Old 03-17-2014, 09:51 PM   #505
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by glorydays View Post
So... is this option ready to use for the average noob or is this still a developer only type of deal... OR is it one of those "if you have to ask" type of situations?
I'm in the same boat as you.
Chad86 is offline   Reply With Quote
Old 03-17-2014, 09:51 PM   #506
Chad86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by mad_sb View Post
It's one of those "if you have to ask" for the moment, but it won't be long before it's ready for the masses
How much longer until anyone can get this done easily for performance upgrade?
Old 03-17-2014, 10:23 PM   #507
steve99
Drives: FT86
Originally Posted by Chad86 View Post
Are there any videos on this? And basically how is it changing the car's computer to get the extra performance? I'm a tech guy, but new to ECU flashing technology and wanting to get into more performance modding instead of just appearance ONLY
The tactrix adapter is an interface between the car obd-2 port and your computers usb port.
The Ecuflash software allows you to read your car ECU ROM via the tactrix adapter and save it, edit it then reflash it to the car
If you have the definition files for the ROM (table structure) then you can use ECUflash software to modify fueling ignition timing and many other tables to increase the performance and drivability of your stock car.
Do not expect huge gains on a stock N/A car maybe 10hp
If you have other mods headers intakes ect you can change tables/parameters to suit these mods and possibly pick up maybe 20hp over an untuned car
retune for e85 maybe 30hp
Any re-tuning even on a non turbo/supercharged car (ie N/A) requires much knowledge and skill , time and patience and the ability to interpret engine parameter logs.
The ecuflash software will not "tune" your car for you.
99% of people will require a source of pre tuned ROM's, and at best may be able to fiddle with the odd table to tidy something up.
note I am in the 99%
I have a tactrix as a backup to my Open flash tablet
Tectrix/openflash is working at present for read/write/edit but logging still a work in progress as I understand it. It works but limited access to rAM addresses for parameter logging, depending on your rom type.
Old 03-21-2014, 05:16 AM   #508
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
What is left as far as logging goes? Specifically a and b series usdm mt roms....
Hoping for a rough estimate for when I can get my car tuned.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 03-21-2014, 05:29 AM   #509
steve99
Drives: FT86
The logging works fine, been using it for a while.
Just install a SD mini card in tactrix adapter and have a suitable logcfg file in the root directory and your good to go.
If your on C or G series rom their are a couple of logcfg files posted a couple of pages back.
You only need to have the same ROM series ie C or G , revisions loke A01 BO1 700 are compatable just the last letter is significant.
Unfortunatly for other ROM types i dont have memory addresses. The logcfg file is just text.
Old 03-21-2014, 07:33 AM   #510
StormTrooper
Meaning flkc, iam, afr targets, Load, fueling, pulse widths ect????
Are they still in beta or alpha stage?
GR86 MT premium
Old 03-21-2014, 09:25 AM   #511
steve99
Drives: FT86
If you make a text file containing the text below the ******* and call it "logcfg.txt" and have it in root directory of SD card in tactrix it will log the parameters this is for C series USA ROM
anything with a ; at start of line is comment or commented out
It will create a csv file on the sd card , new one each time logging starts
Starts when rpm not 0 and stops when rpm goes to 0.
Mate don't know about alpha beta, its open source. no guarantees its use at your own risk stuff.
If you want something more user friendly with safeguards to stop writing wrong ROM,s and with support and backup I would suggest you look at OFT, Ecutek or a tuner. not being nasty it just the way it is.
If you want more parameters you will have to beg/borrow/ask on here and or Romraider/ecuflash forums. only the guru's dissassembling code can dig these out.
I personally have OFT and use tactrix as a backup device and for faster logging/flashing but if it all goes pear shaped I have the oft as a fallback or comparision device.
type = obd
protocolid = 6 ; ISO15765
mode23txaddrwidth = 4 ; mode23 req format info
mode23txlenwidth = 1 ; mode23 req format info
mode23rxaddrwidth = 0 ; mode23 req format info
mode23uds = 1 ; lets OBD channels know you are using mode23 UDS
sortpids = 1 ; sort these PIDs by value to potentially make for fewer requests (=faster)
calcsampinterval = 1000 ; timing parameter - leave as is - will make default for release version
; here are some known RAM addresses for ROM ZA1JA00C
; addresses are likely different for other ROMs
; you can comment out ones you don't need, but keep in mind that with
; the block read nature of UDS, reading extra parameters that have
; adjacent addresses comes at very little bandwidth (=sample rate) cost
paramname = RPM
paramid = 0xFFF8DB80
isfloat = 1
paramname = accel_pedal_angle
paramid = 0xFFF8922C
isfloat = 1
paramname = throttleplate_angle
paramid = 0xFFF89030
isfloat = 1
;Colby
paramname = MAF_default
paramid = 0xFFF8DB90
isfloat = 1
;TD-d
paramname = MAF_Tdd
paramid = 0xFFF89114
isfloat = 1
paramname = load
paramid = 0xFFF8DB6C
isfloat = 1
paramname = IAT
paramid = 0xFFF8DB8C
isfloat = 1
paramname = advance
paramid = 0xFFF8DB88
isfloat = 1
paramname = KC_learned_value
paramid = 0xFFF8B0AC
isfloat = 1
paramname = fine_knock_correct
paramid = 0xFFF8B14C
isfloat = 1
paramname = feedback_knock_correction
paramid = 0xFFF8B0B0
isfloat = 1
paramname = AFR
paramid = 0xFFF8932C
isfloat = 1
scalingrpn = x,14.7,*
paramname = STFT
paramid = 0xFFF8DB74
isfloat = 1
paramname = LTFT
paramid = 0xFFF8DB78
isfloat = 1
paramname = MAP
paramid = 0xFFF8DB7C
isfloat = 1
paramname = IAM
paramid = 0xFFF816F4
isfloat = 1
paramname = speed_KMH
paramid = 0xFFF8DB84
isfloat = 1
paramname = cool_temp
paramid = 0xFFF8DB70
isfloat = 1
paramname = fuel_press
paramid = 0xFFF8DBA0
isfloat = 1
paramname = lambda
paramid = 0xFFF8DBA4
isfloat = 1
paramname = O2_volt
paramid = 0xFFF8DBA8
isfloat = 1
paramname = O2_curr
paramid = 0xFFF8DBB8
isfloat = 1
paramname = cat_temp
paramid = 0xFFF8DBBC
isfloat = 1
;paramname = ECU_volt
;paramid = 0xFFF8DBC0
;isfloat = 1
paramname = abs_load
paramid = 0xFFF8DBC4
isfloat = 1
paramname = requested_torque
paramid = 0xFFF8B490
isfloat = 1
paramname = engine_load
paramid = 0xFFF89148
isfloat = 1
paramname = ignition_total_timing
paramid = 0xFFF8ADF8
isfloat = 1
isfloat = 1
paramname = gear
paramid = 0xFFF895D9
databits = 8
; experimental parameters below this line
;E_AF_Learning_1_A_StoredExt_E44 FFF815C4
paramname = AF_Learning_1_A
paramid = 0xFFF815C4
isfloat = 1
scalingrpn = x,100,*
;E_AF_Learning_1_B_StoredExt_E45 FFF815CC
paramname = AF_Learning_1_B
paramid = 0xFFF815CC
isfloat = 1
;E_AF_Learning_1_C_StoredExt_E46 FFF815D4
paramname = AF_Learning_1_C
paramid = 0xFFF815D4
isfloat = 1
;E_AF_Learning_1_D_StoredExt_E47 FFF815DC
paramname = AF_Learning_1_D
paramid = 0xFFF815DC
isfloat = 1
;E_AF_Learning_Airflow_Range_CurrentExt_E61 FFF8A788
paramname = AF_Learning_Range_Current
paramid = 0xFFF8A788
databits = 8
;paramname = evap
;paramid = 0xFFF8DBAC
;isfloat = 1
;broken
;paramname = fuel_level
;paramid = 0xFFF8DBB0
;isfloat = 1
;broken
;paramname = amb_press
;paramid = 0xFFF8DBB4
;isfloat = 1
;-------------triggers---------------
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
Old 03-21-2014, 09:39 AM   #512
StormTrooper
I have the OFT, the reason why I am asking is because I want to use a tuner and not pay for another solution like EcuTek.
I've used RR and ecuflash with my wrx and while it wasn't too difficult I am still not comfortable self tuning nor disassembling code.
I want to go to my tuner and say, yes ecuflash /RR is ready to use to tune my car. Not, well half the parameters are missing and there is only 3-4 errors each time we flash.
GR86 MT premium
Old 03-21-2014, 10:04 AM   #513
steve99
Drives: FT86
Why won't tuner use OFT ?? with the enhanced logging now available It seems a bit confusing. Using OFT or Tacrix will still be editing with Romraider. Both flash same ROM.
I don't thing you ever going to get a guarantee from anyone on parameters unfortunately, although you could use oft to check them.
Old 03-21-2014, 11:12 AM   #514
StormTrooper
I haven't played with the advanced logging on the OFT yet.
Can you get a wideband o2 output on the OFT?
Honestly I don't think he's used oft before, most tuners outside of this and BMW don't know what it is. I went looking for someone experienced with ecuflash and RR because they worked with what I have already.
I have two options within driving distance and neither have tuned an 86 yet, one tunes almost daily the other less often but has a BRZ so should be comfortable with it soon.
GR86 MT premium
Old 03-21-2014, 11:38 AM   #515
steve99
Drives: FT86
Gather your going FI ?
Old 03-21-2014, 12:24 PM   #516
StormTrooper
No I just want to verify the stock sensor..... Keep hearing things about it being up to a full point off.
Nameless headers and downpipe (op/fp)
And probably GS intake.
I live at 4500ft so canned tunes don't work well
GR86 MT premium
Old 03-21-2014, 12:40 PM   #517
steve99
Drives: FT86
would E tune from shiv be an option
Old 03-21-2014, 01:01 PM   #518
s2d4
s2d4's Avatar
Shiv said he was getting a wideband sensor so he could make a kit, much cheaper as all it needs is a sensor and the OFT takes care of turning raw values into equivalent AFR values.
Close iJason Member's Car Journals 1 08-04-2013 09:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 03:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 10:40 AM
