Old 03-11-2014, 12:46 PM   #169
Dezoris
Dezoris's Avatar
Originally Posted by CajunFRS View Post
Crazy to think anyone would call that noise working as intended.
ALL GOOD HER BRO I'VE BEEN DOING DIS.
Yeah, that's what pisses me off most about this. Its normal right? Then there should be a straight answer from tuners as to mechanically why it's making this "noise."
Haven't seen one yet. Lot of good discussion on maybes though.
Old 03-11-2014, 12:47 PM   #170
Dezoris
Dezoris's Avatar
Originally Posted by regal View Post
My main hobby is computer audiophile (I've got quite the setup.). The noise couldn't be more identical except your's may be louder. My car is 100% stock and this started when the dealer flashed for the very first CEL light flash fiasco, fall 2012. Mine kicks in a little higher rpm more like 4.5k but I keep my eyes on the road so that might be off.
I haven't shifted over 3-4k since I first started hearing it (unless absolutely necessary), I figure this will all get sorted out eventually. There are quite a few posts of broken cams on here so this car is just a commuter now. Its still fun around the twisty's at 3k rpm. Don't have the time or energy to fight it.
With romraider/ecuflash coming I think the famous anti-EcuTek east coat Subaru gurus will sort tuning these cars and get these engine running right. Stock it just doesn't.
Have to remember in this case the sound was not there before the tuning.
Old 03-11-2014, 12:55 PM   #171
wparsons
wparsons's Avatar
Originally Posted by Luckrider View Post
It sounds exactly like mine. I took another video today. This time it has 3rd gear a few times as well as fourth and fifth on e85 which makes the change more audible. In addition to that, the dealership just changed the HPFP (No More Crickets!) and supposedly something with the cam. I haven't had a chance to verify the cam claim yet by reading through the paperwork though. With this video, I can now easily hear the change on my phone and ultrabook. I don't need to hook it up the to sound system or Grados to actually hear the changeover.
Edit: I just pulled up the paperwork and it looks like they just replaced some extra gaskets on top of the HPFP. They also hit the tail lights, GPS bracket/GPS Map Card and the frozen window TSB.
IMO, all you're hearing is the intake noise changing as the revs climb. I don't hear any extra resonance/rasp, or marbles in a can type noise in that video.
flickr
Old 03-11-2014, 12:58 PM   #172
wparsons
wparsons's Avatar
Originally Posted by Dezoris View Post
@regal @Element Tuning @arghx7 @wparsons @kiichiro @DJCarbine
Wanted to provide an update to this thread. I rigged up 4 mics under the hood with 24 Bit recording, even if you are bad speakers you can visually and audibly hear the valvetrain noise I am speaking about associated with the cam angle change. I also included the log view of these events.
Here are the logs to accompany the video:
UNDER HOOD VIDEO WITH PRO MICS TO CAPTURE SOUND:
I didn't notice it with speakers, but with headphones on it actually sounds like you always have the ticking noise, it just greatly increases in volume in the "bad" part of the rpm range.
flickr
Old 03-11-2014, 02:10 PM   #173
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
I don't hear anything that sounds like a problem to me. I hear a distinct change in intake noise when the cams phase. I hear injectors. I do not hear abnormal valve train (i.e. mechanical) noise.
I'm going with "normal".
Ralph Spoilsport is offline   Reply With Quote
The Following 3 Users Say Thank You to Ralph Spoilsport For This Useful Post:
arghx7 (03-11-2014), SirBrass (03-11-2014), Turdinator (03-13-2014)
Old 03-11-2014, 02:54 PM   #174
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
That is exactly why I struggle to see issue with it. It isn't a nasty metal on metal sound, it is a sexy growl letting you know the motor is really breathing now. It is a different story for those who sound like they are having mechanical issues though.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Old 03-11-2014, 03:06 PM   #175
Dezoris
Dezoris's Avatar
Still waiting for tuners to weigh in on it.
Old 03-11-2014, 03:18 PM   #176
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
nelsmar has already offered to send you 3 test ROMs when you've got the time. Run those and see what he says.
^GT5 Replay Photo Mode^
Old 03-11-2014, 03:25 PM   #177
jeebus
OMG the noise!!!! For christ's sake people, calm down. Did none of you ever own VTEC integras, or e46 M3s, or any other car that makes noise in one part of the powerband that sounds a bit raspy, growly, or tinny?
This car has a crappy torque hole that makes mid-range driving lame. The tuners have found ways to reduce the torque hole a bit, and in doing so it makes some noise. The factory engineers probably did the same but then decided too many people would bitch about the noise so they traded a few pounds of torque to quiet it down.
jeebus is offline   Reply With Quote
The Following 2 Users Say Thank You to jeebus For This Useful Post:
Rayme (03-11-2014), SirBrass (03-11-2014)
Old 03-11-2014, 03:37 PM   #178
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you link me to some of these posts? If they are on another forum, can you PM me. Thanks.
Old 03-11-2014, 03:52 PM   #179
Dezoris
Dezoris's Avatar
Owned plenty of cars, never had one tuned to sound like it needs a valve adjustment. Don't care about the torque dip, that's not what this thread is about, its about answering some simple questions:
  • What are the tuners doing that is introducing this valve train noise or what is the sound?
  • What is the mechanical reason for the sound that was not there before the tune?
  • What are the effects if any?
Definitively answer the questions and we can move on pretty simple concept.
Adding you guys for input on this thread:
@moto-mike @xjohnx @jamesm @EcuTek @DeliciousTuning @PERRIN_Mladen
Old 03-11-2014, 03:59 PM   #180
Tromatic
Since you are the one who continues to imply the tuners are guilty of shady behavior and are not satisfied with the answers they are providing, perhaps it's time for you to tell us whats going on.
The Following 3 Users Say Thank You to Tromatic For This Useful Post:
Luckrider (03-11-2014), SirBrass (03-11-2014), wparsons (03-11-2014)
Old 03-11-2014, 04:03 PM   #181
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Originally Posted by Tromatic View Post
Since you are the one who continues to accuse the tuners of shady behavior and are not satisfied with the answers they are providing, perhaps it's time for you to tell us whats going on.
I found a super easy way to get rid of the noise without changing anything in the tune...
... I added Dezoris to my ignore list.
AdrianG is offline   Reply With Quote
The Following 2 Users Say Thank You to AdrianG For This Useful Post:
Dezoris (03-11-2014), wparsons (03-11-2014)
Old 03-11-2014, 04:26 PM   #182
andrew20195
Drives: 2013 Subaru BRZ
That was a nice, high quality recording you made. Did you have any microphones on the bottom of the engine bay or just the top? Front of engine, rear of engine?
I ask because to me, from that video, it sounds similar to the change I noticed on my 2006 GTO when switching from stock exhaust to long-tube headers. It may simply be, as others have suggested, the sound of better breathing. If you could narrow it down to location on the engine (HP pump area/DI area/cam adjuster area/exhaust pipe area), it would be easier to figure out what exactly is making the noise.
The other question I have is what stroke is the Direct Injector firing on during this RPM range? If it's firing on the intake stroke, could it be possible if unburned fuel is making it's way into the hot exhaust and igniting?
andrew20195 is offline   Reply With Quote
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 07:21 PM
First tank OFT E85 tuning. Noise? Tromatic Software Tuning 2 02-20-2014 06:43 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 11:06 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 09:53 PM
