Old 04-19-2014, 01:08 AM   #1
jc1993
Drives: 2013 all stock frs
3inches or 2.5inches???;)
Hey guys i just want to know which is better in a exhaust setup. this of course would be on a n/a build.. when i mean better i mean it as in hp/tq gains. im planning on getting op fp and a catback all the same pipeing size. would this be a good idea? should i mix sizes on pipeing and would it have any benefit? ill appreciate the help thanks!
jc1993 is offline   Reply With Quote
Old 04-19-2014, 01:51 AM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
From what I have read before, there isn't much gain between 2.5 and 3inches for exhaust on N/A (someone check for me on this). The most gain you would get for sure is noise.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
jc1993 (04-19-2014)
Old 04-19-2014, 02:14 AM   #3
Kostamojen
No need for 3" unless you are going FI
Old 04-19-2014, 02:26 AM   #4
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
well according to my ruler its about 9 inches, however I am italian.
Maverick22 is offline   Reply With Quote
The Following User Says Thank You to Maverick22 For This Useful Post:
jc1993 (04-19-2014)
Old 04-19-2014, 02:45 AM   #5
wootwoot
Drives: FRS
You mean 9cm?You are Italian....
The Following User Says Thank You to wootwoot For This Useful Post:
Gunman (04-19-2014)
Old 04-19-2014, 11:13 AM   #6
transition
Not necessarily true. http://blog.perrinperformance.com/3-...ults-and-tune/
transition is offline   Reply With Quote
Old 04-19-2014, 11:44 AM   #7
zooki
Drives: waiting on a 2021...
Originally Posted by transition View Post
Any independent dyno tests I wonder? Manufacturer's claims are always suspect, at least to me.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
Shagaliscious (04-19-2014)
Old 04-19-2014, 11:47 AM   #8
Malt
Drives: 2015 WRX
I have the perrin 3" exhaust and I love perrin products but you really need to take dyno charts published by companies for what they are, a tool to help them sell a product. Its highly unlikely a 3" exhaust makes 8 more whp than a 2.5" exhaust on a NA engine and independent testers confirm that.
To the OP: stick with a 2.5" exhaust as the increases in volume and rasp (even on the resonated systems) on the 3" exhausts is to excessive IMO.
Malt is offline   Reply With Quote
Old 04-19-2014, 11:50 AM   #9
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Do you have an unbiased, third party dyno results..bigger is not always better ~3-5 whp or wtq difference may occur between pulls, 3" exhaust for NA cars (even for many FI is pointless)
Most of the time 3" becomes necessary at around 400whp levels and I highly doubt third party dyno results show otherwise
This has been debated for years and some people claim too large of an exhaust (for SC not for a turbo application of course) even hurts the low end torque.
Also some superchargers such as Rotrex kits -in general- makes a lot more power up top and lacks some low end power -as opposed to positive displacement SC s- I always thought it would be more beneficial to keep the low end TQ in expense to lose some top end (after 7200 rpm !!) and of course if it makes any difference
glamcem is offline   Reply With Quote
Old 04-19-2014, 01:44 PM   #10
Kostamojen
IF the header collector was 3" and a 3" over pipe and front pipe were included... then maybe I would agree.
But for just a catback or an exhaust that still has a bunch of restrictions, then no, just stick with 2.5".
I'm also guessing folks with the 3" have more scraping issues with the pipe goiing under the rear subframe..
Old 04-19-2014, 01:50 PM   #11
transition
No, there is no scraping issues with the 3" catback. I had rubbing issues with my JDL overpipe though which is 2.5" - doesn't fit great.
Old 04-19-2014, 01:51 PM   #12
transition
I have no independent tests although I trust Perrin is one of the more reputable shops. I understand that most manufacturers claims are usually optimistic though.
Old 04-19-2014, 01:55 PM   #13
I vote for the 2.5" pipe for a NA, FR-S engine.
Why? Because that's what I bought ..... so, it must be .... "right" ....
jc1993 (04-19-2014), Venator (04-21-2014)
Old 04-19-2014, 07:45 PM   #14
jc1993
that's what i hear from guys with fi :/
