#15 |
Drives: 2013 Whiteout Scion FR-S 6MT
| The Following User Says Thank You to husker741 For This Useful Post: | Guff (02-25-2014) |
#16 |
Drives: A Blue One
#18 |
PROUD OF BOXER
Drives: Raven FR-S
How to fix: tap into clutch switch line. run line to relay. power the relay. run line from relay to rpm switch. power rpm witch. run rpm line to crankshaft position sensor. run line to window switch. set rpm signal to 1000rpm. when the clutch is pressed below 1000rpm, doors lock. doors will not "relock" when shifting due to rpm switch being "open".
#19 |
Drives: Asphalt FR-S
Protip: don't try to open the door while the car is in motion.
| Auto Lock (Doors) | pinoyplaya | BRZ First-Gen (2012+) — General Topics | 67 | 11-13-2017 11:47 AM |
| CG Lock Seat Belt Lock | Biggins | Interior Parts (Incl. Lighting) | 0 | 02-03-2014 09:41 AM |
| Air Conditioning, closed vent turns on automatically. | Rumbaar | Electronics | Audio | NAV | Infotainment | 5 | 09-05-2013 07:19 AM |
| Windows not automatically rolling up | mickey177 | Issues | Warranty | Recalls / TSB | 1 | 01-18-2013 12:34 PM |
