#981 |
Junior
Drives: a car
I guess it just comes down to how crazy you want to get with the car.
#982 |
Junior
Drives: a car
@CSG Mike
Is there anything that's more complicated than motion ratio in terms of suspenion? Or is that as bad as it gets?
#983 | |
Because compromise ®
Drives: Red Herring
#984 |
Junior
Drives: a car
See all that seems more docile than motion ratio...although roll center is a doozy...
#985 |
Drives: Red Herring
Watch out for roll centers. Is it not the center which the car rotates about but the point at which the car rotates about at that particular point in time depending on what the car is doing. That is, the roll center can move about, off center line as well. Should be called instantaneous roll point.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Dimman (03-16-2014) |
#986 | |
- Andy |
#987 |
Kuruma Otaku
Virtual centers (roll center is one type) for geometry are a PITA. Take point A and point B, draw an imaginary line until it intersects another imaginary line off of another set of points, in 3 dimensions, and can possibly end up underground or in the middle of the car. And the initial points change as the suspension moves, so a degree of recalculation needs to be done for different suspension positions. And those virtual centers then affect how other points with virtual centers move.
Fun times.
Because titanium. |
#988 | |
Junior
Drives: a car
Good to know I need more math to accurately understand what is happening...yaaaay calculus
| The Following User Says Thank You to cdrazic93 For This Useful Post: | solidONE (03-16-2014) |
#989 |
Drives: FR-S Whiteout
#990 |
Drives: Raven Fr-S
Will the Bilstein B14 PSS work well with 215/45-17 Michelin Pilot Super Sports on 14 lb Kosei K4r 17X7 wheels?
What would be a good Sway bar setup for the above parts? Goals for car are: -DD with 4-5 track days a year max -Good ride quality for crap Detroit roads -Equal steering response to stock or better -Neutral to slight oversteer handling I am also open to other coilover options under or around 1500$. Thanks
FR-S Mod target: 200 BHp / Tonne 4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff |
#991 |
Junior
Drives: a car
I know I feel the pain too Dx
#992 | |
Junior
Drives: a car
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Racecomp Engineering (03-16-2014) |
#993 |
Drives: WRB BRZ
CSG and RCE tag-team suspension Q&A thread! Ask us anything!
I am getting a lot of mixed responses when it comes to a question I have and was wondering if you guys could help out.
I have some RCE tarmac 2 going on once the weather gets nice and will be doing some occasional autocross and possibly track days. The car is more of a weekend driver. I am looking for a decent lightweight rim for autocross and track days/occasional weekend driving. The RpF1's are great rims but I am leaning toward the TsW nurburgrings (simply aesthetics in this case) in a 18x8 w/ 35mm offset(18.6lbs).Would the 10mm difference in offset be detrimental in comparison to the 45mm. Also the 1 inch increase from 17 as well. I am also looking for tire suggestions as well if you have any. Probably looking to get some Michelin pilot super sports in 225/40/18. (Another mixed area as some people say drop in the widest tire possible and others disagree.) I appreciate your time and insight. Thanks in advance. |
#994 | |
RCE T0 would be worth considering. ![]() - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | 200hp/tonne (03-17-2014) |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 04:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 06:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 07:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 11:13 AM |
