Old 04-01-2014, 11:01 PM   #575
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
Question about Winjet Headlights
For you guys worried about fogging...some fogging during the first few days after installation is normal. If you do choose to bake the headlights to take them apart...about 200 deg for 8 min should do the trick. Get the 3m window weld to use for the new sealant (works better than silicon sealants). The 3m window weld has never leaked with my projects. For the guys wanting hids for their winjets...just get a set of hid bulbs and don't bother with a retrofit. Ive done retrofits before and believe it or not my winjets have great light output, aim and cutoff with hids and no retrofit.
beaver_scott is offline   Reply With Quote
The Following 2 Users Say Thank You to beaver_scott For This Useful Post:
86SPEED (04-02-2014), R.K (04-03-2014)
Old 04-01-2014, 11:05 PM   #576
beaver_scott
Size:  222.9 KBName:  ImageUploadedByTapatalk1396404305.735195.jpg
Size:  137.2 KBName:  ImageUploadedByTapatalk1396404326.735282.jpg
Size:  225.7 KBName:  ImageUploadedByTapatalk1396404341.868752.jpg
Old 04-01-2014, 11:06 PM   #577
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Hey @Midarete what did you do to make your LED light up with the projectors? Or is the shot taken with the high beams?
headlikeahole is offline   Reply With Quote
Old 04-01-2014, 11:10 PM   #578
Midarete
Midarete's Avatar
Drives: Whiteout FRS
That is with the highbeams on, but @fteightysix sells DRL mod for $50 where you can have the DRL on but dimmed while the headlights are running
Midarete is offline   Reply With Quote
Old 04-01-2014, 11:47 PM   #579
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Our mod does not dim the lights - they are not as bright as real 86 lights -
We tested these - they are bright but not bright enough to blind anyone
If needed we will work on a Dimmed design - and one specific for 10 series and Monograms
86SPEED is offline   Reply With Quote
Old 04-01-2014, 11:50 PM   #580
Midarete
Midarete's Avatar
Thought they dimmed them, if the mod doesn't dim them then would it be problematic to drive with the highbeams on?
Old 04-02-2014, 12:03 AM   #581
frskid
frskid's Avatar
Drives: 2013 Scion FR-S 6 MT Raven
I can't find that DRL mod
frskid is offline   Reply With Quote
Old 04-02-2014, 12:41 AM   #582
86SPEED
86SPEED's Avatar
No problems.
The high beam is in the projector. The DRL is seperate.
The Following User Says Thank You to 86SPEED For This Useful Post:
Midarete (04-02-2014)
Old 04-02-2014, 01:31 AM   #583
86SPEED
86SPEED's Avatar
http://www.fteightysix.com/whats-new.../#.UzuSMK1dVyE
Or just type "DRL" in the search bar
Old 04-02-2014, 01:44 AM   #584
86SPEED
86SPEED's Avatar
This is True - The winjet projector is very good (Way better than OE) - When we got the first set and tested them there is a major light output difference with different HID Bulbs - I will let @Gixxersixxerman comment more -
We have tested about 5-6 different bulbs and found that some compare well while others compare above and beyond -
There is a major light output difference in all the Retrofits we have done also - I have watched Thomas "tune them" to get a good crisp light output
@Gixxersixxerman
Old 04-02-2014, 09:22 AM   #585
STS-V
So the correct HID setup for these is H7?
STS-V is offline   Reply With Quote
Old 04-02-2014, 09:45 AM   #586
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Output Photos Please of the cutoff, real curious as to the cutoff
These are D2S projectors at 25 feet, how do yours compare?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
Old 04-02-2014, 03:42 PM   #587
86SPEED
86SPEED's Avatar
Correct - but we are saying the bulb honestly matters
Photos are worth 1000 words so........ photos coming soon
Old 04-02-2014, 04:27 PM   #588
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I'll post up what we did here in the shop
Stock winjet bulb and projector
Stock winjet projector with upgraded Morimoto XB35 5K bulb
Retrofitted Mini D2S projector running upgraded Morimoto XB35 D2S bulb
As you can see the stock projector doesn't come close to a retrofitted one. These are cheap Q5R replicas or knockoffs, while better then a OEM projector in the cars, and a lot better once they have a hid kit installed in them, they just don't come close to a retrofitted set.. I'll put my retrofitted setup against the shops 10 Series stock HID setup and know mine is better. I have "tuned" my set up and I run 185$ Osram 66240 CBI bulbs.. And Bulbs make a big difference.. Anyone that says a cheap 30$ kit bulb is the same as a quality ORM bulb or even the XB35 bulbs with the handmade German capsules don't know anything.. If your wanting the most out of your lights, then doing a retrofit is the way to go..
Gixxersixxerman is offline   Reply With Quote
The Following 2 Users Say Thank You to Gixxersixxerman For This Useful Post:
86-tundra (04-03-2014), Brody602 (04-04-2014)
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 11:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:26 PM
Winjet headlights fogging up? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 23 05-17-2014 02:26 PM
Has anyone modified the winjet headlights to keep led's on? 86black Cosmetic Modification (Interior/Exterior/Lighting) 0 01-24-2014 01:42 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 09:28 AM
