added to your base map is not getting a good reflection of reality from his tests then? I should have known that graph was too good to be accurate.
http://www.ft86club.com/forums/showp...&postcount=965
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-22-2014, 02:53 PM   #6
Shiv@Openflash
Drives: 2013 FRS
Nope sorry, I do not believe that is accurate. I think much of that is from natural run to run variances from using a road dyno. But things have surprised me in the past so I don't like to say anything definitively.
Old 04-22-2014, 03:04 PM   #7
brn12345
brn12345's Avatar
Looking forward to the new releases. Keep up the great work!!!
Question though. If not knock limited (i.e using higher octane fuel) would our cars make more power with an increase in timing?
Old 04-22-2014, 03:05 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Yes indeed. That is where much of the E85 gains come from
Old 04-22-2014, 04:02 PM   #9
ML
ML's Avatar
Drives: 13 White MT FR-S
Wouldn't spraying methanol help increase timing or am I confused?
Old 04-22-2014, 04:07 PM   #10
wparsons
wparsons's Avatar
Just adding a methanol spray won't automatically increase timing, but constantly spraying methanol would let you increase timing in the tune. Unless you're going to have the map switched (or run something like a flex fuel kit), you can't do that or you'll get a bunch of knock when not spraying the methanol.
flickr
ML (04-22-2014)
shiv_awesome
Seriously though (2014 Frs related) Badasi12b Scion FR-S / Toyota 86 GT86 General Forum 14 10-09-2013 01:12 PM
A/C pulley or something related :) SmsAlSuwaidi Issues | Warranty | Recalls / TSB 2 09-23-2013 09:20 PM
Car-related legos? Gost Other Vehicles & General Automotive Discussions 0 03-18-2013 11:32 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Kind of AX related... Sam Strano Tracking / Autocross / HPDE / Drifting 9 02-07-2013 10:00 PM
