Old 04-01-2014, 12:40 AM   #15
bobaab
Drives: 13 Subaru BRZ Limited
Does anyone use a dashcam to leave on over night? I have to park on the street in Chicago and the car recently got broken into. I'm thinking about a discrete dashcam setup that stays on after the ignition is turned off and holds the last 48 hours of video (or something like that).
Just want to increase the possibilities of catching someone doing whatever to my car, especially a hit and run situation during parking...happens way too often here.
bobaab is offline   Reply With Quote
Old 04-01-2014, 10:23 AM   #16
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I don't do it personally, but I know folks who do. I know that iTronics has a special power adapter that will keep the camera powered with the ignition off unless/until battery voltage drops below a certain threshold. That way it will record video for as long as it can without draining your car battery.
I believe most dashcam manufacturers offer a similar power rig, and most also will have the ability to only trigger recording when motion is detected.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
The Following User Says Thank You to codesplice For This Useful Post:
bobaab (04-01-2014)
Old 04-01-2014, 10:42 AM   #17
HunterGreene
Hail Magnet
HunterGreene's Avatar
Just purchased an OJO cam, looks like it will be a huge improvement over the clunker I have as a dash cam now. Thanks for the heads up!
It has priests in it?
Old 04-02-2014, 06:05 PM   #18
Chimera
Drives: FRS
I saw the roadhawk brand had a power unit it inline filter for voltage drop threshold to prevent battery overdraw..
I think I'll probably go this route myself.
Old 04-02-2014, 06:49 PM   #19
spyingwind
Drives: White '17 86
With any dash can that is kept in the car during hot days. I recommend that you either remove battery or remove the camera when you aren't using the camera. My finevu battery expanded in the Texas heat. Caused some component damage.
spyingwind is offline   Reply With Quote
Old 04-03-2014, 05:23 PM   #20
djdnz
1337
Drives: 2013 BRZ WRB S/C
The OJO/Mini 0801 is very tempting - I will likely be picking one up!
djdnz is offline   Reply With Quote
Old 04-03-2014, 05:37 PM   #21
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Ec1990 View Post
GoPro 3 is also an option but to keep it constantly plugged in you have to drill the plastic case sacrificing water-proof qualities.
You can always get the skeleton frame to avoid this problem.
But if it's used only as a dash cam, water isn't an issue. The real issue with a GoPro is that it doesn't loop/record over itself. Imagine you went on a 2 hour drive and got in an accident... do you have to know how to edit video files to present evidence?
5 minute clips are a thing of beauty.
-alex
Old 04-03-2014, 05:38 PM   #22
HunterGreene
Hail Magnet
-alex
Only if you drive on conventional surfaces...
Old 04-03-2014, 06:03 PM   #23
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Does the ojo require a power cable at all times or is it just to recharge an internal battery?
Toyarzee is offline   Reply With Quote
Old 04-04-2014, 04:43 AM   #24
Ec1990
Drives: '14 BRZ
-alex
Actually with the Hero 3 you can loop record in intervals at your choosing.
Yeah the action frame would avoid that too.
Ec1990 is offline   Reply With Quote
The Following User Says Thank You to Ec1990 For This Useful Post:
mav1178 (04-04-2014)
Old 04-04-2014, 04:49 AM   #25
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I have this DVR and it is absolutely brilliant.
http://www.aliexpress.com/item/Best-...715941624.html
Ryan86 is offline   Reply With Quote
Old 04-04-2014, 11:53 PM   #26
Chimera
Drives: FRS
got the powerucc panorama 2
now if only my touchup paint would come in
Thanks for all the recommendations folks!
Old 04-10-2014, 06:19 AM   #27
KissMyAsphalt
KissMyAsphalt's Avatar
Drives: 2014 FR-S, Asphalt (obviously, lol)
I was thinking of getting something like this more or less..
[ame="http://www.amazon.com/Abeo-HDVR-150-Accident-Camera-Recorder/dp/B005GTKY24/ref=sr_1_10?ie=UTF8&qid=1397121297&sr=8-10&keywords=dash+cam"]http://www.amazon.com/Abeo-HDVR-150-Accident-Camera-Recorder/dp/B005GTKY24/ref=sr_1_10?ie=UTF8&qid=1397121297&sr=8-10&keywords=dash+cam[/ame]
But I have a general dash cam question: where do you guys recommend I plug it in so it's neat? The front dashboard only has that usb port, there's a cigarette lighter in the middle console but that just seems too far and awkward, and then there's the cigarette lighter in the glove box but I don't even know if it that's viable option.
KissMyAsphalt is offline   Reply With Quote
Old 04-10-2014, 09:26 AM   #28
jonzhuxD
Drives: Ultramarine FR-S
http://www.amazon.com/Abeo-HDVR-150-...words=dash+cam
Pull out your dome light from your headliner and reach in there towards the back of the car, there's an accessory plug that's for the auto dimming mirror, you can tap into that for accessory switched power.
jonzhuxD is offline   Reply With Quote
DYI Request, Removing dash board Stratoside DIY (Do-It-Yourself) Guides 11 05-15-2014 10:17 AM
[Request] Double DIN dash Mikeez Electronics | Audio | NAV | Infotainment 10 02-02-2014 02:32 AM
Request: Dash Cam install w/ pics of A-Pillar/headliner 1Cor10:23 DIY (Do-It-Yourself) Guides 13 01-16-2014 08:31 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 06:34 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
