Old 02-16-2014, 05:25 PM   #1
FRS-AZ
Drives: Scion-FRS
2013 FRS flash
New too the tuning world and of course my flash error out.
ECU: ZA1JA00C and I tried to use stage 1.bin from OFT bins with ecuflash with Tactrix openport 2.0 it stop at 50% of the flash. Now the car will not crank over. I tried to reflash with factory ROM but did not complete either. Can some help!!!
Thanks
FRS-AZ is offline   Reply With Quote
Old 02-16-2014, 05:50 PM   #2
FRS-AZ
Drives: Scion-FRS
Sorry, here is log file
Forgot to attach the log file.
Old 02-16-2014, 05:53 PM   #3
steve99
Drives: FT86
Thanks
Did you get the brz beta version of the ecuflash software from romraider and the updated 32bitbase file and the correct definition files for your rom type ??
If you have got all that you may need to talk to tactrix or the romraider guys
Old 02-16-2014, 06:19 PM   #4
steve99
Drives: FT86
http://www.ft86club.com/forums/showt...=47322&page=19
have a read of a obove page, not sure if you should be using defs off github or the openflash ones whos ROM are you trying to write ??
Old 02-16-2014, 06:22 PM   #5
FRS-AZ
Drives: Scion-FRS
Try reflash again.
Steve,
I did install the beta version of ecuflash, ROM is stage 1.bin from OFT but 32bitbase not sure but I believe I did. Just now, I tried to reflash stage 1 it complete but still error. The car starts but in limp mode with check engine light on. I will attach the log file.
Old 02-16-2014, 06:25 PM   #6
FRS-AZ
Drives: Scion-FRS
Steve,
ROM was from OFT OTS v1.55.
Old 02-16-2014, 06:38 PM   #7
steve99
Drives: FT86
Steve,
I am pretty sure you need to manually copy in the 32bitbase file
https://github.com/TD-D/SubaruDefs/t...standard/Bases
Also read here
http://www.ft86club.com/forums/showp...&postcount=408
re waiting after beeps
When using EcuFLash, connect the cable, click on "read rom" (or "write"), the prompt will ask you to turn on the ignition - do turn on the ignition, wait until the bipping stops (i think 5 bips), then wait another about 6 seconds, only then click on that pop up box confirming that the iginition is "on".
Old 02-16-2014, 06:49 PM   #8
FRS-AZ
Drives: Scion-FRS
Steve,
I did verify that 32bitbase file is there under bases folder. My concern is that ecu not communicating so its going through OEM bootloader, is this normal?
Old 02-16-2014, 06:53 PM   #9
FRS-AZ
Drives: Scion-FRS
When I open the stg1 A00C.bin in ecuflash, it ask if I want to correct the checksum, should I click yes or no?
Old 02-16-2014, 06:58 PM   #10
steve99
Drives: FT86
The OFT Bins do not have checksum corrected its done by the OFT Tablet so you will need to correct the checksum with ROMRaider i am not sure ecuflash does it correctly. but you could try doing it in ecuflash.
Make sure your battery volts are good, bad flash can be caused by low battery volts maybe attach charger.
Old 02-16-2014, 07:17 PM   #11
FRS-AZ
Drives: Scion-FRS
Steve,
Battery is good but not sure on how to correct the checksum in RR. I read the post and its telling to look through the tables. Not sure on what I'm looking for and what to correct. Can you point me in right direction?
Old 02-16-2014, 07:31 PM   #12
steve99
Drives: FT86
Steve,
If you just open the rom in rom raider then save it it should correct the checksum.
On the left hand side their is a table list about half way down their is one called "checksum fix"
RR will fix the checksum on a save regardless of the setting in the "checksum fix" tables so just open it then save the ROM again
Old 02-16-2014, 08:13 PM   #13
FRS-AZ
Drives: Scion-FRS
This is what I did:
1. I took stg1 A00C.bin, opened it in RR then I saved it as stg1A00C.bin
2. I open ecuflash and open this bin stg1A00c.bin, again it ask too correct checksum, I said no. When I tried to flash it, it bombed fairly quickly.
3. After it bombed, I closed ecuflash while the ignition is on position. And reopen ecuflash again, decided to use stock.srf instead. The flash completed successfully, there is a god. Waited and crank it over, somehow the car was flashed with stock. I send amen and call it the night. I'm chalking this as hell of experiment.
Old 02-17-2014, 12:31 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
According to utekineir, you are a dimwit because you did not figure this out in 5 minutes.
Originally Posted by utekineir
It takes roughly 5 minutes to make it work and it's in this thread. Put the right definitions in the right places, correct the check sums and go.
But dont go looking for that quote because he deleted it....
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
ecu flash? jybrd Engine, Exhaust, Transmission 69 07-15-2013 04:36 PM
Why no ECU Flash? ngabdala Engine, Exhaust, Transmission 26 09-03-2012 08:27 PM
FR-S/BRZ Flash News!!! manny25 Engine, Exhaust, Transmission 88 09-02-2012 02:45 PM
ECU flash drei CANADA 8 08-10-2012 02:31 PM
