#15 |
I have the Rydeen Duo... Need to get a little creative with the mounting because it's fixed at a pretty low angle.
#16 |
Drives: shiny side up.
http://www.rydeenmobile.com/downloads/DUO_Cam.pdf
according to the above spec the Rydeen Duo is a 12v not a 6v unit... is there an earlier Duo that powered off the HU? |
#17 | |
Drives: WRB BRZ Premium
#18 | |
Drives: Subaru BRZ 2014 Limited WRB
Even though the specs say 12v, the HU 6v power supply is enough. I have confirmed this in my installation, as have others here, but here is a link from the guy that knows these things better than the rest of us: http://www.ft86club.com/forums/showp...&postcount=111 -Z |
#19 |
Drives: 2013 BRZ Limited WRB
#20 | |
You might find workarounds for these issues, or be willing to live with them for the price. -Z Last edited by zinzan; 11-10-2014 at 04:01 PM. |
#21 | ||
Sent from my SGH-I337M using Tapatalk
#22 |
Drives: 2014 Subaru BRZ
Add Roadshop HD1401 to the list, but. . .
Roadshop HD1401 works. HOWEVER:
There's a camera cable and a body harness cable. You have to solder the red wire of the camera cable to the red wire of the body harness cable, and then solder the cable to the connector at the head. The Roadshop also needs to be grounded in the back of the car (the ground is not carried to the head) I grounded it to the cover of the speaker amplifier in the trunk. The ground on the harness connector is really too short. An extra inch and a half makes all the difference. Or so they say. I found the best place for the extra cable is in the door sill. I found a really easy way to check if the camera works with a 6V head. Take a mini LED flashlight, open it and take the battery pack out. It should be three AAA batteries delivering 4.5 volts. The pack has a plus and minus terminal. Mine powered right up with 4.5 Volts. I like the look, the performance, and the camera looks well made. It's good in low level light. It also needs a larger cutout in the back trim piece. My whole install was less than $100 and I got a great camera. If I did it again, I'd probably wait for a good deal on a Rydeen. Lastly, you can test the camera without putting the car in reverse, which is kind of nice if you have the head unit resting on the shifter. Press Map --> Then press the three buttons together, then Failure Diagnostics --> System Check. If it comes up OK you're good to go. I can't say this works when a relay is in place, but it worked for me. Happy modding, C |
#23 |
Drives: Subaru BRZ, Chevrolet Camaro
BRZ Backup Cameras a List
I about such yet did not hear
#24 |
Drives: 2015 CWP BRZ Limited
Has anyone ever tried mounting the Rydeen Duo on the license plate? I like the option of not drilling but the Beat Sonic requires 12v and I'd prefer to just get power through the HU's 6v.
#25 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I have the OEM Subaru reverse camera... Then I had to buy a OEM BRZ specific shim to add to it for the angle adjustment.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#26 |
Drives: '14 BRZ CBS
I'm interested in the shim, mounted a camera today and don't get enough height to see infinity
'14 BRZ CBS
>>Pretty Stock |
| The Following User Says Thank You to a_dee For This Useful Post: | meWant (07-06-2015) |
#27 |
Drives: '14 BRZ CBS
Seems like I'm going to have to get a rubber block and cut it in a wedge shape to make the shim, not really getting much other options here..
'14 BRZ CBS
>>Pretty Stock |
#28 |
Drives: 2015 Subaru BRZ
Installing a rear backup camera in a Subaru BRZ w/ a navigation unit.
I found the easiest way to install a rear backup camera in a Subaru BRZ cheap and w/o having to drill any holes is:
1) Buy the following camera (you do not need one with lights for nighttime): http://www.happyshoppinglife.com/car...on-p-2307.html 2) Buy the following wiring harness: http://www.autoharnesshouse.com/19867.html 3) Learn how to remove the radio/navigation unit: [ame="https://www.youtube.com/watch?v=kAWRRJcxWkI"]Subaru BRZ Stereo Removal - YouTube[/ame] 4) Remove the factory license plate light cover. 5) Install the new license plate light cover w/ the camera. 6) Remove the radio/navigation unit and remove the 10 and 16 pin connectors. Plug in the new harness 10 and 16 pin connectors in to the back of the unit. Plug the original 10 pin connector into the new harness. Note: the original 16 pin connector is no longer needed and can just rest inside the cavity. 7) Plug the camera RCA jack in to the harness and connect the red wire from the video cable to the 12v connector on the harness. 8) Run the cable to the rear of the car and connect the video RCA cable to the camera and the red 12v wire to the camera. Connect the ground wire to the nearest ground. (You can always run the cable through the center of the car first to test.) 9) Turn the car on and put the car in reverse, you should see the rearview camera image on the screen. 10) Adjust the grid lines on the navigation unit: http://ae64.com/Rear-camera-install-16p-FT.htm Total cost was under $50.00 and 30 to 60 minutes of your time. Good luck! Last edited by CBrown_BRZ; 09-18-2015 at 11:59 AM. |
| Kenwood CMOS-210 Backup Camera Install | TSY | Electronics | Audio | NAV | Infotainment | 34 | 12-10-2014 02:18 PM |
| one more car list... | Axel | Off-Topic Lounge [WARNING: NO POLITICS] | 20 | 12-18-2013 07:17 AM |
| Interior wish list.... | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 07-18-2012 08:57 PM |
| $500 Deposit = First on List | IntenseDVDA | BRZ First-Gen (2012+) — General Topics | 373 | 02-21-2012 05:44 PM |
| Keep your eyes/cameras open in SoCal? | Buggy51 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-10-2011 11:21 PM |
