Old 04-07-2014, 09:28 AM   #981
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Originally Posted by troek View Post
ahh thanks, i guess i figured the OFT side of the cable was OFT specific. but i didnt even realize you could extend it on the obd side. i was just thinking of a single longer cable.
I would look for a Flat OBDii Right Angle Extension.
[ame="http://www.amazon.com/Profile-Right-Angle-Extension-Ribbon/dp/B00EECXAY8"]Amazon.com: Low Profile Right/Left Angle OBD 2 II Extension with Flat Ribbon Cable 3'/1m: Automotive[/ame]
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
The Following User Says Thank You to TIE Pilot For This Useful Post:
troek (04-07-2014)
Old 04-07-2014, 10:31 AM   #982
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by s2d4 View Post
The OCD in me find this process rather soothing for some reason..
That's C D O, get the letters in the correct order damnit.
I don't have OCD but my sister in law does and she thought that was funny so I figured I'd share.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 04-07-2014, 11:36 AM   #983
phrosty
Does this log look alright? Been driving it for about a week, looks like fuel trims have stabilized.
http://datazap.me/u/phrosty/oft-stag...&zoom=318-1308
It's 1.58 Stage 1 700D w/ scaled MAF for Perrin's CAI.
phrosty is offline   Reply With Quote
Old 04-07-2014, 12:14 PM   #984
Kodename47
Kodename47's Avatar
Drives: UK GT86
Looks a little lean. The LTFT is taking out about 0.8% fuel under WOT and it still looks like it's running lean even if the trims are spon on.
Did you scale the MAF yourself or use a provided scale?
Next time, can you log the commanded AFR as well? Then it's easily comparable.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-07-2014, 02:26 PM   #985
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Originally Posted by mid_life_crisis View Post
This appears to be proof that if you have 93 readily available there is room to play.
True to some extent, I'm not sure if you've read my other thread but there seems to be a limit to the extent of these ots maps, once you stray to far from the ots settings it'll pretty much scale itself down to what its default base map "safe map?"is. I'm sure you can mess with the backup map so that it won't do that but it's probably safer the leave it alone just incase you went to crazy with the tweaks can always fall back on the base safe map.
My lingo is probably wrong but that's the jest of it
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
Old 04-07-2014, 02:29 PM   #986
phrosty
I'm using Perrin's provided scale. Still not confident enough with my understanding of the steps to scale it myself, but I hope to get there.
I'll set up to log commanded AFR next time I do a pull. What's the difference between AFR and commanded AFR?
Old 04-07-2014, 02:34 PM   #987
s2d4
s2d4's Avatar
AFR is what is measured by the stock o2 sensor, commanded is what the ECU was targeting at the time.
Old 04-07-2014, 02:37 PM   #988
s2d4
s2d4's Avatar
"The higher the octane, the more compression the fuel can withstand detonation. "
Old 04-07-2014, 02:53 PM   #989
mid_life_crisis
Reasonable to expect that you can learn a lot by comparing what you told the system to produce (commanded AFR) and what it actually did produce (AFR).
Old 04-07-2014, 03:05 PM   #990
s2d4
s2d4's Avatar
What you do with it is the important part, which is what kodename47 was referring to, what would you do with it?
Old 04-07-2014, 03:24 PM   #991
mid_life_crisis
Don't ask me. I'm not going to even start to delude myself that I have any business making changes to the tune on one of these things. Some things just make sense, and I believe the information mentioned earlier would be dead useful to someone who knows what they are doing, but I'm just not that guy.
Old 04-07-2014, 04:17 PM   #992
Kodename47
Kodename47's Avatar
Drives: UK GT86
Well here's the sort of tools I've created to use to look at the data. This is after some filtering though to clear erroneous data. This is just OL changes. I've already taken into account the LTFT, in this case it's 0 anyway. If you have a LTFT set, fill the AFR column with (100 + LTFT)/100 x Actual AFR (from the log)
Data table:
Comparing original MAF scaling to those derived from the calculations (Resultant MAF):
And a MAFv vs RPM chart. This is useful to know where you are hitting certain MAFv and so you can correlate to CL MAF scaling.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
phrosty (04-07-2014), Yobiwan (04-08-2014)
Old 04-07-2014, 05:54 PM   #993
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
Quick FYI for those who plan on purchasing an OFT soon: We have less than 20 in stock as of now. New stocking order probably wont be arrive until end of next week so if you want one to ship the same (or next) day you order, we advise ordering soon. We expect to be out of stock within 24hrs.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
lookchris (04-11-2014)
Old 04-07-2014, 07:49 PM   #994
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I've got a right angle one and tuck it into the trim.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
toysub (05-06-2014), troek (04-08-2014)
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 04:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 04:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 09:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 12:53 PM
