Old 02-12-2014, 04:41 PM   #155
SP86
2S Crew
SP86's Avatar
Drives: a 2013 FR-S
Works well on that color. I'm liking the canards and lip as well. Probably my next purchase. :b
My 2013 FR-S
SP86 is offline   Reply With Quote
The Following User Says Thank You to SP86 For This Useful Post:
sidnacious (02-13-2014)
Old 02-12-2014, 10:02 PM   #156
dohiedoh
dohiedoh's Avatar
Drives: 2013 scion FR-S
dohiedoh is offline   Reply With Quote
Old 02-17-2014, 02:37 AM   #157
SP86
2S Crew
SP86's Avatar
Drives: a 2013 FR-S
Better shot of mine:
My 2013 FR-S
Trashed675 (03-16-2014)
Old 02-17-2014, 05:14 PM   #158
kinryu
kinryu's Avatar
Drives: 2004 tsx aspec manual /FRS WHITEOUT
Here is mine!!
from Sema 2013 in the winjet booth
TEAM R-RYDES
1 of 1st 86 FRS
Follow my build:instagram @MIGELEO88
http://www.ft86club.com/forums/showthread.php?t=10634
kinryu is offline   Reply With Quote
The Following User Says Thank You to kinryu For This Useful Post:
RZ86 (02-17-2014)
Old 02-20-2014, 08:50 PM   #159
hotpanda1
hotpanda1's Avatar
Drives: 2013 scion FRS
hotpanda1 is offline   Reply With Quote
The Following User Says Thank You to hotpanda1 For This Useful Post:
JustBoostin (03-06-2014)
Old 02-25-2014, 06:06 AM   #160
Lemar58
Drives: Scion FR-S
Originally Posted by BMHumanic View Post
Only pic I have of mine on my PC, at the Paul Walker/Roger Rodas Memorial Meet
Dude I see you around all the time. I have the blacked out fr-s with red rails and TRD spoiler/bumper
Lemar58 is offline   Reply With Quote
Old 02-26-2014, 01:11 PM   #161
toby714
Drives: whiteout
People are wondering how the h11 hid bulbs work with the winjet. i have a retro solution 55w ballast with morimoto 5five 5k bulb. definitely some light scatter and dimmer compared the the stock headlights with hid when driving. i ordered the h7 xb35 awaiting for it to come in the mail today.
toby714 is offline   Reply With Quote
Old 02-28-2014, 12:07 PM   #162
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Are they seated correctly? I know my H11 had 3 tabs which prevented it from matching up correctly with the single tab in the H7....
ApolloSki is offline   Reply With Quote
Old 02-28-2014, 02:29 PM   #163
FR-Slide
Drives: 13 Whiteout 6MT
A bit confused; if I have an HID kit in my OEM lights, is it still simple plug-n-play with the Winjets? Or will I need to source a new HID kit as well? (not talking retrofit, just the bulb/ballast)
FR-Slide is offline   Reply With Quote
Old 02-28-2014, 03:23 PM   #164
toby714
Drives: whiteout
yea i took off the rubber seal that is on the bulb and the metal rod on the bulb was pointed down. i would advise against the h11. my h7 xb35 makes a world of a difference the cut off is more defined. i can post pics later if it stops raining.
Old 02-28-2014, 03:26 PM   #165
toby714
Drives: whiteout
plug and play. just need new bulbs. here is a more video so you get a better idea. you just need to get h7 bulbs though. i recommend the xb35 from morimoto you can boost with a 55w ballast. [ame="https://www.youtube.com/watch?v=EV4x5MH01k0"]Diode Dynamics HID install on Winjet/Spyder Headlights - YouTube[/ame]
The Following User Says Thank You to toby714 For This Useful Post:
FR-Slide (02-28-2014)
Old 03-06-2014, 08:34 AM   #166
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Winjets with Morimoto Mini D2S 3.0 , Osram 66240 CBI's
On my daughters car
Winjets upgraded to Morimoto Mini D2S 3.0 with Osram 66240 CBI's
All the credit goes to Illuminated Lightworkx for the retrofit and the advice.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 03-06-2014, 10:11 AM   #167
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Size:  44.3 KB Mine! Just need to get them adjusted the beam is to low. Besides that I love them.
Sent from my SPH-L710 using Tapatalk
C130NAV is offline   Reply With Quote
The Following User Says Thank You to C130NAV For This Useful Post:
Mad1723 (03-06-2014)
Old 03-06-2014, 11:51 AM   #168
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Does anyone know if the Morimoto retro quick projector can be installed in the winjets? I'm looking to do both.
headlikeahole is offline   Reply With Quote
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 11:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:26 PM
Winjet Headlights - Installed, Compared, and done up the FT-86 SpeedFactory Way! FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 42 03-25-2014 12:08 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 09:28 AM
Norcal GB: Winjet JDM Style Headlights 86_ZN6 Northern California 2 12-11-2013 04:31 PM
