Koji_Online
Old 03-06-2014, 11:36 AM   #407
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Originally Posted by userjack6880 View Post
Does this have any other effect other than "stiffening" the clutch feel?
Feels like a real clutch now, I've had two other manual cars in my life and it feels great. No effect on clutch wear or anything else, the pedal doesn't sag either.
.ck
Sent from my HTC One using Tapatalk
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 03-06-2014, 11:35 PM   #408
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
.ck
That is what I wanted to hear. Clutch engagement point isn't my biggest complaint, and this is my first manual, so the "softness" didn't bother me much, but I ended up driving another manual car that had a "soft" clutch and realized just exactly how soft ours really was. I didn't expect sag (as the spring helps us depress the pedal, not help keep it up), but didn't know if it had any negative affect.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 03-07-2014, 02:17 PM   #409
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I'm tempted to pull that helper spring out as well, but my only fear is the fact that it seems to be irreversible should you find you prefer the super soft clutch and/or bring the car in for warranty for some transmission/clutch related issue.
I liked my sti clutch, but always thought it was a little too stiff. Would prefer the resistance somewhere between what the brz is from the factory and what the sti is from the factory. How stiff does it make the clutch?
xxBrun0xx is offline   Reply With Quote
Old 03-07-2014, 02:55 PM   #410
ck-GT86
ck-GT86's Avatar
I would think a valve spring compressor would do the trick. The clutch is stiff, not like a stage II, but traditional feel.
Ever drive a car without the drive-by-wire crap? May predate your time, but my old '91 Toyota pickup had a throttle cable, physically wired to the throttle body; the idle was controlled by a screw holding in the position of the wire. I'd have to say it was just a bit stiffer than that
.ck
|| My Build Thread ||
Old 03-07-2014, 03:52 PM   #411
xxBrun0xx
xxBrun0xx's Avatar
.ck
I guess if it was anything like my old dd...
http://cnysubies.com/forum/viewtopic.php?f=3&t=5641
I'd be happy with that. I'll give this a try when I get home! I'll take some pics as well and post up a tutorial, although I'm guessing it sounds really simple.
Old 03-07-2014, 06:59 PM   #412
userjack6880
Is the spring removal reverse-able? That is the other question.
Old 03-07-2014, 07:47 PM   #413
ck-GT86
ck-GT86's Avatar
Likely, I've never used a valve spring compressor that small, but I think it'd work. I mean, how else did Subaru do it when they assembled the car?
|| My Build Thread ||
Old 03-08-2014, 03:10 PM   #414
userjack6880
True. You'd be surprised how many parts are put on once, replace when putting something back together. Just hoping the spring isn't one of them.
Old 03-08-2014, 05:38 PM   #415
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Been dying to do this mod but I'm gonna wait until after I take my car to the dealership. My clutch has been making a squeaking noise and feels crunchy the bottom few inches before it's pressed down all the way. I'm sure if I do this mod then the dealership will give me some BS about how this mod caused the clutch issues.
Anyways, can't wait to do this! Glad everyone is having great results so far!
ericmpena is offline   Reply With Quote
Old 03-08-2014, 06:29 PM   #416
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Hi guys please read this thread - this clutch adjustment gave a few of us a loud "clicking" noise when pushing in the clutch, and again on release. Sounds like it is on the inside of the car. Toyota denies that is an issue, but there are a couple of videos showing the loud and obnoxious click that was created, in that thread.
IMO, with the consequences I saw, the adjustment definitely was not worth it. Didn't see any real improvement in clutch feel and put it back at OEM due to preference
http://www.ft86club.com/forums/showthread.php?t=57383
86-tundra is offline   Reply With Quote
Old 03-08-2014, 07:15 PM   #417
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I didn't get any such bad reaction to the adjustment. I didn't make too aggressive an adjustment, though.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 03-09-2014, 04:05 AM   #418
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
seems like i will be trying this one... on a side note any body know how to have the gear indicator on the dash activated ?
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 03-09-2014, 04:17 AM   #419
SciOnDrifTtSlIdeR
Drifter
Originally Posted by s0sl0w View Post
Did this today, HUGE improvement in the clutch.
I did modify the technique discussed however, Subaru didn't intend for you to spin the metal rod to adjust the clutch.
I took off the safety clip, squeezed the plastic safety clip on the pin and took out the pin then pulled the rod down and spun the long "u" shaped bit down, took two tries to get it at a point I liked but it was much easier that trying to spin the rod. Also the gear indicator and cruise worked without adjustment.
any pictures of the cap/ clip in question?
The Following User Says Thank You to SciOnDrifTtSlIdeR For This Useful Post:
s0sl0w (03-09-2014)
Old 03-09-2014, 07:13 AM   #420
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Basically pull the clip out of the pin and then squeeze the white cap of the pin and pull it out.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
jcw99 (01-24-2015), s0sl0w (03-09-2014)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
