Old 04-03-2014, 07:49 PM   #1
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Upshifting sound
Hey guys!
I recently started noticing a sound when driving around in my car and shifting gears. It sounds like a scratching noise at the back of the car. Some people mentionned that the driveshaft could be the culprit, as it's 2 parts from what I gathered.
It also does that sound when I'm just pressing on the throttle from just cruising to wide open throttle. Hope it's not a clutch issue
Mad1723 is offline   Reply With Quote
Old 04-03-2014, 07:50 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Maybe you're just kicking up rocks?
N1rve
Old 04-03-2014, 07:55 PM   #3
Mad1723
Mad1723's Avatar
Nope, it's very specific to the car, not caused by external elements. It did that in the snow and I notice it a lot more these days.
It sounds like a scratching sound, or a very slight grind.
Old 04-05-2014, 03:45 AM   #4
stEVO X
Drives: 2010 Evo X GSR; 2014 FR-S 6spd MT
is it this:
http://www.ft86club.com/forums/showthread.php?t=59745
stEVO X is offline   Reply With Quote
Old 04-05-2014, 11:44 AM   #5
Mad1723
Mad1723's Avatar
Doesn't sound like it. It sounds like a scratching sound. A slipping clutch could be the issue, but is it supposed to do it even when I'm not even touching the clutch pedal?
Old 04-05-2014, 11:50 AM   #6
wheelhaus
wheelhaus's Avatar
If the clutch was slipping, it would slip more at high rpm under high load (gear doesn't matter) and the revs would rise faster than normal and/or you'd feel a loss of acceleration.
If it was a shifting issue, you wouldn't hear it when in gear.
At what rpm are you noticing this? Does it make the noise during tip in or the whole time during acceleration?
Old 04-05-2014, 12:11 PM   #7
Mad1723
Mad1723's Avatar
The sound is produced when around 2.5 to 3k rpm, right when I floor it, you hear the scratching sound.
It also does it when shifting and hitting the gas (acceleration for example)
Old 04-11-2014, 04:41 AM   #8
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
I am also having this issue! It sounds like a wire brush scratching against metal. I thought it was the throw out bearing at first but it didn't make sense because I had to be shifting or cruising to WOT to hear the noise. It's a pretty distinct sound though. I've been trying to wrap my head around it for a while now. PLEASE HELP!!!
corvino26 is offline   Reply With Quote
laggy/hesitant throttle response when upshifting? Formula Vee BRZ First-Gen (2012+) — General Topics 27 02-14-2014 11:10 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 07:03 PM
Sound - ASL ScottKR Electronics | Audio | NAV | Infotainment 0 07-01-2013 11:34 AM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 02:33 AM
