Old 04-02-2014, 07:14 PM   #1
spyingwind
Drives: White '17 86
Rear driver side clank and click
Time frame: This started about a month ago. Didn't hear that often, because of the radio.
Car mods: none
Transmission: Standard
Issue: When the car is accelerated there is a clank, much like what a flag pole makes with a metal clasp hitting it. Then after letting go of the gas petal or disengaging the clutch, I hear click. Both sounds sound like they originate from the rear on the driver's side.
Trouble shooting:
Does not happen when I brake in either directions, forward or backwards.
Does not happen when I rock the car back and forth with a friend.
Does happen in reverse and other gears.
I suspect it is something to do with the differential. It can't be a suspension.
Any thoughts or any one else encountered this?
I do plan on taking it in to Toyota, but they want to keep it over the weekend and a few day to just diagnose it.
spyingwind is offline   Reply With Quote
Old 04-02-2014, 07:22 PM   #2
Ben_G
Drives: Blue BRZ
I have the same noise once in a while, but never was able to duplicate it.
Ben_G is offline   Reply With Quote
Old 04-02-2014, 08:14 PM   #3
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Have you tried folding down the rear seat and see if the noise goes away? If it goes away, then it might be the rear seat latch.
Old 04-02-2014, 08:29 PM   #4
spyingwind
I thought of that, but the sound is loudest from out side the car.
Old 04-02-2014, 10:00 PM   #5
I haven't noticed that in my car.
It could be a universal joint lose, somewhere in the driveline .....
Old 04-03-2014, 04:54 PM   #6
spyingwind
If I were wouldn't breaking cause the same sound? My thinking is that the force of stopping would move a loose ujoint.
If I had a dyno I can reproduce it every time.
Old 04-03-2014, 05:17 PM   #7
Supreme Taco
Drives: Subaru BRZ
I'm actually sitting in the dealership right now trying to have them figure this out. I was reading the broken axle thread and it's got me wondering if mine is about to break! Like you said though, it's not a regular noise, only when the direction of pressure changes on the drive shaft (accelerating, then lifting off gas without pressing in clutch, or accelerating forward, stopping, then accelerating in reverse).
At first they were telling me it was a loose brake pad sliding around in its place... so I held up the E-brake and tried to drive forward then reverse and each time it clicked without rolling the wheels; just from the loading on the drive shaft.
Could this be an axle thing, even if the car is stationary while doing this??
EDIT: This is the thread I was referring to - http://www.ft86club.com/forums/showthread.php?t=49511
Supreme Taco is offline   Reply With Quote
Old 04-03-2014, 05:24 PM   #8
A lose U-joint would usually only make noise when torque on the drivetrain is applied, either rotation (forward or backward).
You might slide under your car and see if you can detect any play in the u-joints of the drive shaft.
Ahhhh......heck, just take it into a shop .....
Old 04-03-2014, 05:39 PM   #9
Supreme Taco
Drives: Subaru BRZ
They just came out and confirmed that it is an issue with my axle... something is loose, but not broken. Perhaps this is what's leading to all of the breaking axles? Also, my car is totally stock aside from replaced tires (pilot sport AS3s)
Old 04-04-2014, 09:10 PM   #10
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Bookmarked this thread....I've had the issue for a long time and the dealers look at me like I'm crazy when I tell them about the noise.
speedracer38 is offline   Reply With Quote
Old 04-04-2014, 10:48 PM   #11
Ozzman
Drives: old
It was probably just a loose axle nut.
Ozzman is offline   Reply With Quote
Old 04-05-2014, 12:26 AM   #12
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
You can look here also :
http://www.ft86club.com/forums/showt...t=41762&page=3
o= FR-S =o
Mikepage is offline   Reply With Quote
click, clank click sounds when cooling down and more? leaking oil? Boofneenee Issues | Warranty | Recalls / TSB 19 10-02-2013 12:27 PM
Click sound from left rear Tt3Sheppard Issues | Warranty | Recalls / TSB 1 09-25-2013 06:58 PM
WTB: FRS rear driver side seat base. Raven604 Want-To-Buy Requests 0 09-05-2013 01:23 AM
WTB Rear Seat Butt Cushion BRZ Limited(driver side) larryt1026 Interior Parts (Incl. Lighting) 0 04-05-2013 09:18 AM
