Old 04-07-2014, 03:22 PM   #1
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Wheel Directory: Forgestar F14 18x9.5 +40
I didn't see a specific thread for these wheels with this offset yet, but I promised @ModBargains.com photos when I got the wheels installed.
Wheels: Piano Black Forgestar F14 18x9.5 +40 all around
Tires: Michelin Pilot Super Sports 265/35/18 all around
Suspension: HVT Electronically Valved Dynamic Dampening Monotube Prototypes
Camber: -2.4* all around
Fenders: Fronts rolled, pulled outward by the front bumper. Rears rolled/flatened, bumper tabs trimmed.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
continuecrushing (04-07-2014)
Old 04-07-2014, 03:25 PM   #2
mfbmike
Drives: 2013 FRS, 2008 R32
After a weekend on the dragon, I rub on the driver side rear under extreme conditions while the right rear is golden. I have the same size wheel and same tire and size.
I'm curious what your experiences are.
I'm thinking my driver's side rear might just be slightly lower than the passenger rear which is the reason.
mfbmike is offline   Reply With Quote
Old 04-07-2014, 03:29 PM   #3
Acree
Acree's Avatar
Originally Posted by mfbmike View Post
After a weekend on the dragon, I rub on the driver side rear under extreme conditions while the left rear is golden. I have the same size wheel and same tire and size.
I'm assuming you mean the right rear is golden. And if so, yes that's been my experience. I had to go to greater lengths to get the driver side rear to clear than the passenger under full compression
Old 04-07-2014, 03:35 PM   #4
mfbmike
That's interesting. I wonder why.
I've been under there and can't seem to find what the hell it's rubbing on. I understand it making contact with the fender liner under hard compression but during hard cornering (close to the limit) getting some rubbing as well, but only on that side.
Yes, right rear is fine. Driver's rear still experiencing rubbing but only under extreme cornering conditions. Passenger rear under same conditions, golden.
There are two brackets under there that come extremely close to the wheel in this size that I assumed might be making contact when the chassis flexes but that doesn't seem to be the case as there was no indication, and if so, why wouldn't both sides do it as both are just millimeters from the inner rim of the wheel.
Old 04-07-2014, 03:40 PM   #5
Acree
Acree's Avatar
Mine was rubbing on the inner fender sheet metal at the 12 o'clock position.
Old 04-07-2014, 03:42 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Daaaannngggggg....Lookin' sick!
The Following User Says Thank You to continuecrushing For This Useful Post:
Acree (04-07-2014)
Old 04-11-2014, 04:26 PM   #7
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
How much was it to get the fenders rolled? Mines are rubbing but a camber adjustment may do the fix.
Zero90 is offline   Reply With Quote
Old 04-11-2014, 04:28 PM   #8
Acree
Acree's Avatar
Depends on the shop. Mine was $100 per fender.
Old 04-11-2014, 04:33 PM   #9
Zero90
Zero90's Avatar
Hot damn, that is pricey. I'm a noob when it comes to suspension so I can't say much.
Old 04-11-2014, 05:20 PM   #10
FullTuneZN6
Novice Drifter
FullTuneZN6's Avatar
Drives: 2013 Asphalt FR-S
im looking at these wheels as well, any comments on the concavity of the 9.5s? noticeable or minimal? looks minimal from pics
FullTuneZN6 is offline   Reply With Quote
Old 04-11-2014, 06:52 PM   #11
Acree
Acree's Avatar
I'd call it minimal. But still noticeable.
FullTuneZN6 (04-11-2014)
Old 05-09-2014, 07:00 PM   #12
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Old 02-05-2015, 07:34 PM   #13
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Anyone knows if this is Semi Concave or Deep Concave? For sure its not super deep concave.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Wheel Directory: Forgestar F14 17x8.5 +38 cycleboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-20-2016 04:13 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Wheel Directory: Forgestar F14 19x8.5 +35 / 19x9.5 +38 exequtor1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 04-06-2015 09:59 PM
Wheel Directory: Forgestar F14 18x9.5 +38 empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 12-26-2014 06:24 AM
Wheel Directory: Forgestar CF5 18x8.5 +42 / 18x9.5 +45 pandora Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-10-2013 03:34 AM
