| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#1499 | |
Drives: e92 335i, FRS, Lexus ls400
IG: nabb335 |
#1500 |
Drives: Toyota 86
| The Following 12 Users Say Thank You to blags For This Useful Post: | boucher (03-03-2014), HATED1 (03-03-2014), humanshield (03-06-2014), Jeeper_x (03-03-2014), Michael (03-18-2014), mrxchris (02-22-2015), SkAsphalt (03-03-2014), SnapOv3st3r (03-06-2014), westbase (03-03-2014), whitefrs (03-03-2014), WhiteLightning (03-03-2014), zenki_levin (03-05-2014) |
#1501 |
Drives: Smells like tires when I drive
For those of y'all with adjustable rear arms, other than price is there any reason for going with an adjustable lower rather than an adjustable upper rear control arm? Looking at a set of wheels that are on the verge of needing a pull in the rear and I think I can work it if I get an adjustable rear upper arm so I don't lose distance with camber.
I just hate the fact that I'll push the rear hubs out with an adjustable lower arm thus losing fender clearance and needing a bigger pull. |
#1502 | |
Drives: 2006 STi
@crazy_drew for fitment reasons, upper arms are the way to go IMO. Lower arms dont actually push the hub out like they would on mcpherson strut type suspension , extending lower arms will give you fender clearance, but requires a bit to get any good clearance. For instance, the upper arm will give you X amount of clearance at -5ish degrees of camber , while to get that same X amount of clearance with lower arms you will need say -10ish degrees of camber. (of course the camber numbers may be off but you get the point.) Also with lower arms, if you plan on dialing in any more than -5 degrees, you most likely will need adjustable toe links to correct the toe to zero. I have both uppers and lowers, along with toelinks- if you have any more trouble shoot me a PM
| The Following 2 Users Say Thank You to SLICVIC For This Useful Post: | Crazy Drew (03-04-2014), WolfsFang (03-04-2014) |
#1503 |
Drives: 2014 BRZ World Rally Blue
#1504 | |
Scrape Master
Drives: Goal: Oldest FRS State Side
#1505 | |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
#1506 |
lol, i think what you are planning is perfect. LCAS with some spacers will give your wheels a nice fit
IG: nabb335 |
#1507 | |
Love Boost!!!!!!!!
what spacers tho. I'm thinking 5 all around but idk lol
#1508 |
with that offset i think you can run 10-15mm with 5 degrees of camber. You have 45 profile tires though so i'm not too sure. 10mm would probably be safe without a fender roll
IG: nabb335 |
#1509 | |
Love Boost!!!!!!!!
Im trying to fit 265s as well lol Fenders are rolled I love boost!!!!!!
#1510 |
Lol I have no idea then man. I'm running 225s on a 10.5 but I'm not boosted or anything so I didn't have to worry about sacrifices
IG: nabb335 |
#1511 | |
Thanks Vic. I figured it was something like that. The "pushing the hub" out may not have been entirely correct however you confirmed my theory with the difference in required adjustment for the same camber angle. I daily my car 60 miles each way so I'm not looking for more than a couple degrees to get things to clear. The wheels I wanted anyways sold earlier today so no Leon Hardiritts for me... womp womp womp. Rotiform Nue's on the way. |
#1512 |
IG: nabb335 |
| The Following 3 Users Say Thank You to nab335 For This Useful Post: |
| Tags |
| dontlike?dontlookmoveon |
| Post the Wheels You want On your FRS/BRZ!! | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1738 | 10-11-2017 05:29 PM |
| RPF1 and PF01 aggressive fitment size requests | Crossover Auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-22-2012 03:30 PM |
| post VIN with any problem thread? | fistpoint | Issues | Warranty | Recalls / TSB | 0 | 10-04-2012 11:11 PM |
| Do aggressive offsets cause more debris to kick up into the paint? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-26-2012 11:03 PM |
| Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 03:20 AM |
