Old 02-17-2014, 01:04 PM   #15
utekineir
blowhard
Drives: frs, project forester
According to utekineir, you are a dimwit because you did not figure this out in 5 minutes.
But dont go looking for that quote because he deleted it....
I didn't delete anything mods probably did and I stand by my statement that there is enough information in the linked threads to make it work.
I thought you were a 50+ year old mature grown ass man that contracts for nasa not a grudge holding child that saves and references quotes from a month back.
utekineir is offline   Reply With Quote
Old 02-17-2014, 02:56 PM   #16
stugray
Drives: 2013 GBS BRZ Limited
I was merely stating a fact. YOU are apparently the one with "issues" or the mods probably would not be censoring you. And I never said that I was 50+...
And I ws NOT "saves and references quotes from a month back".
It was on the very page of the link 3 posts above.
AND If I WAS 50+ I would probably threaten to "bend you over my knee"....
Old 02-17-2014, 03:40 PM   #17
utekineir
blowhard
Still butt hurt from a month ago, tagging and quoting. I hadn't thought about the giggles you provided a month ago since then, obviously you haven't moved on like a clingy ex.
Way to go, you're awesome at the internet.
Old 02-17-2014, 03:44 PM   #18
1086
1086's Avatar
Drives: UM86 - 6MT
^ why don't you both stfu. byeeeeeeeeee
1086 is offline   Reply With Quote
The Following User Says Thank You to 1086 For This Useful Post:
reardrv (02-18-2014)
Old 02-17-2014, 03:48 PM   #19
utekineir
blowhard
Talk to the 8 year old that brought me in with his tag and quote.
Old 02-17-2014, 04:13 PM   #20
1086
1086's Avatar
Drives: UM86 - 6MT
hahaha
Old 02-17-2014, 06:14 PM   #21
stugray
Originally Posted by FRS-AZ View Post
3. After it bombed, I closed ecuflash while the ignition is on position. And reopen ecuflash again, decided to use stock.srf instead. The flash completed successfully, there is a god. Waited and crank it over, somehow the car was flashed with stock. I send amen and call it the night. I'm chalking this as hell of experiment.
Question: What was your stock ROM?
I thought that if you pulled a ROM that you did not have a definition for, then you couldnt write it back on?
Maybe the fact that it saves the file as a *.srf means that it can be restored without a definition...
The Following User Says Thank You to stugray For This Useful Post:
steve99 (02-17-2014)
Old 02-17-2014, 06:34 PM   #22
steve99
Drives: FT86
very good question if i had a tactrix box id give it a go, would be a very usefull feature if you had a rom with no definition ie new one flashed by dealer.
maybe some of the guys with a tactrix could do some more work on the "how to flash with tactrix guide " started by @stugray and edited by @vgi
Old 02-18-2014, 02:29 PM   #23
FRS-AZ
Drives: Scion-FRS
Stugray,
Here are my stock ROM from my vehicle both *.srf and *.bin.
I have engage Mike from Tactrix on this issue with the logs files. Like I said, all the *.xml are in right path.
If you think or know I did something wrong let me know. I followed every steps that I have read from other posts.
FRS-AZ is offline   Reply With Quote
Old 02-18-2014, 03:53 PM   #24
stugray
FRS-AZ - Thanks
Your stock ROM is ZA1JA00C
There IS an ECUFlash definition file: https://github.com/TD-D/SubaruDefs/b...Z/ZA1JA00C.xml
Did you have that on the machine when you reflashed the *.srf file?
Old 02-18-2014, 04:15 PM   #25
FRS-AZ
Drives: Scion-FRS
Yes and here is the copy of the xml file from path:
openecu\ecuflash\rommetadata\subaru\BRZ\2012\
Hopefully its the correct one!!
Old 02-18-2014, 08:45 PM   #26
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The difference between the *.bin / *.hex file format and *.srf is that srf can deal with non-contiguous ROM areas, whereas *.bin / *.hex cannot. RR unfortunately cannot read srf files at this stage.
I would use Ecuflash to correct the checksum - there was a discussion on the BRZ thread over on the RR forums how the checksum is calculated (it's significantly bigger than the older roms, and required some code changes).
Td-d is offline   Reply With Quote
Old 02-20-2014, 07:29 PM   #27
stugray
Have you tried again yet?
I am curious if you have figured out what went wrong.
Old 02-21-2014, 08:15 AM   #28
FRS-AZ
Drives: Scion-FRS
No word from Mike or Tactrix yet.
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
ecu flash? jybrd Engine, Exhaust, Transmission 69 07-15-2013 04:36 PM
Why no ECU Flash? ngabdala Engine, Exhaust, Transmission 26 09-03-2012 08:27 PM
FR-S/BRZ Flash News!!! manny25 Engine, Exhaust, Transmission 88 09-02-2012 02:45 PM
ECU flash drei CANADA 8 08-10-2012 02:31 PM
