#57 | |
#58 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#59 | |
#61 |
Scrape Master
Drives: Goal: Oldest FRS State Side
here is mine on CCW classics
#62 |
2S Crew
Drives: a 2013 FR-S
I may a little down the road I kept fighting myself with buying adapters though ended up ordering ccw's
Man I hope I don't regret getting 17x8s and 17x9s because I do like 16s we'll see when I get mine mounted ahah
#63 |
Drives: GT86
Autec Wizard now painted silver
| The Following 3 Users Say Thank You to Trettiosjuan For This Useful Post: |
#64 | |
Just the tip
CSG David or other CSG, could you rate them or something in order of best performance based on my above use? I'm trying to get someone to help me lean one direction or another.
#65 |
Drives: SOLD...
Just tossing this out there.. but whats the narrowest rim that will fit and is available in 16" (thinking for winter duty next season) anything in 6" or 6.5"?
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
#66 |
Just the tip
4 spare tires will fit and they are tiny.
#67 | |
If you can, run a 17x8 +42 TWS T66-F with a 225/45/17 or a 17x9 +35 Wedsport TC105N with 245/40/17 tires. Both setups are fine and fairly dependent on application and desires. Tire selection on 17s is much greater. Everybody has preference, but I recommend RE11A for DD cars and RS3s for track setup. NT01, RC1, or RA1 are great tires if you like running with R-comps. With a grippier tire, you don't need to run as wide of a tire, however, having a fat sidewall also means slightly less response. |
| The Following 3 Users Say Thank You to CSG David For This Useful Post: |
#68 |
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
here is mine
still don't know if i like that bigger sidewall, last year i was on 18 inch wheels... i really preffer the 16' look, but, can't say if it will give a better handling or not... |
| The Following 2 Users Say Thank You to Walla Walla For This Useful Post: | dori. (05-09-2014), GuerillaRacing (04-23-2014) |
#69 |
Drives: Scion FR-S
Looking good. I dig the large sidewall look so far on our FR-S also, as well as the old school vibes.
| The Following User Says Thank You to GuerillaRacing For This Useful Post: | Walla Walla (04-23-2014) |
#70 |
Drives: Subaru BRZ Limited, Red
I bought 205/55 -16 Michelin Alpins for winter in the Northeast mounted on 16 X 6.5 inch Rials from Tire Rack.
The rolling circumference is less than 20mm larger than the original equipment tires which yields a negligible difference in gearing. Used the tires through two winters with great success. The slightly narrower footprint of the 16's yields slightly better tire load and traction. There's probably some gains in traction to be made by mounting wider rubber on larger wheels. The obvious trade-off is in tire/wheel weight and rotational mass under acceleration. I'm planning on replacing the OEM tires with the stock size 17's and upgrading the rubber compound over the low rolling resistance OEM's. Probably see a small decrease in fuel economy then. |
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 05:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 07:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-28-2012 12:20 AM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 09:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 12:17 PM |
