Old 03-25-2014, 11:04 PM   #1
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
the future of track day tires
welcome to the future ladies and gentlemen.
http://www.cambertire.com/
these are awesome. Saw them a few years back, but I think they have been under everyone's radar.
Old 03-25-2014, 11:06 PM   #2
fourvalleys
Howdy!
fourvalleys's Avatar
Drives: Party ST, Classic Mini
I wonder how this affects toe. A conical tire (with smaller diameter on the inner sidewall than the outer sidewall) will not itself roll in a straight line. Maybe the effects are negligible but I've always been curious to see how that works.
fourvalleys is offline   Reply With Quote
Old 03-25-2014, 11:15 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I think the tire is meant for a suspension that has a certain degree of camber on it already, then slap on these tires and all of a sudden you have full tire contact 24/7, instead of not just in the twisties.
I remember seeing a video of these on a semi tuned Evo 8, and the comparison was surprisingly shocking. These tires were seconds faster around a track than a regular R compound was.
Old 03-25-2014, 11:39 PM   #4
sshole
It's hardly new, but it is kinda vaporware. I don't think I've ever seen anyone running these tires in real life.
sshole is offline   Reply With Quote
Old 03-26-2014, 03:14 AM   #5
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
It's a cool idea, but seems like you would need some major toe changes if you swapped back and forth between regular tires and these camber tires. I'm guessing you would want these on your car and aligned before going to the track.
Wonder what the steel radials look like under the rubber.
OjiGeorge is offline   Reply With Quote
Old 03-26-2014, 11:49 AM   #6
wparsons
wparsons's Avatar
Unless the outer sidewall is super soft and allows the contact patch to stay flat as cornering loads build, these are just as bad as running 0 camber on any other tire. If these have a stiff outer sidewall, they'll roll over just like any other sticky tire with too little camber.
The whole point of increased camber is to keep the contact patch flat in a corner as the car rolls and suspension loads.
How would these affect toe settings? Toe is set at the knuckle, not the tire, and since these sit square on the tire in the rotational axis toe won't be any different.
flickr
Old 03-26-2014, 11:51 AM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The future of track day tires mounted on a Rota wheel on the front page. Looks good.
wparsons (03-26-2014)
Old 03-26-2014, 11:54 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
too bad they're not actually fast :/
The Following User Says Thank You to 7thgear For This Useful Post:
Old 03-26-2014, 12:07 PM   #9
Crazy Drew
Drives: Smells like tires when I drive
/\ This. With this tire you'll still wear out the outside tread first. This tire shouldn't be marketed towards racers but instead the "stanced" crowd. Or, these tires need to be mounted in reverse of how the pictures are showing it so that you can run zero to a couple degrees of camber and the smaller (then outside) sidewall accounts for the needed camber when racing.
Crazy Drew is offline   Reply With Quote
The Following User Says Thank You to Crazy Drew For This Useful Post:
Old 03-26-2014, 12:17 PM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
[ame="https://www.youtube.com/watch?v=Z5bT4hJ4B6M"]https://www.youtube.com/watch?v=Z5bT4hJ4B6M[/ame]
Old 03-26-2014, 12:26 PM   #11
fourvalleys
Howdy!
I don't actually mean toe settings. That's probably not the right way to describe it. If your car is driving straight on conical-shaped tires, the front of each tire will push towards the center of the car. That's the nature of it when the inside and outside circumference are different.
My question is just how severe this force will be, especially at speed. Maybe not much, but it will exist and I don't think there's any way to avoid it.
The Following User Says Thank You to fourvalleys For This Useful Post:
OjiGeorge (03-26-2014)
Old 03-26-2014, 02:58 PM   #12
wparsons
wparsons's Avatar
I'd love to see actual hard numbers, not just seat of the pants observations. I can't find much online, but this doesn't seem to support the benefit in any way.
Originally Posted by fourvalleys View Post
I don't actually mean toe settings. That's probably not the right way to describe it. If your car is driving straight on conical-shaped wheels, the front of each tire will push towards the center of the car. That's the nature of it when the inside and outside circumference are different.
Gotcha, and agreed. It might be a small enough difference to not be too noticeable, but they would definitely want to roll towards the center of the car.
flickr
Widest Track tires for stock wheels?? track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 10-11-2015 12:01 PM
FS: go fast track tires for your FR-S! l8apexr Canada Classifieds 2 10-02-2013 07:28 AM
When to replace street tires used for the track? ayau Tracking / Autocross / HPDE / Drifting 4 07-23-2013 12:45 PM
Hankook Future of Tires video Asphalt~86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-25-2012 10:32 PM
track day tires that will fit inside dabguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-25-2012 05:08 PM
