01-12-2013, 03:56 PM | #57 | |
Drives: '13 Argento 6MT FR-S
01-12-2013, 05:09 PM | #58 |
Yes. Basically 50$ and 2 hours of time (my first time ever taking anything out of the frs interior and first time ever doing sound matting)
01-13-2013, 11:03 PM | #59 | |
Drives: 2008 Honda S2000 (yellow)
01-14-2013, 12:39 AM | #60 |
Drives: CBS BRZ Limited
Not readily available unfortunately. If I get a chance I can try to snap some pics. It's not pretty because they're much smaller patches than what you usually see in installs, but Don's methods do work. No sense in adding weight and cost without additional benefit, right? :happy0180:
01-18-2013, 08:46 AM | #61 |
Drives: 2013 Subaru BRZ Limited SWP
I have the JPM Coachworks Alcantara speaker covers to install so I decided to order a CARE package from Second Skin Audio. I ordered a sheet of Overkill pro and a door pack of Damplifier, plus a single sheet of Luxury Liner and a Speaker Tweaker kit. I also have about 12 sq ft of Damplifier and a whole sheet of Overkill left over from doing my Si. Unfortunately the stuff from JPM arrived last night, but the Second Skin stuff isn't going to get here until Monday. I have a wedding to attend next weekend so I may not get anything done for a few weeks.
Since I'll have the doors apart to install the speaker covers, I'm going to start by sealing the doors and installing the Speaker Tweakers. What I'm hoping to do is to clean up the stock bass and be able to crank the volume a bit more without distortion/rattling. My goal is to see how good I can make the stock system sound before doing any aftermarket upgrades, with the added caveat that I don't add a bunch of weight to the car as well. Since sound deadening can improve the sound by removing competing noise, then it's the first thing I'll tackle. I eventually will be going with some aftermarket audio gear but my goals are to
A buddy and I are working on a unique subwoofer solution for the rear seat location, which we'll document a little more once we're further along in the project, but for now, I'll be happy to see how much improvement is available just with the stock setup.
Derek
2013 BRZ Limited SWP Professional driver in search of closed course.. |
03-09-2013, 12:09 PM | #62 | |
Klaatu barada nikto
Drives: Raven FR-S MT
I'm doing JPM speaker covers as well. I also have the same goals. Minimum weight added, but with quality results. So, I'm wondering how your install went. Pics? Recommendations? Results? DIY guide? I'm thinking of doing just around the speakers, and strips in key vibration areas. I'm not sure where the best areas are though. Any input from the pros here on the best places to put a minimal amount of deadening is welcome. Thanks. Edit: @WolfSongX I should've searched a little more. I just found your other thread. http://www.ft86club.com/forums/showthread.php?t=28506 Thanks!
I vow to do no harm. 2013 Raven FR-S Manual "Lenore" 1985 Silver RX-7 GSL-SE (Gone and missed) Last edited by Slartibartfast; 03-09-2013 at 03:51 PM. Reason: Found your other thread |
07-21-2013, 10:32 AM | #63 |
Drives: 2013 Scion FR-S Raven
Recent additions
Rear seat base
Rear compartments with new Alpines Raammat BX II , Ensolite one huge piece on interior trim, Second Skin Audio Speaker Tweaker Kit glued to Raammat directly behind the speaker I don't hear much of a difference in sound quality, the rear seat area is quieter, can't hear the rear Michelin PSS tires anymore.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
The Following 2 Users Say Thank You to tonystewart For This Useful Post: | PatrickSAN (07-22-2013), SkAsphalt (07-22-2013) |
09-07-2013, 01:59 PM | #64 |
Trunk Update
The Following User Says Thank You to tonystewart For This Useful Post: | drewbot (08-13-2015) |
09-07-2013, 03:25 PM | #65 |
Drives: TRD Ultramarine '13
For sound deadening? Just tape.
The Following 4 Users Say Thank You to kALMIGHTY For This Useful Post: |
09-08-2013, 02:37 AM | #66 |
Drives: GT86
I intend to use Tecsound SY50 as the primary noise barrier. It's thin but rated at 5kg/sq.m.
May put some of their FT55AL on top in some areas or possibly 3M thinsulate. I don't really want any cld in the car. |
04-03-2014, 09:10 AM | #67 | |
Drives: Scion FRS
I am considering doing sound deadening on my trunk too. Can you kindly give everyone an update? Does it improve much on the noise? Do you do it on the door too? Many thanks, |
04-04-2014, 02:03 PM | #68 |
Frosty Carrot
Drives: The Atomic Carrot
I used Stinger Expert Roadkill. It looks like we'll need 30 sq ft for the doors, quarter panels, and trunk area. If you want to line the floor, that's probably 20 more. Headliner is probably 15 more.
The doors received a full coating on the outer skin and based on the "tap and slap" method I did the inner skin with patches. I'm not done yet (actually worked on it during the lunch break today). Eventually, I'll add closed cell foam to replace the plastic vapor barrier. Doors: Trunk
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
04-10-2014, 09:47 PM | #70 |
I wouldn't put much effort into sound deadening materials until you have removed the sound generator. Most of the sound in the cabin is from that sound generator, not the wheels, engine or exhaust. I verified that with a sound meter and have it in a separate post in the "BRZ General" section as
http://www.ft86club.com/forums/showthread.php?t=61234 |
Similar Threads | ||||
Sound tube mod? | smbrm | Engine, Exhaust, Transmission | 25 | 06-20-2012 07:24 PM |
Southeast sound OFF! | OldSkoolToys | Southeast | 133 | 05-25-2012 12:31 AM |
86 Sound System | Skorov | AUSTRALIA | 25 | 05-09-2012 04:51 PM |
BRZ exhaust sound! | ilikecars86 | BRZ First-Gen (2012+) -- General Topics | 16 | 04-13-2012 03:26 PM |
What should the FR-S sound like? | 1660 | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 07-31-2011 01:33 AM |
