Old 06-22-2010, 11:51 PM   #113
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
^ That's why ppl use full stand-alone or sub-ecu and leave the main ecu alone. I'm praying that Cuz of this, Subie's ecu won't be hard to crack from 2011~
Old 06-23-2010, 12:01 AM   #114
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by nate89 View Post
The only concern I have is that if toyota doesn't release a turbo version, then it could be fairly hard to turbo unless you run a full stand alone. Toyota sucks when it comes to making their car (at least recent ones anyway) tunable. If it comes turbo, then upgrading the turbo and stuff should be no problem. It's when you try to add a turbo that things get messy. Toyota really needs to make their ecu's flash-able, if only for this car. Hopefully since Toyota is using a Subaru engine, Subaru will also help develop the ECU. Does anyone know anything about the ECU?
Side note: A EJ20H (twin turbo) would be pretty sweet!
EJ20H = Valley of Death. There's a reason they stay in Legacies and aren't a common swap.
As for standalone's, no big deal. May have to wait a bit for a plug and play unit but it won't be too bad. For example, a P&P Haltech Platinum Sport 2000 for my car is $1900 installed with a base tune. It's the rest of the turbo install that may be a pain, strictly from a packaging/fabrication standpoint.
I'm still worried about the strength of this new transmission.
Old 06-23-2010, 12:16 AM   #115
nate89
nate89's Avatar
Drives: MR2
Looks like I have some reading up to do about Subaru engines lol. I'm not to familiar with Subarus.
Aren't Subaru's fairly easy to tune using the stock ecu. The transmission is another area of concern. I know the wrx transmissions have been known to be weak whereas the sti transmissions are better and ca handle more power.
nate89 is offline   Reply With Quote
Old 06-23-2010, 12:26 AM   #116
Dimman
Kuruma Otaku
Dimman's Avatar
The EJ20H uses a sequential twin-turbo setup. First one spools, then the other. The Mk4 twin turbo Supras use a similar system. On the Supra, as the first one approaches its set boost, the sequential system begins to 'pre-spool' the second turbo so that by the time the first one is at full, the second one is smoothly continuing. (Rough explanation). The EJ20H uses the same idea, but apparently not as smoothly, and I've heard of a lot of complaints of a dead spot from lag at the transition from 1 to 2 turbo operation. They call it the Valley of Death. It may be over-dramatized, but the EJ20H doesn't seem to make it into swapped Imprezas.
An advantage the transmission will have is not having AWD that will be trying to break it on hard launches. Wheelspin will be the fuse, at least for a stock car. But if this car comes out NA and with no plans for a turbo (god forbid...) the transmission (and diff) may end up being the weak link, even if you boost the motor yourself.
Old 06-23-2010, 12:44 AM   #117
ichitaka05
Site Moderator
ichitaka05's Avatar
Like I said, tranny will be built by Aisin AI. Some of the JDM FR companies uses them (Nissan, Mazda, Toyota, Mitsubishi) and GM too. Tranny gonna be the least of my worry
Old 06-23-2010, 02:00 AM   #118
Dimman
Kuruma Otaku
Dimman's Avatar
It depends on the purpose of the tranny. Twin Turbo Supra got the V160/161. This was the transmission of the gods. NA got the W58. Not known to handle much more than 50% over stock torque.
If this car is destined to be a NA only 2.0L there is no reason for Toyota or Subaru to ask Aisin to build it to take more than 200 lb-ft, there is no reason for it to be super strong.
I'm just throwing out worst case scenarios, so we'll all be that much happier when the 305 hp, bulletproof 6 speed, 2.5L Turbo Sti/TRD, easily tuned with a Cobb Accessport, version comes out. (pleaaaaase...)
Old 06-23-2010, 02:01 AM   #119
Matador
hashiryu
Drives: Mk4 Supra
That's the thousand ft/lb question
Matador is offline   Reply With Quote
Old 06-23-2010, 02:29 AM   #120
ichitaka05
Site Moderator
ichitaka05's Avatar
Don't forget, it's gonna be 6sp. I don't know much NA engine w 6sp tranny that is weak.
Old 06-23-2010, 03:44 AM   #121
nate89
nate89's Avatar
Drives: MR2
Thanks for the info! I was thinking it was a parallel setup? Learn something new right?
The MOTHER-LOAD! (...time to come back down to earth lol)
Old 06-23-2010, 03:53 AM   #122
70NYD
70NYD's Avatar
Drives: RX8 S1
Originally Posted by MatadorRacing_F1 View Post
How about you stop talking shit? Your "Opinion" does not define what a sports car is. This is why Mustangs, Holdens and Falcons are generally called "muscle cars" and not sports cars. They miss the most essential component of a sports car; handling.
Everybody knows the MR-S came with a piss weak engine from the factory. So does the Miata. A powerful engine does not a sports car make. In either case, the power is a turbo or a 2ZZ swap away.
anyway.. back on topic. Anybody stop to think that FR-S might be for another car that can drop the top?
agreed about the holdens and falcons, never drove a mustang but whatever. yeah il stop talking shit, this opinion comes from me not liking that car in general (aesthetically) and i realise that other ppl dont share my opinion. so i promise to stop hating on the mrs
70NYD is offline   Reply With Quote
Old 06-23-2010, 07:58 AM   #123
CyberFormula
CyberFormula's Avatar
Drives: gti, nsx, integra type r,porsche911
i would much rather have the JDM 2.0 sti engine than the 2.5
and as far as power goes, if it comes factory 270hp....its already pretty impressive for me. No need for 300hp/300tq.
CyberFormula is offline   Reply With Quote
Old 06-23-2010, 02:17 PM   #124
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I'm probably going to debadge and rebadge the car once I get it . . . FR-S is odd.
blur is offline   Reply With Quote
Old 06-23-2010, 11:07 PM   #125
Dimman
Kuruma Otaku
Dimman's Avatar
But torque is delicious. Mmmmm... torque...
Old 06-24-2010, 02:04 PM   #126
DrunkenMime
Drives: IS300
I'm almost positive they'll call this car something cool in Japan. They don't really use the alpha-numeric names over there too much...ie: Sylvia vs 240SX, Fairlady Z vs. 300ZX or 350ZX, Integra vs. RSX, Trueno/Levine vs. Corolla GT-S, etc, etc...so we can debadge ours and get JDM badges to put on the car...that's what I did to my IS
DrunkenMime is offline   Reply With Quote
Toyota FT-86 G's Sport Concept moved to Toyota Mega Web showroom at Odaiba Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 23 05-02-2011 02:11 AM
Toyota FT-86 G-Sport Concept car displayed with AE86 at Toyota Amlux, Tokyo Kenji FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 03-09-2010 12:09 AM
Video del Toyota FT-86 Concept Axel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 03-04-2010 06:06 AM
FT-86 convertible under consideration according to Toyota official! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 88 01-03-2010 05:07 PM
