Old 03-20-2014, 04:52 PM   #71
Victor Draken
Drives: Toyota Gt86
Various Pulls STG1 OTS after 400kms 100RON (EU)
Mods: Blitz Drop-In Filter
Victor Draken is offline   Reply With Quote
The Following 2 Users Say Thank You to Victor Draken For This Useful Post:
TIE Pilot (03-20-2014), wparsons (03-20-2014)
Old 03-20-2014, 05:17 PM   #72
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Just so you know, you can save the graph directly as an image so that you do not have to take a screenshot of it. Much easier.
Luckrider is offline   Reply With Quote
Old 03-20-2014, 05:35 PM   #73
Victor Draken
Drives: Toyota Gt86
Lol yeah. I even knew it... Just forgot it ahaha.
Thanks Anyway!
Old 03-22-2014, 12:23 AM   #74
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Very surprised you guys are getting wheel spin at over 60mph....
Are these logs taken on stock tires on a cold day? As far as if it's tc or clutch I'd try the run with tc in sport or all off and see if it changes.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-22-2014, 11:26 AM   #75
Luckrider
Luckrider's Avatar
I am assuming you are talking about me. I am currently running 215/45r17 General Altimax tires and the logs were taken in sub 40 degree weather that was wet. Honestly, I think it was closer to 20 degrees. I got my new tires in and it is finally get a bit warmer so I will be able to swap to my new wheel setup. 17x8 OZ Anthricite Alleggerita HLTs with 245/40r17. Total weight is 2lbs less than stock and should have way more grip to eliminate the possibility of slip.
Edit: Forgot to say that this is with the TC totally off.
Old 03-22-2014, 11:32 AM   #76
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Here is my VD stuff. This is a comparison of the average of several logs from last summer with perrin header back and Ecutek stg 1 vs. OFH, Perrin header back and OFT stg 2 logs I have taken over the last week. Both are using 94oct gas and have been corrected for atmospheric pressure, tire diameter and air temp. Same car, same road.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 2 Users Say Thank You to Apoc For This Useful Post:
Shiv@Openflash (03-22-2014), Wepeel (05-16-2014)
Old 03-25-2014, 11:45 PM   #77
Luckrider
Luckrider's Avatar
Does anyone know why I am having this problem? You can clearly see the RPM range of the logs by looking at the left where it shows the information used to generate the graphs.
Old 03-25-2014, 11:58 PM   #78
DriftHappens
Drives: '14 FRS White
double check to make sure the throttle position reads >92% (i think someone stated that was the cutoff), I always set it to 100% anyway to be sure.
DriftHappens is offline   Reply With Quote
The Following User Says Thank You to DriftHappens For This Useful Post:
solidONE (03-26-2014)
Old 03-26-2014, 01:06 AM   #79
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'm pretty sure this is what causing the problem. I just put the entire log to 99% throttle position, since usually it reads 9x.xx%. I just go over the second digit down the entire log and change to 9 on all of them.
Old 03-26-2014, 02:17 AM   #80
DriftHappens
Yeah, that one took me a bit to figure out. haha. "Why the F*** is it stopping at 4k!?!?!" Good times.
Old 03-26-2014, 08:55 AM   #81
Luckrider
Luckrider's Avatar
How are you guys doing this efficiently?
Old 03-26-2014, 11:42 AM   #82
wparsons
wparsons's Avatar
I was talking to the guy that wrote VirtualDyno, and it's not actually a fixed value. It just takes everything within ~5% of the max value as WOT. In our case max seems to be around 97-98%, so the 92% is the value that cuts us off, I just take any value that should be WOT and make it 100% before importing the log and it works fine every time.
flickr
DriftHappens (03-26-2014)
Old 03-26-2014, 12:04 PM   #83
Luckrider
Luckrider's Avatar
Are you guys manually changing the throttle position one value at a time?
Old 03-26-2014, 02:37 PM   #84
wparsons
wparsons's Avatar
Just open it in excel and set the first value you want to change to 100, highlight all the values in that column you want to change and press ctrl + D to set all highlighted values to 100.
flickr
Data Logs! Post them here. feldy Software Tuning 2162 Today 07:09 AM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 07:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
