AVOturboworld
Old 04-09-2014, 07:16 AM   #2885
M1K3
M1K3's Avatar
Drives: vrooom...
Originally Posted by protpibe View Post
What kind of oil cooler sandwich plate is that?? That thing is huge
That's the RobiSpec Rad/Oil cooling setup on Sportsguy83's car.
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
Sportsguy83 (04-09-2014)
Old 04-09-2014, 07:40 AM   #2886
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Wow, I had seen the pic earlier, and didn't even cross my mind that is my car..
The radiator is HUGE too
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Astroboy (04-12-2014)
Old 04-09-2014, 07:44 AM   #2887
M1K3
M1K3's Avatar
Drives: vrooom...
In all fairness your engine bay looks quite different now though.
Old 04-09-2014, 06:22 PM   #2888
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Well kit is almost done being installed now! Just waiting on the always delaying UPS
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 04-10-2014, 12:40 AM   #2889
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
So after a long arduous process and winter, I finally took my car out for a rip today. There's still a bit of snow on the ground, but the roads are dry for the most part and it's above zero. I took it fairly easy since there's a winters worth of moisture in the gas tank and 6 month old 91 octane fuel, but I was really surprised to see 7psi on my boost gauge. Is this normal? I'm assuming it's the actuator rod adjustment. I'm actually totally ok with it running 7psi, I just need to get my map updated by Bill @DeliciousTuning
Either way, the car pulls like a beast even though I didn't wind it out. Can't wait to get my tune dialed
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 04-10-2014, 01:02 AM   #2890
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
My god...that boost. I know I am not running more than 6-7 PSI but....wow. This just feels GREAT haha!
Slight leak in the line that feeds the turbo from the motor, the line has a "sweat" of a leak from where the line is crimped (so between the crimping and the fixed bolt that is threaded onto the crimped end) So it could not be fixed with teflon or anything else. Looks like I will be getting a custom line made locally to fix this issue
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
Astroboy (04-11-2014), protpibe (04-10-2014)
Old 04-10-2014, 01:11 AM   #2891
protpibe
protpibe's Avatar
Actually mine has been seeping oil from there too. I thought it was the Crush washer.
Before that I thought it was the oil pump leaking but after i redid it once, i checked the line under the fuel injector cover and there was oil around it. Unfortunately, it looked to pool up a bit on top of the head and then drip down by the oil pump onto the exhaust overpipe. The burning oil caused the ceramic coating to chip/flake off of my AVO overpipe and a chunk of it is bare stainless steel now.
Anyways, I re-used the brass crush washer but made sure to teflon tape the bottom part of the threads on the fitting into the block. I'll let you know if it solves the issue, if not, mine may be the line as well. I also torqued that bastard down pretty tight. I would of used a new crush washer, but the fitting was way smaller than I expected and didn't have a new one.
Sent from my HTC One using Tapatalk
The Following User Says Thank You to protpibe For This Useful Post:
SkAsphalt (04-10-2014)
Old 04-12-2014, 06:02 PM   #2892
Astroboy
Astroboy's Avatar
Drives: None
When I installed mine my "passenger air bag off" light came on... Is anybody having the same issue?
Astroboy is offline   Reply With Quote
Old 04-12-2014, 06:03 PM   #2893
protpibe
protpibe's Avatar
You mean the light that comes on when no one is sitting in the passenger seat ?
Old 04-12-2014, 07:02 PM   #2894
Astroboy
Astroboy's Avatar
Drives: None
Yes... does it only say that when nobody's in the passenger seat? God I feel like such an idiot
Sent from my LG-D800 using Tapatalk
Old 04-12-2014, 07:25 PM   #2895
protpibe
protpibe's Avatar
Yes, it does lol
No big deal, not everyone is a car expert
Old 04-12-2014, 08:10 PM   #2896
Astroboy
Astroboy's Avatar
Drives: None
Yes, it does lol
How much oil are you suppose to put in your car now with the turbo?
Old 04-12-2014, 08:12 PM   #2897
protpibe
protpibe's Avatar
You won't need to add that much. I would guess 1/4 of a liter, but keep an eye on your dipstick to add as needed
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Astroboy (04-13-2014), SkAsphalt (04-13-2014)
Old 04-13-2014, 02:57 AM   #2898
Astroboy
Astroboy's Avatar
Drives: None
So about a little over 6qts?
Because I was told that the scion frs requires about 5.7 qts
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
