Old 03-26-2014, 08:51 PM   #1625
Kodename47
Kodename47's Avatar
Drives: UK GT86
Even if the sensor was inaccurate the ecu would not know so why doesn't it try to get AFR to 12.5 ?
It seems that the stock sensor loses accuracy richer than 12.5-13. As you're N/A you could create a map to run safely at 12.6/12.7 to dial in the MAF before running desirable ratios, just dial back some advance while doing so.
You seem to be missing how open loop fuelling works mate. It doesn't look to see how the end result compares to the O2 sensor, as far as the ECU is concerned it doesn't exist in open loop. It does a calculation based on the air intake in g/s and calculates the fuel needed to hit the AFR in the fuel table. The LTFT is set by consistent STFTs occurring and those only happens in CL operation.
Here's an OL example:
At 5000rpm the MAF is outputting 3.6v, the MAF scale shows this as 90g/s. The ECU then looks at the target AFR and calculates that x amount of fuel is required to hit the target AFR basedon 90g/s of air and then adds the LTFT on top.
If you now change 3.6v to 100g/s the ECU will now assume more air is entering the engine and to continue to make the target AFR more fuel is required, so the resultant AFR will become richer. If the ECU still has a similar LTFT due to the CL operation it will still add this on top, potentially making it even richer.
This is why ensuring that areas of CL to OL operation are scasled well on the MAF. The car I've done recently has 0 LTFT everywhere and I haven't disabled them or moved the WOT area out of the area of correction learning, although I probably will in the long term.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-26-2014, 09:07 PM   #1626
steve99
Drives: FT86
Thanks, that makes more sense. There is heaps on info on maf scaling but all seem to be "tools" that do it for you and not much on how its actually achieves it.
Its starting to sink in now
Old 03-27-2014, 12:02 AM   #1627
troek
troek's Avatar
Drives: 2012 Toyota 86
This is some great reading, thanks guys!
troek is offline   Reply With Quote
Old 03-27-2014, 02:48 AM   #1628
nelsmar
I'll just place this here... Mind you my LM2 has an extra latency over AFR which has latency over equivalence ratio...
It is not always this consistent but it is more often than people seem to be suggesting.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
Kodename47 (03-27-2014)
Old 03-28-2014, 06:03 PM   #1629
Lytheum
Drives: 2013 BRZ Premium 6MT
new log with modified snorkel! got bored today and hacked it up lol.
http://www.datazap.me/u/lytheum/3281...ata=1-5-6-7-11
i think im done tinkering stuff on the car so now its time to start tinkering with the tune. any thoughts on how the OTS tune is looking? @shiv@vishnu ?
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 03-28-2014, 11:39 PM   #1630
nelsmar
Just at quick glance I would start with adjusting your maf. after 2.9v you seem 3-5% too rich across the board. I would drop the g/s on the maf chart a few % and taper it closer to 1% off near 3.2v to start. Best to make minor changes rather than drastic. Just take out a calculator and do the math based off of how much your AFR is off from current vs your fuel trim compensation. Just adjust slightly short of your math as to not over shoot.
Lytheum (03-29-2014)
Old 03-29-2014, 04:11 PM   #1631
stevo585
Drives: White 2014 BRZ
To temporarily change subject:
Do you guys think the stage II EL flash could be ran with a gutted cat stock header? Anyone tried this yet? I'm still not convinced the stock header design is all that bad but rather restricted by the cat.
stevo585 is offline   Reply With Quote
Old 03-29-2014, 05:08 PM   #1632
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
That's the tune I would use.
- AdrianG
AdrianG is offline   Reply With Quote
Old 03-30-2014, 01:57 AM   #1633
phrosty
I modified 1.58 Stage 1 700D with the MAF table for my Perrin 2.75" CAI. Also have a P&L catback. Here's a 3rd gear pull — how does it look?
http://datazap.me/u/phrosty/oft-stag...=0&data=1-9-11
phrosty is offline   Reply With Quote
Old 03-30-2014, 03:46 AM   #1634
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why didn't you use the A01D or B01D ROM? IMO try and use the latest ROM available that's compatible.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-30-2014, 04:13 AM   #1635
phrosty
My base ROM is 700D. OFT only lets you upload the same as your base.
Old 03-30-2014, 06:38 PM   #1636
uncivilised
Drives: 86 GT
ive been logging my e85 tune on my stock 86 using the latest OFT stg2 EL e85 tune.
so far it has stable afr between low 12s and mid 11 through out the rev range, IAM pegged at 1 and stable kc learned value.
my question is that i have a 4-1 catless EL header going on, will the tune re-learn for the header or will i need to reflash again?
my last log http://www.datazap.me/u/uncivilised/lol2-0
uncivilised is offline   Reply With Quote
Old 03-30-2014, 10:28 PM   #1637
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I don't think you'll need to reflash necessarily, but with any big change like that, it's good to reset the ECU. This can be done by pulling the negative battery cable for a few minutes.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
uncivilised (03-31-2014)
Old 03-31-2014, 03:39 AM   #1638
Kodename47
Kodename47's Avatar
Drives: UK GT86
Does the OFT not have qan ECU reset function?
.: Stealth 86 :.
Kodename 47 DJ:
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
