Old 03-06-2014, 12:48 AM   #71
Pete156
I like to eat!
Ryan P
Pete156 is offline   Reply With Quote
Old 03-06-2014, 03:38 AM   #72
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Luckrider View Post
literally just HP = (tq x RPM)/5250
Why /5250?
Old 03-06-2014, 03:45 AM   #73
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Shit Luck View Post
Unless you count helping load cars. I got run over by a 410 sprint car when I was like 4...
OT but;
Am I the only one who thinks this would be great as your sig?
Anyway; Im curious about this from an engineering prospective, I would love to know how retarded the timing on those cams have to be for this kind of power, not to mention the piston head temp at the point of detonation.
Old 03-06-2014, 06:00 AM   #74
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by cdrazic93 View Post
Why /5250?
It's not something that's pulled out of the air, that is the definition of hp. Every dyno plot you see will have hp=tq at 5252 rpm. Torque is one of two components of horsepower, it's the intensity portion. The rate portion is rpm. In hydraulics those are pressure and flow rate. In electronics they are voltage and current. Every form of energy has those two components, with out either no work can be accomplished.
That's all torque is, a component of horsepower. Useless on its own. Think about it, given a four foot pipe you could generate 400ftlb of torque relatively easily. Could you use that to push a car past 2 mph. Nope, because it's just intensity with almost no rate.
Sent from my samstone
The Following User Says Thank You to Calum For This Useful Post:
Luckrider (03-06-2014)
Old 03-06-2014, 06:17 AM   #75
Calum
That Guy
Originally Posted by moto-mike View Post
I think you got the point
The up top HP number is not such a huge deal for reliability. The pistons speeds are much faster, and the torque number is what you have to watch. Overall 300 tq is not a big deal IMO. The fact that it holds up and carries it to redline just shows that it is tuned proper. Keeping it misfire free and holding to redline is no joke at those levels. If you look carefully at other dynos posted on this forum you'll find a serious lack of carrying it to redline past 7k.
Not to mention the graph is smoother than a lot of stock tune dyno graphs I've seen.
Old 03-06-2014, 06:58 AM   #76
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Why /5250?
Horsepower is a rate of work. It is literally define in watts and I remember when I was taking physics in highschool that is was an semi-arbitrary amount chosen as common rate of work that a horse was able to accomplish, if I remember correctly, somewhere about 734 Watts. A Watt is defined in Joules/seconds. A Joule is an amount of work and seconds are a length of time. This means a Watt is defined a work/time.
Now lets think about horsepower. HP is rated in (torque*RPM)/5250. RPMs are a speed with a defined time. In reality, 5250 is 1 minute. Thinking about the units we are applying helps show us their origin. As you can see here, we are getting work/time again. It simply becomes a multiplication factor as we are able to continue doing the same amount of work in less time (which is what revving over 5250 means). I could get into the conversions and how 5250 really came to be, but in all reality, I have neither the desire or dedication to dig up that math and try to write it out in a forum post.
Luckrider is offline   Reply With Quote
Old 03-06-2014, 07:13 AM   #77
raven1231
Congrats OP nice results best of luck with everything!
Old 03-06-2014, 03:36 PM   #78
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thank you gentlemen @Calum & @Luckrider, my physics teacher in high school was an idiot
The Following 4 Users Say Thank You to cdrazic93 For This Useful Post:
Calum (06-05-2014), Creole (04-07-2014), Luckrider (03-06-2014), Pete156 (03-06-2014)
Old 03-06-2014, 10:44 PM   #79
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It is easy to do if you continue to ramp up the PSI as RPM increases.
Old 06-05-2014, 04:15 PM   #80
R/T Tuning
R/T Tuning's Avatar
Drives: 2013 ScionRacing FRS w/2AZ-FE swap
Originally Posted by woode View Post
Sorry I'm at work and on my cell phone so I'm not sure this will show up..
hows the car holding up @woode ?
R/T Tuning is offline   Reply With Quote
The Following 3 Users Say Thank You to R/T Tuning For This Useful Post:
Calum (06-05-2014), cdrazic93 (06-05-2014), woode (06-06-2014)
Old 06-06-2014, 10:34 AM   #81
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Still going strong, almost 8k miles later!
Aside from blowing several vacuum lines off, zero issues.
Recently moved so depending on how quickly I get settled in I plan on starting to build the engine and try to start getting some track time in.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
Ryan P (06-06-2014)
Old 06-06-2014, 11:01 AM   #82
Raven604
746w...and 5252
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 06-06-2014, 11:16 AM   #83
Luckrider
Luckrider's Avatar
Originally Posted by Raven604 View Post
746w...and 5252
Oh come on, that is like .00325% of a difference on RPM and you have to give it to me for remembering back 6 years to an arbitrary rate of work being that I got within several watts.
Old 06-06-2014, 04:19 PM   #84
Raven604
Heh sorry. Ocd Electrician here
The Following 2 Users Say Thank You to Raven604 For This Useful Post:
cdrazic93 (06-06-2014), Luckrider (06-06-2014)
400HP Toyota GT86 GT4 Racer by GPRM Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 46 04-10-2015 10:31 PM
Nissan 400hp 88lb turbo 3 banger Anthony Other Vehicles & General Automotive Discussions 3 01-28-2014 12:51 AM
400hp build and other turbo questions. Ludacrits Forced Induction 22 10-26-2013 10:01 AM
400HP Firestorm Red FBM Kit FullBlown Forced Induction 166 10-16-2013 06:54 PM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 02:41 PM
