#379 |
Drives: FT86
That pretty much sums up what I was experiencing. will be interesting to see your logs.
#380 |
Drives: WRB BRZ
Hey guys, I'm running 1.56b stage 2 UEL with my OFH/Invidia OP/Stock FP/Q300.
I decided to take a log and try out the new channels available (I logged the first 100 miles after installing stage 2, it looked great). So I logged my commute to work this morning. IAM started out at one, which I expected. When I got to work I noticed that IAM had dropped to .55! This was rather unexpected. I'll post a link to the log. Looks like I had three episodes of knock correction. Is this the light load knock that is being talked about? I've never messed with Romraider, as I had been pleased with the logs upto this point, but I'm willing to give it a shot to correct the knock issue. Here's a third gear pull, looks pretty good IMHO: http://www.datazap.me/u/vmax911/long...om=10534-10724 This should be the entire log: http://www.datazap.me/u/vmax911/long...=0&data=1-9-12 Any comments would be great! |
#381 | |
Drives: frs
Maybe you should let your oil warm up more before revving to 7k. I heard high revs with colder oil isn't a good idea. Anyone have thoughts on this? About how warm should the oil get before redline pulls? Last edited by gonzo; 03-19-2014 at 11:02 PM. |
| The Following User Says Thank You to gonzo For This Useful Post: | 8686 (03-20-2014) |
#382 | |
Drives: FT86
Either run better fuel or you will need to pull a bit of timing in the knock prone rpm/load cells where it occur's. I have the same issues with this tune on 98 (your 93) and even 100 RON (your 94) due to differences in fuel formulation over here. Same thing would happen on stock tune its meant to run 93 (98 RON) for best results. I have had good results after pulling a bit of timing. ie no IAM drop and much reduced occurrences and severity of knock in 2000-3500 rpm range. |
| The Following User Says Thank You to steve99 For This Useful Post: | DAEMANO (03-20-2014) |
#383 | |
Drives: WRB BRZ
#384 | |
Drives: FT86
here is what I did , note I am in Oz and out fuel is different so you may have to work in it a bit. see link below http://www.ft86club.com/forums/showp...0&postcount=64 Table is knock correction max A or you could pull it from Base timing B, however I used knock correction max A table First screen shot show "delta" or changes second one is actual table after changes. You really need to log RPM Knock correction (FBCK) Engine load Note the RPM and load where the Knock correction occur regularly. The IAM will drop as a result of repeated or severe knock noted in FBCK. This will occurr some time after the knock events. Once IAM has dropped it takes quite a while to recover, will not recover if severe knock events continue. you can generally get IAM to recover with sone easy pulls to over 4000 rpm as long as no further knock events occur. Don't worry to much about small values of knock correction such as -0.3 but if you see -1 or more its worth pulling 0.35 degrees at that RPM/load point. Watch for the knock events where the IAM drops shortly afterwards. The area thats the problem is generally 2000-3500 rpm load between 0.6 and 1.2 As your on 91 you may have to pull a bit more than I did maybe 0.7 if you seeing corrections over -2 . flash it and test, it may take a few attempts. Last edited by steve99; 03-20-2014 at 02:39 AM. |
| The Following 7 Users Say Thank You to steve99 For This Useful Post: | Boofneenee (03-20-2014), DAEMANO (03-20-2014), gonzo (03-24-2014), Gums (03-20-2014), Shiv@Openflash (03-20-2014), Vmax911 (03-20-2014), WRB5titch (03-20-2014) |
#385 | |
Drives: UK GT86
I log FLKC too as this can also highlight areas that don't turn up by logging FBKC. The knock event is also usually the row before the actual knock that has been logged and I will pull 0.35 in the cells surrounding the "prone" cell due to the way the ECU is interpolating as the load ramps up. Eg, if the knock even looks like it's happening at 2300 rpm within the 0.52 load range, I'll pull 0.35 deg between 2300 and 2400 in load ranges 0.4-0.6.
.: Stealth 86 :.
#386 | |
Drives: FT86
Was wondering if ecu averaged/interpolated values now have answer thanks |
#387 |
Drives: WRB BRZ
Thanks @steve99
Can anyone explain the difference between base timing table A and Table B? And how does knock correction max A interact with them? And yes, I'm using OFT. |
#388 | |
Should be a fun weekend of driving
#389 | |
Drives: UK GT86
The ignition advance table is added to the base timing. The amount is determined by the IAM and FLKC. Google RomRaider IAM and it's there in detail as to how the system works.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Vmax911 (03-20-2014) |
#390 |
Drives: Toyota Gt86
http://www.datazap.me/u/victor-drake...0&data=1-2-4-7
4 3rd gear pulls and quite a bit of driving in traffic. stg1 1.56 after 400km on 100RON fuel (EU). Only mods: Blitz drop in filter. how is it? @shiv@vishnu @nelsmar |
#391 | |
Drives: WRB BRZ
#392 |
Drives: FT86
Yes , but there are also other ignition timing compensations for IAT "Intake air temp and coolant temp and Air conditioner on/off ect probably some other to.
| The Following User Says Thank You to steve99 For This Useful Post: | gonzo (03-24-2014) |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 12:12 PM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 01:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 10:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 01:10 AM |
