#29 |
Drives: '13 BRZ Ltd WRB
Not to get too far on-topic, but...
I haven't really noticed it doing this in my BRZ, but it's not something I do often. However...a few years ago I had a WRX and got massively rear-ended. After that, I had a clunk whenever pulling up the hand brake while not completely stopped. It was a WRX so, no, I never did this to slide. More like rolling down the driveway a couple more inches for whatever reason and using that instead of the pedal. Maybe...just maayyyybe I might have used it to slow down just a tad without lighting up the brake lights. Once or twice. Maybe. I took it back to the shop that did the repair and they said everything was working fine but since it doesn't happen when stopped, there was no issue. Still bugged me knowing that something changed.
#30 | |
#31 |
Drives: 2013 FR-S, hot lava
what are the odds this has to do with the rear sub frame contacting the body? from the under car video i've seen that sub frame gets real close to the body under hard braking and accelerations.
for the record my car has the same clunk as the OP and i've never done more than use the parking brake to stop the car rolling down the driveway. |
#32 | |
I had figured something was different after they put everything back together. I do agree that I was sensitive to EVERYTHING after that. I cringed every time I looked in the rear view, and kept thinking I'd find a boost leak any moment... That car is long gone now, though.
#33 |
Kurenai Samurai
Drives: Red and manual
the e brake is intended for use when the car is stationary. not rolling. hence the clunk......maybe
#34 | |
#35 |
Kurenai Samurai
#36 | |
#37 |
Drives: 2013 BRZ Premium Blue Manual
I have the same ebrake clunk. I never abused the ebrake. I likely heard it the 1st time I was slowly rolling to a stop to park and pulled up the ebrake while the car was still rolling. Happened since day 1 and still doing it. None of my other cars are this loud. I thought it was originating at 1 rear drum? The noise is irritating and seems cheap. I think it is silent when rolling backwards and applying ebrake?
#38 |
Drives: 2013 Toyota GT86
Learn how to clutch kick to initiate a drift. Problem solved
2013 Asphalt GT86 HKS F-Con is: HKS V1 Supercharger: Tomei UEL Header: Tomei Overpipe: Trust/Greddy CS GTS Ver. 2 Exhaust: Airlift Suspension: Sard Seat Covers: Defi Boost Gauge: Innovate Wideband A/F Gauge: Ca-Fi Dashlinq4 Headunit: KM4SH #006: Tom's TN06 Wheels: Winjet Headlights: Tom's Tails: Beatsonic Shark Fin: Hood Struts |
#39 |
Potato Farmer
Drives: #SLOBRZ
Something something butter..
www.vic86brzclub.com |
#40 |
Drives:
Will this be covered under warranty?
#41 |
Just for kicks I'll throw in that my e-brake has also done this since day one when pulling the handle under even the slightest of motion.
I will also admit that I've always been an e-brake user, though not for handbrake turns (well, maybe once or twice). I use it for slowing on the highway to keep the nose from diving while potentially under "observation" from the constabulary. I've been doing this for twenty years and four other cars now - and multiple rentals - and I've never heard an e-brake make this sound (I've also never "burned up" a brake or overly stretched a cable). So, while all the links and definitions of drum brakes are nice, that is not the answer. Or more specifically it's not the whole answer. It may be perfectly normal for however the twins are set up, but it is unusual in general. |
#42 |
Drives: FR-S Whiteout
You need to put some e-brake oil on the brake shoes.
| Anyone doing brake bleeding with the "Gravity Method"? | Hanakuso | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 03-03-2013 02:53 PM |
| "Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
| pulling e-brake with auto tranny | carbonBLUE | Engine, Exhaust, Transmission | 2 | 05-16-2012 04:27 PM |
| Limited gets brake "upgrade" over Premium - Canada only? | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 25 | 05-15-2012 12:35 AM |
