#43 |
Resident Post Whore
Drives: 2022 WR BRZ
Gavin
#44 | |
BRZerhood Lurker #13
Drives: 15 DGM BRZ Premium
There really seems to be a big divide forming on these forums between the old school AE86 people and everyone else. It will be interesting to see how things develop the more info we learn about the car. |
#45 | |
Resident Post Whore
Drives: 2022 WR BRZ
Gavin
#46 | |
Drives: SW20 MR2, bugeye WRX
I look forward to Subaru owners digging into this car. It will be like an Easter egg hunt. They'll be unbolting parts just to see if they can. If the car still drives...the part stays in the garage! Who needs those army green fuel injectors covers anyway. ![]() I think Subaru owners will love the bigger wheel wells on this car as well. No more searching for an extra mm with camber bolts, camber plates, adjustable lower links, rolled & pulled fenders...unless you want tires wider than 245's. Just bolt them on and be happy. I'm hoping they left plenty of room in the rear for at least 275's and took care of any offset related bearing issues. If the rear diff is an R180, I think the Toybaru is in for trouble. Let's hope it is a beefy Toyota/Lexus rear end. If I get one of these cars, the first mod I'd look into would be polyurethane steering rack bushings. Best bang for the book on my MR2 and WRX. |
#47 |
Drives: MX5 Miata Mk2.5 1.6
Even though its too soon, I am thinking about smaller diameter wheels (16'' if 17''s are stock), some removal of not useful stuff like I did to my MX5 (I saved about 1000 lbs from its stock weight). Then, maybe I'll try a different setup with a set of sways.
#48 |
Drives: yaris
you should look into Braille batteries, they are 6-10 lbs in relatively affordable prices.
http://www.braillebattery.com/ |
#49 |
86 Enthusiast
Drives: Yaris LB 5MT
I'm gonna keep mine stock. I don't see too much of a reason to upgrade much.
RWD? Check. 6spmt? Check. LSD? Check. Good Suspension? Check. Nope, my checklist is complete! Is anyone planning on a 4age swap? I know there has to be.. |
#50 | |
or for someone looking to go even further... http://www.voltphreaks.com/products.php |
#51 |
Resident Post Whore
Drives: 2022 WR BRZ
To each his own. That's what makes this so wonderful. There are always folks that don't want to upgrade anything. People do the same with the S2000. Things can always be upgraded from factory though. Just imo.
Gavin
#52 | |
Drives: 2004 STI
#53 |
Resident Post Whore
Drives: 2022 WR BRZ
Gavin
#54 | |
#55 |
Drives: 2001 2.5RS 4Dr 5MT
Just a UEL header
#56 |
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
if i end up purchasing one of these, i will likely keep the mod list VERY short. i have my MR2 to go nuts on.
![]() -brake pads: i like Porterfield R4-S pads -short throw shifter: probably TRD -tint: maybe 35% all around, nothing too dark -factory/TRD exhaust upgrade option if there is one -stickier tires since i imagine there will be all-seasons from the factory: i like Toyo T1R's depending on what some drivetrain parts are, i might want to change a couple other items. -if they put a dual-mass flywheel in, i will pull that out and get an aluminum flywheel -i REALLY hope they don't put an accumulator in the clutch hydraulic system; if they do, i will need to figure out a way to remove it. i want a VERY direct clutch -LSD if there's no factory option for it i really think these simple mods could take a very fun factory car and make it just that much crisper. -Mike
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs 1990 240SX Coupe - sold 2008 Civic Si Sedan |
