Old 02-18-2014, 04:30 PM   #1
jdmblood
jdmblood's Avatar
Drives: white subaru brz
A/C coming out hot
The air on my brz started to come out hot. it was first on and off cold and hot and now it just comes out purely hot. im trying to avoid going to the dealer as this is my daily driver. if anyone could help me out id greatly appreciate it. also when the air is on and the car is idling, the needle wont stay put and it goes up and down around 1k rpms..idk if that helps of not but yea lmao.
jdmblood is offline   Reply With Quote
Old 02-18-2014, 04:36 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Assuming you have the temperature dial set to a much lower setting than ambient temp outside, you should take the car to a dealer to get it fixed.
-alex
jdmblood (02-18-2014)
Old 02-18-2014, 04:56 PM   #3
sshole
If it looks/sounds/smells/feels/tastes like a warranty issue, it's a warranty issue.
Unless it's not a warranty issue.
sshole is offline   Reply With Quote
Old 02-18-2014, 05:10 PM   #4
jdmblood
jdmblood's Avatar
guess i was just avoiding the inevitable
Old 02-18-2014, 06:46 PM   #5
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
There's also little shielding between the engine bay and the intake, a little weather stripping in the right place under the hood (between the bay and air intake) might at least be a partial solution. It did wonders for my SRT-4 after I got a CF hood that just blew hot air from my turbo straight to the air intake.
IIRC there's also an ECU flash to address the RPM idle dip on A/C cycling, and Chase Bays has a replacement ground cable that stops tach drops when you turn on electric seats or rear defrosters. I know most grounding kits are for the most part snake oil on modern cars, but I've heard good things about theirs. The electrical system on this one isn't the greatest if it can't turn on a defroster without dropping idle RPMs.
DoomsdayJesus is offline   Reply With Quote
Old 02-18-2014, 08:09 PM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Sounds like you need to take it to the dealer.
The Following User Says Thank You to N1rve For This Useful Post:
jdmblood (02-19-2014)
Old 02-19-2014, 12:20 AM   #7
Originally Posted by jdmblood View Post
The air on my brz started to come out hot. it was first on and off cold and hot and now it just comes out purely hot. .....
Quickly, trade it in on a FR-S!
Seriously, like stated above, I agree, it's time to pay a visit to the dealer.
It could have a refrigerant leak; could be an electrical problem (compressor clutch not engaging); could be a bad compressor; could be the controls are whacked out.
Let the dealer sort it out ....
Old 02-19-2014, 02:16 PM   #8
N1rve
N1rve's Avatar
Don't you mean 'for'? I think Mr. Humfrz need's his sleep
Old 02-19-2014, 04:23 PM   #9
...... thanks, N1rve ...... I needed that!
That does it ........ nap time it is .......
New kit coming out? Sing4LTS Forced Induction 0 08-08-2013 03:08 PM
Coming soon P&L Hawaiian Engine, Exhaust, Transmission 16 08-09-2012 11:17 AM
car coming FIRECAR Member's Car Journals 0 07-12-2012 10:28 PM
Coming soon F3dzo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-10-2012 08:27 PM
Those who coming from the TC?? csaba Scion FR-S / Toyota 86 GT86 General Forum 15 06-09-2012 01:18 AM
