Old 04-08-2014, 01:50 AM   #1
Goodmanner
10 Series TRD
Goodmanner's Avatar
Drives: 2013 FRS 10 Series, 2013 IS250
Leaking Shock Abosrber
My car is currently at around 5400 miles and I noticed some sort of leakage coming from the rear driver side. At first I thought it might've been a leaking exhaust but it turns out to be from the shock absorber.
Has anyone else experienced this issue?
Goodmanner is offline   Reply With Quote
The Following User Says Thank You to Goodmanner For This Useful Post:
ZionsWrath (04-08-2014)
Old 04-08-2014, 01:52 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
rule out leaking exhaust vs leaking shock absorber
wut?
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
gramicci101 (04-08-2014), sshole (04-08-2014)
Old 04-08-2014, 01:57 AM   #3
Goodmanner
10 Series TRD
Goodmanner's Avatar
wut?
I'm not too technical of a person when it comes to cars so bear with me. What I first noticed on the drive way were wet stains. My initial conclusion was that it might be coming from the exhaust (as the stain was near the area). Anyway, I wiped it with my finger and it was this rather clear oil. I had a friend of mine come over to take a gander and he confirmed that it was coming from the shock absorber.
Anyway I'm going to be taking this to the dealership tomorrow but I wanted to see if anyone else had similar issue(s) with this.
Thanks for your reply, however.
Old 04-08-2014, 01:59 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
If it is actually an oil there is no way it is from the exhaust, I agree with taking to dealer if it is an oil and not just water
The Following User Says Thank You to ZionsWrath For This Useful Post:
Goodmanner (04-08-2014)
Old 04-08-2014, 02:38 AM   #5
I haven't read about any leaking shocks on these cars.
However, whatever is leaking back there ..... it shouldn't be.
Yep, best have it checked out.
I hope it's minor.
Old 04-08-2014, 08:34 AM   #6
sshole
If your shock is leaking, you should be able to tell pretty easily. Lift up right rear corner of the car, grab a white paper towel, wipe the shock as best you can through the coils of the spring. Do you see oil? If yes, go to the dealership and get a new one. If no, it's likely not your shock.
sshole is offline   Reply With Quote
The Following User Says Thank You to sshole For This Useful Post:
Old 04-08-2014, 12:15 PM   #7
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Are you lowered on springs?
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
The Following User Says Thank You to SpeedyJay For This Useful Post:
Old 04-08-2014, 12:19 PM   #8
Goodmanner
10 Series TRD
Goodmanner's Avatar
Hello, yes I am. I have the eibach pro kit installed. I've had it installed for well over 3 months and never had an issue.
Old 04-08-2014, 12:45 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
In that case you are SOL dealer isn't going to replace that for you. Buy some konis or bilsteins to replace
The Following 5 Users Say Thank You to ZionsWrath For This Useful Post:
fx35s (03-13-2015), humfrz (04-08-2014), RobertPaulson (03-22-2015), sshole (04-08-2014), strat61caster (04-08-2014)
Old 04-08-2014, 01:36 PM   #10
Goodmanner
10 Series TRD
Goodmanner's Avatar
I dropped it off this morning and am waiting to hear back from them. Hopefully the Warranty Gods will grace me with their presence.
Old 04-08-2014, 02:15 PM   #11
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
You do now!! An upgrade is in order, I anticipate this when I lower my own! I'd like to put KYB adjustable struts on, if they make them for our cars...
Wolfking is offline   Reply With Quote
The Following User Says Thank You to Wolfking For This Useful Post:
Old 04-08-2014, 02:29 PM   #12
Goodmanner
10 Series TRD
Goodmanner's Avatar
I was hoping the stock would at least last more than a few thousand miles.. I am still waiting for the dealership to give me a call back on the status.
Old 04-08-2014, 02:30 PM   #13
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Definitely let us know if they warranty the shock w/ the Eibachs installed.
Originally Posted by humfrz
I'm old and lazy
Old 04-08-2014, 02:33 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
If they warranty it you better go play the lotto
The Following 3 Users Say Thank You to ZionsWrath For This Useful Post:
Goodmanner (04-08-2014), strat61caster (04-08-2014), Wolfking (04-10-2014)
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 08:14 PM
Oil leaking? grgonium CANADA 7 07-30-2013 05:08 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 05:15 PM
