Old 04-07-2014, 07:30 PM   #617
vgi
Drives: frs
Originally Posted by Td-d View Post
Tinywrex was the first to provide a patch, NSFW then coded it up from scratch and posted up the source on the RR forums, this was then incorporated into Merp's work. Not sure where the OFT code comes from, but it's really quite a simple piece of code, not difficult to code up in C.
Got it. I knew there had to be an open source code for that but didn't spot it on RR forums. So what else merpmod has besides ffs/lc and sd?
vgi is offline   Reply With Quote
Old 04-07-2014, 07:42 PM   #618
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Plenty - cel flash on knock, cel flash on high EGT (using o2 sensor resistance), speed density with MAF blending, FFS with per gear thresholds, LC, per gear boost control. I'm sure I'm forgetting stuff...
Sent from my iPad using Tapatalk HD
Td-d is offline   Reply With Quote
Old 04-13-2014, 01:38 PM   #619
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Regarding the "base timing a" and "base timing b" tables. I've been missing around with different settings trying to figure out the difference, and it looks like "base timing b" is used only when vcs sport is on is that correct? I wanted to relabel the tables so I won't forget.
D-VO is offline   Reply With Quote
Old 04-13-2014, 01:49 PM   #620
Kodename47
Kodename47's Avatar
Drives: UK GT86
AFAIK Base A is VVT disabled, B is normal operation.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-13-2014, 02:04 PM   #621
D-VO
Does that mean that VVT is disabled when the VSC sport is off? On the dyno graphs I'm noticing a 40hp difference when vsc is on or off.
*EDIT* Timing was too low on first pull. Just happened that my VSC was off and I didn't think 2 degrees of timing would make so much difference.
Old 04-13-2014, 02:18 PM   #622
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, VSC should have no impact on the tables at all and doesn't have an impact on performance. All the VSC does is allow for less interruption from the traction control. Are you talking about the AT or MT?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-13-2014, 02:29 PM   #623
D-VO
I have an MT. Maybe there's another variable that I'm missing.
Old 04-15-2014, 06:31 PM   #624
Wepeel
Drives: '13 BRZ Ltd
Anyone know if there anything like Learning View in the works for this platform? Loved that feature for my '08 STI but I know that capability wasn't available after MY '11 (I think)...
Wepeel is offline   Reply With Quote
Old 04-15-2014, 07:08 PM   #625
vgi
Drives: frs
Not as far as I know. You should ask developer of LV on RR forum if he plans to do a new release.
Old 04-16-2014, 03:01 PM   #626
qoncept
qoncept's Avatar
merchgod wrote Learning View and he works for Cobb now.
qoncept is offline   Reply With Quote
The Following User Says Thank You to qoncept For This Useful Post:
EAGLE5 (04-16-2014)
Old 04-16-2014, 03:34 PM   #627
vgi
Drives: frs
yep, i just couldn't remember the nick from the top of my head.
he wrote a LOT of good staff.
the problem is that most of those free proggies aren't open source. so when they move on with their lives their proggies die off.
The Following User Says Thank You to vgi For This Useful Post:
EAGLE5 (04-16-2014)
Old 04-16-2014, 04:16 PM   #628
regal
Drives: Scion FR-S/Toyota Yaris
I hope there is room for a few remedial questions but after 2 years I am very close to updated to the latest factory calib. My back up car is alost back together so in case something goes wrong no worries. My e-tuning stopped with hondata a decade ago.
What I have:
1. Tatrix cable cable.
2. ecuflash_brz_beta_1444040b.exe
3. Td-d's def file ZA1IB01C.xlm (don't think I need this as my goal is just to upgrade factory calib.)
4. 2013ZA1JB01C.bin
5. 2013ZA1JB01C.hex
6. Aspire One Laptop dual boots Win XP/Win 7x64 (USB 2.0)
I imagine I want to install all this on the WinXP partition? And do I need both the hex and bin file on the laptop? Any drivers I need (this is SP3?)
Thanks for the time/thread.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-16-2014, 06:35 PM   #629
steve99
Drives: FT86
What I have:
4. 2013ZA1JB01C.bin
5. 2013ZA1JB01C.hex
Any rom you want to write you will need a definition. You can read without one.
Did a write up on this forum in another thread TACTRIX INFO FOR ECUFLASH..... see first post. else wise you look good to go.
regal (04-16-2014)
Old 04-16-2014, 06:51 PM   #630
regal
Thank you I completely missed that thread.
Mods:
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
