Old 04-07-2014, 07:13 PM   #869
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Boostedpro View Post
I don't know if you guys have tried this yet or not, but after I had new tails installed I ended up with condensation. So I popped the panel in the trinl and used a 1/4 inch ratchet with I think a 10mm socket and got probably an 1/8th of a turn on each nut. Haven't had any condensation since.
From TSB:
caution: Failure to follow the proper tightening sequence and torque specification will result in damage to the new combination lamp. Starting with number 1, hand tighten each nut in order prior to torquing them to the final specification. Torque the nuts down in the same order.
Torque Specification: 4.5 N-m (0.46 kgf-m, 39 in.lb)
Old 04-09-2014, 06:43 PM   #870
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
No response from Subaru yet...
speedracer38 is offline   Reply With Quote
The Following 2 Users Say Thank You to speedracer38 For This Useful Post:
daftpunk (04-13-2015), ftc~brz (04-11-2014)
Old 04-09-2014, 09:44 PM   #871
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Just found it in my passenger tail light yesterday. Yeaaa! Now I have chirps under my hood and splashing in the back. This one is going to be a Tom's tail light replacement and self seal.
AVodka14 is offline   Reply With Quote
Old 04-09-2014, 10:51 PM   #872
mmsracing
Drives: 2013 FRS
my dealer just ordered me a new light. I just went in, they took pictures and new light is on the way
mmsracing is offline   Reply With Quote
The Following User Says Thank You to mmsracing For This Useful Post:
Old 04-10-2014, 12:23 PM   #873
aagun
Drives: 86
Just u have remove it and install it but with more harder torque
aagun is offline   Reply With Quote
Old 04-10-2014, 04:36 PM   #874
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
That's not necessarily the case and I wouldn't be telling people that. You have to be very careful how much you torque the nuts, because if you go too far you'll crack the housings.
It's listed a few times in this thread, but the torque specs are:
3.25 ftlbs / 39 inlbs / 4.4 Nm
You might get away with a little tighter than that, but I wouldn't push the limit.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline   Reply With Quote
Old 04-10-2014, 05:08 PM   #875
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
I just had mine replaced yesterday, and Toyota replaced both. Although, it was in one of the lights. They said that they're putting in a new gasket, and this supposedly fixes the issue.
TOTO_86 is offline   Reply With Quote
Old 04-10-2014, 05:27 PM   #876
Dpforlife
Dpforlife's Avatar
Drives: Scion FR-S Raven
I'm on my second taillight with the third on order threw the dealer under warranty. If this one is bad I give up!!
Dpforlife is offline   Reply With Quote
Old 04-10-2014, 05:40 PM   #877
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Did you do anything for those chrips?
N1rve
Old 04-11-2014, 01:01 AM   #878
AVodka14
AVodka14's Avatar
Nothing about the chirps. I could care less. I am taking the car in for it's first oil change and getting the tail light replaced.
Could be a little zoo in my car if I can get some fish in my tail light housing to go along with the crickets.
Old 04-11-2014, 03:13 PM   #879
aagun
Drives: 86
the nuts and bolts are made of steel also you have tail light gasket. so that make safe from losing bolts tiered or brake the tail. i not say torque it until the tail broken .
Old 04-11-2014, 04:09 PM   #880
wdninja
wdninja's Avatar
You did say to torque it more. How is someone going to know how much "too much" torque is? That's why the torque specs exist. As I said, you can go a little tighter than the specs, but not too much.
There are a lot of factors and variables at play, including the temperature you're working in. Plastic breaks more easily in cold temps, for example.
Do whatever you'd like with your own tail lights. I just want people to be aware that you can easily over torque the tail light post nuts. We're trying to prevent condensation in this thread, not potentially cause more.
G'day.
Old 04-11-2014, 10:32 PM   #881
cycleboy
Drives: 2013 Scion FR-S - Argento
My driver's side has had water in it since the one and only decent storm we had in Ca. Today I decided to start doing something about it. I got some removable adhesive (so-called snowman snot, but mine's blue!), and alcohol to dry out the existing water. Intending to get some new gasket material too, just didn't do it today.
CRITICAL WORD OF CAUTION - Be careful what you use for your drying agent. More below.
First off, here's the gasket after I took it off. Lots of crap stuck on the tiny adhesive area. Of course this isn't going to hold up when it is the runoff path for half the back end of the car!
It is lighter though because racecar!
So I pulled one bulb from the housing and couldn't figure out how the water got in because it looks like the lights are an enclosure-within-an-enclosure - they aren't! Next, I poured in a little of my alcohol with a funnel to dry out the existing puddle and drops in there.
CAUTION - MAKE SURE WHAT YOU USE FOR THIS HAS NO SOLVENT IN IT! To put it mildly, I fucked up big! I couldn't find methanol easily, so I got denatured alcohol at Home Depot. Should be just fine though as it is similar enough.
Well, what I got apparently has a tiny bit of acetone in it (from Home Depot, supposedly "greener" denatured alcohol. MY ASS!). I didn't notice the smell right away when I opened it and poured it in, but I did a few seconds later. Hoped for the best, but today is not my day!
Eff You See Kay! Shit! Crap!
Well, looking on the bright side it appears I'll be getting some aftermarket tail lights very soon. I guess I have to figure out which ones I like.
On the downside, I wasn't planning on spending that $ on that mod. . .
cycleboy is offline   Reply With Quote
The Following User Says Thank You to cycleboy For This Useful Post:
kodyo (04-12-2014)
Old 04-12-2014, 12:18 AM   #882
kodyo
Drives: Scion FR-S
Get OEM tails for cheap then. $150 for a set is common.
kodyo is offline   Reply With Quote
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 04:48 PM
HKS head and tail lamps DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 5 05-19-2012 02:04 PM
Tail of the Dragon Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 32 02-10-2012 03:30 PM
headlight condensation MRZ415 Off-Topic Lounge [WARNING: NO POLITICS] 1 01-23-2012 03:24 AM
Optional coloured tail lights? m_life Scion FR-S / Toyota 86 GT86 General Forum 9 11-30-2011 07:20 PM
