Old 04-08-2014, 08:21 PM   #4271
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Originally Posted by xjohnx View Post
opened a ticket but it looks like it was closed, at least its not on my recent tickets page anymore. i'm going to wait until next week when he has more time to bug him since i need some non-standard stuff on my rom (wideband o2 via rear o2 sensor), perrin 3" intake.
Has he gotten you a version with rr7? Pretty sure the 8.52 version I have was still rr5 (12000 svn revision range, still the a1c ROM)
mikalem is offline   Reply With Quote
Old 04-08-2014, 08:43 PM   #4272
xjohnx
Grip>Slip
xjohnx's Avatar
I got 8.52, but i need one with the custom map enabled for the wideband (and now the 3" perrin)
Old 04-08-2014, 10:18 PM   #4273
TemeCal
Drives: 86
Originally Posted by CK_Bladesmith View Post
Has anyone got the 8.54 tune revision from @DeliciousTuning?
I haven't received my revision either. Opened the ticket when it was first announced. I just continue to *patiently* wait.
TemeCal is offline   Reply With Quote
Old 04-08-2014, 10:28 PM   #4274
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
I received an update a few days ago for my intercooler upgrade and Bill sent me 8.52. What coolant did you guys use for the intercooler?? I used the Subaru coolant and realized its a 50/50 mix and the manual says to use a 70 water/30 coolant mix.
Sent from Samsung Galaxy Note 3
Area86 is offline   Reply With Quote
Old 04-08-2014, 10:49 PM   #4275
olorin
olorin's Avatar
Drives: GBS Premium
I just used regular coolant-- you don't have to use the subaru stuff. More water in the mixture will make it cool better but will raise the freezing point and lower the boiling point. I think I did closer to the 70/30 mixture.
olorin is offline   Reply With Quote
Old 04-08-2014, 11:30 PM   #4276
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I'm testing 8.54 at the moment, ran about 60km of logs under different conditions. We noticed car running a little Rich hence reason for all the logs.
Im sure it's just my version of the tune, as I'm adding mixture to increase to 103Ron, which requires fine tuning. If not then you know Bill working hard to get this tune perfect out to you.
It is super smooth, no hesitation, nice power with a kick from 4000rpm WOT.
Ryan86 is offline   Reply With Quote
Old 04-08-2014, 11:39 PM   #4277
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
I'd suggest a very thorough test in 6th gear around 70-80mph (whatever that is in km), on the highway with varying throttle input from barely any up to WOT. Aside from the surging in the 4-5k range under creeping throttle input, I've always felt a slight jerky feeling in the car while on the freeway and climbing very small hills (this is in the 3k range)
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 04-08-2014, 11:46 PM   #4278
Ryan86
Road Warrior
Ryan86's Avatar
I'd suggest a very thorough test in 6th gear around 70-80mph (whatever that is in km), on the highway with varying throttle input from barely any up to WOT. Aside from the surging in the 4-5k range under creeping throttle input, I've always felt a slight jerky feeling in the car while on the freeway and climbing very small hills.
Exactly what I logged cruising at 120kmh 6th gear slight throttle in and out for over 50km. Then town driving in traffic for 10km. Next day cold start driving into traffic for 15km then back on highway cruising for 20km.
Then pushed the car 4,5,6 gears from 3000 up to 7000rrpm for 15km.
Anything else you suggest?
I assure you the jerk is gone.
Old 04-08-2014, 11:59 PM   #4279
CK_Bladesmith
Drives: Raven FR-S
If you've done mild acceleration pulls in stop and go traffic from 1-4th gears (to keep up with the acceleration of the traffic), and there's no jerk at 20 to 50% throttle then I can't make any other suggestions
Old 04-09-2014, 12:13 AM   #4280
Ryan86
Road Warrior
Ryan86's Avatar
I promise I did just that.
Bill was very specific in how to log and requested long continuos logs. I did almost 200km of logging.
That jerk around 4000rpm gone, however I did feel ever so slight hesitation under 2000rpm when I came off the highway back into traffic for the first few pull off, then went away. Got this on the log.
Other than that very very smooth.
The Following User Says Thank You to Ryan86 For This Useful Post:
CK_Bladesmith (04-09-2014)
Old 04-09-2014, 02:45 AM   #4281
KSpider
KSpider's Avatar
Drives: '14 S4
In order to sell me car to the dealer that is purchasing it, it must pass smog here in CA and be "legal". Please let me know your thoughts on if my car will pass, to be honest, I have never had a car smogged before, I am not sure what is involved or what they check.
My SC has a CARB sticker from innovate.
I have a catback exhaust, no headers / all stock cats.
Running flex fuel and 70mm pulley.
Would pump gas or e85 be best for passing smog?
Do you guys think Ill have an issue???
2014 Audi S4 · 2010 xTerra Off-Road · 2014 Fiat 500e
KSpider is offline   Reply With Quote
Old 04-09-2014, 12:13 PM   #4282
mikalem
mikalem's Avatar
Assuming you aren't running the carb tune, having the Flex Fuel and 70mm pulley? I'm pretty sure some of the flex fuel tunes out there using the CPC input to the ECU caused one of the systems to report "Not Ready" (I know I've seen it aleast on my original flex fuel tune, haven't checked the latest from my current tuner - Ohio doesn't care) - not sure what Cali's stance on that is - I know if you use something like Torque you can check your car out to see what the systems report. Since you haven't changed the header/overpipe/midpipe you should be good CO2 wise - it just depends if they connect up to the ODBII port to see what the ECU reports.
Old 04-09-2014, 12:17 PM   #4283
KSpider
KSpider's Avatar
Drives: '14 S4
Correct, not running the CARB tune, due to flex fuel and pulley. I didn't realize they checked anything with ECU... figured it was just CO2...
I do have an ODBII connector, but I have an iPhone so no torque. I have an app, what am I looking for?
Old 04-09-2014, 12:23 PM   #4284
mikalem
mikalem's Avatar
Not sure of an app for the iPhone that does it (I'm an android guy) but I believe it's called a "Readiness Monitor" and the ECU reports on a few of them (something like 6 - 8 of them I think). Not sure if Cali does this or not however, or if you are "allowed" to have a few report Not Ready as opposed to Ready.
Might try something like this?: http://www.devtoaster.com/products/rev/
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
