Old 04-04-2014, 08:18 PM   #1
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Side marker lights not turning on anymore
Hey guys, just wondering if anyone has run into this problem and if you could give me a hand. Both my left and right side maker lights have stopped working. - They both seemed to have quit at the same time.
Full click of the stalk does give me my proper low beams, turns on my signal lights (as they should) and more weird, activates my fog lights (which are tapped into the side marker lights for activation!)
The fog lights were installed last year and everything has been working great since then...so I do not know if it is from that installation or not (simple pinch type tap connector)
So could it be
  • the fuse? if so, which one do I replace? manual was not helpful
  • Could it be the fact my TPMS sensors are gon, this sounds wierd but it has been over 250km since I have switch to new rims and I have not had a light come on yet...coincidence most likely.
  • Could it be that both LED bulbs gave out at the same time?
  • Could it be the wiring? It is weird that the fogs still work tho isn't it? I will have the bumper off tonight, so I guess I can check later.
Old 04-04-2014, 08:36 PM   #2
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Originally Posted by SkAsphalt View Post
Full click of the stalk does give me my proper low beams, turns on my signal lights (as they should) and more weird, activates my fog lights (which are tapped into the side marker lights for activation!)[/LIST]
why would that be wierd? the fog lights are working as intended.
I would look at the fog light/parking light connection. The pinch type connector could've cut straight through the wire and now no power is getting to the side marker bulb.
subiestyle is offline   Reply With Quote
Old 04-04-2014, 10:23 PM   #3
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Check fuse 10 (I think) under the steering column. I believe it's labeled as "tail light fuse" in the manual. That fixed the issue for me, my fuse was fried. I have a BRZ though. Could be a bit different.
Bg8780 is offline   Reply With Quote
The Following User Says Thank You to Bg8780 For This Useful Post:
SkAsphalt (04-04-2014)
Old 04-04-2014, 10:36 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I just thought it was weird because if the fogs still worked, why not the side markers, it's been over a year. I will check the t connector tonight and that fuse. Thanks guys.
Old 04-06-2014, 01:14 AM   #5
Bg8780
Bg8780's Avatar
Any luck? When my fuse blew the foglights and tail lights did not work. Only the brake lights and main headlight. But as I said before, I have a BRZ so it could be wired a bit different.
Old 04-08-2014, 03:12 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Nope, they still don't work. It is very weird. Kind of put the issue aside while I install my turbo kit though.
Old 04-08-2014, 09:30 PM   #7
Bg8780
Bg8780's Avatar
Hell yeah! Boost now, lights later!
Anybody try VLED side marker lights? subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 8 03-30-2014 10:17 PM
Side marker lights gap subiestyle Cosmetic Modification (Interior/Exterior/Lighting) 1 03-06-2014 02:42 AM
FS: JDM clear side marker lights ILL_86 Audio/Visual, Electronics, Infotainment, NAV 3 01-02-2014 06:19 PM
FS: smoked side marker lights. NorCal_Guy Exterior Parts (Aero, Lighting, Etc.) 46 07-14-2013 05:42 PM
unplugging side marker lights BRZPDX BRZ First-Gen (2012+) — General Topics 2 03-27-2013 12:05 AM
