Old 03-18-2014, 05:41 PM   #421
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
If I understand you correctly it sounds like Perrin is using the stock sized donut. If thats the case its smaller than 2.5" Last time we checked we had our 2.5" front pipe with the bigger ID donut gasket and it fit in the OEM catback. The OD should be the same but with a bigger ID to accept the bigger 2.5" pipe
Can you snap some pics if you get a change
JDLAutoDesign is offline   Reply With Quote
Old 03-18-2014, 06:00 PM   #422
transition
Your quote described it exactly. Factory donut gasket appears to be 2.25" ID, i need a gasket with a 2.5" ID to fit the front pipe. Since JDL does not sell or provide gaskets i'm trying to find out what gasket will fit.
transition is offline   Reply With Quote
Old 03-18-2014, 06:01 PM   #423
JDLAutoDesign
Drives: 13 FRS
Your front pipe should have a donut gasket. Was it not in the box? Its usually placed on the end of the front pipe. If not we can send you one out.
Old 03-18-2014, 06:08 PM   #424
transition
Nope not in the box. Just triple checked and there was no paperwork, gaskets, bolts or anything provided with my header, over pipe and front pipe. Unfortunately my car is tore apart and i can't wait for shipping. Any idea of factory gaskets that might fit?
Old 03-18-2014, 06:10 PM   #425
JDLAutoDesign
Drives: 13 FRS
It will not fit. PM t me your order # and ill get them sent. You can run the OEM front pipe until you get the gaskets. Its an easy swap
Old 03-18-2014, 06:33 PM   #426
Ryan P
Run open header for a week. Just do it
Sent from my SPH-L710 using Tapatalk
Ryan P is offline   Reply With Quote
The Following 2 Users Say Thank You to Ryan P For This Useful Post:
Bonks86 (03-18-2014), nelsmar (03-18-2014)
Old 03-18-2014, 07:00 PM   #427
scionsalesjay
scionsalesjay's Avatar
Drives: 13' MT FR-S Innovate Stage 2
Originally Posted by Jesse@JDLAutodesign View Post
Thank you! We have 2 coated ones coming back in the next day or so instock. We will have uncoated ones by the end of the week in stock. I prefer the UEL over the EL in just about any application just by the sound alone. Let me know if you have any other questins!
Ordered the black coated UELs! Thanks for the help!
View my FR-S Build
Innovate Supercharger w/ Intercooler
My members journal: http://www.ft86club.com/forums/showthread.php?t=58728
Subscribe to TuneCast: https://www.youtube.com/watch?v=1vUWK0GqB_Q
scionsalesjay is offline   Reply With Quote
The Following User Says Thank You to scionsalesjay For This Useful Post:
Jesse@JDLAutodesign (03-18-2014)
Old 03-18-2014, 07:36 PM   #428
Blood
Drives: 2018 STI
Originally Posted by transition View Post
Got the headers installed and the overpipe in. Just starting the front pipe installation although i'm noticing the side the connects to my Perrin catback (where the donut gasket goes) the OD of the front pipe where the donut gasket goes is bigger then donut ID. What donut gasket am i supposed to use here?
There should have been a 2.5" gasket included in the installation hardware of your Perrin catback. You use that gasket instead of the donut gasket to connect the front pipe to the midpipe, even with a stock front pipe.
Blood is offline   Reply With Quote
Old 03-18-2014, 07:43 PM   #429
transition
Perrin does not include a 2.5" gasket they provided a 2.25" gasket. If you want proof i can show you the gasket they provided that does not fit the 2.5" OD of JDL's pipe.
Old 03-18-2014, 07:47 PM   #430
transition
I found that a Japanese 2002 Honda CRV uses the correct size donut gasket and picked up one of those. $30.00 down the drain.
My problem now is the front pipe does not fit at all to the over pipe. Headers bolted up and torque'd to spec, put the overpipe on and left it finger tight so i could still get a little wiggle room there, the problem seems to be the bracket welded mid-way on the front-pipe doesn't allow me to position the pipe properly. Would really help if JDL had some type of instructions/guide to ensure people like me are doing things properly. Suggestions?
Edit: Here's the problem. The bracket welded the front pipe literally has to be forced over the bracket on the car. It requires force to put on then has extremely limited mobility once mounted. The factory bracket is much larger allowing for wiggle room and adjustability. How am i supposed to fix this?
Old 03-18-2014, 07:52 PM   #431
Blood
Drives: 2018 STI
I stand corrected. It is indeed a 2.25" gasket.
JDL's front pipe is advertised as 2.5" though. Is the piping thinner than the piping on Perrin's catback, or is it 2.5" inner diameter?
Old 03-18-2014, 07:55 PM   #432
transition
JDL is 2.5" off the front pipe vs. stock which is 2.25"
Old 03-18-2014, 09:00 PM   #433
transition
Ok so here's the problem for the record. Awaiting response from JDL since there is absolutely no way the front pipe will fit. Also confirmed with another customer the same exact issue on their front pipe.
The Following User Says Thank You to transition For This Useful Post:
xDanger_208x (03-18-2014)
Old 03-18-2014, 09:06 PM   #434
JDLAutoDesign
Drives: 13 FRS
Did you try to the bracket on the mount with the front and rear loosen. Everything needs to be loose then tightened. Our brackets are not the same dimensions/size OEM just use the mounting point.
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 08:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 09:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
