Old 03-05-2014, 02:41 AM   #1
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Taillight condensation
I've got my car garaged and only take my car for spins when the weather is nice and haven't really parked it outside for long periods. I'll probably continue driving like this for a while since I've got another beater car that is reliable.
Under what conditions does taillight condensation show up? Parked overnight? Or when you just go cruising on a chilly night?
subiestyle is offline   Reply With Quote
Old 03-05-2014, 09:41 AM   #2
RFB
RFB's Avatar
Drives: FRS
Whenever water is present (rain,washing). It runs down the back window into the trunk channels, under the tail light housing and assaults the gaskets.
The stock gaskets eventually leak. Search the threads for a permanent fix.
CERBERUS
RFB is offline   Reply With Quote
Old 03-05-2014, 10:00 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Last thing you want is getting pulled over for a shorted out tail light when you got body bags in the trunk
Old 03-05-2014, 10:48 AM   #4
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
I finally had condensation in mine after over a year of having my car. Had dealer replace it.
Rican_D is offline   Reply With Quote
Old 03-05-2014, 11:02 AM   #5
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Im on my second set of tail lights now, they are leaking again.
Im going to apply the afore mentioned fix this time around. Shit is getting old.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 03-05-2014, 11:40 AM   #6
Rican_D
Rican_D's Avatar
If I end up having same issue then I'll just go ahead and order the TOM's tails
Old 03-05-2014, 12:51 PM   #7
RFB
RFB's Avatar
Drives: FRS
ALL tail lights are affected.
Some aftermarket tails have a better sealing gasket, but eventually they leak because of the constant water erosion (as in the Grand Canyon).
The solution is to divert the water flow away from properly sealed gaskets.
CERBERUS
Old 03-05-2014, 01:01 PM   #8
Rican_D
Rican_D's Avatar
Thanks for the heads up. Thought maybe it was just a defect on the seal for the OEM tails.
CERBERUS
Old 03-05-2014, 01:15 PM   #9
subiestyle
subiestyle's Avatar
did they fix it in the 2014 models?
Old 03-05-2014, 01:15 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Mine showed up after last week's rain storm.
-alex
Old 03-05-2014, 01:19 PM   #11
mav1178
mav1178's Avatar
It sort of is... it's the factory lights being installed/overtorqued, and the plastic cracks under a constant cycle of heating/cooling from the outside elements.
The "fix" is just torquing the bolts to a lower spec with new taillights, but unless they redesigned the housing this problem may eventually come back. A more permanent fix is outlined above, but could possibly cause warranty issues if you're still under the basic warranty.
-alex
Old 03-05-2014, 01:53 PM   #12
CatDaddysBBQ
Drives: '13 FR-S
Body bags? Who are you killing that fits in the trunk of our car?
CatDaddysBBQ is offline   Reply With Quote
Old 03-05-2014, 10:04 PM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
Look at the picture in the post above mine
The Following User Says Thank You to ZionsWrath For This Useful Post:
qijian (03-05-2014)
Old 03-05-2014, 10:32 PM   #14
qijian
Drives: FRS
silicone works great and comes off easy if you need to apply it to divert water away
qijian is offline   Reply With Quote
headlight/taillight condensation Moe23 Issues | Warranty | Recalls / TSB 6 01-22-2014 03:27 PM
Taillight condensation.... again. kroarke Issues | Warranty | Recalls / TSB 1 07-03-2013 02:47 AM
Ugh - Possible taillight condensation Crackseed Hawaii 18 04-23-2013 11:38 PM
Taillight Condensation Issues... Again... Kuneff Issues | Warranty | Recalls / TSB 3 12-12-2012 05:21 PM
Anyone Else gotten taillight condensation? clevrname Scion FR-S / Toyota 86 GT86 General Forum 3 06-04-2012 12:28 PM
