#3613 |
Drives: 2013 Firestorm FRS
You'll probably have to wake pretty early in the morning to make it happen. A Dyno tune will be a dream.
| The Following User Says Thank You to migueralliart For This Useful Post: | DAEMANO (02-13-2014) |
#3614 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
Of course, I have never driven an automatic twin. I like to launch our Grand Cherokee like this and that makes >90% peak torque from 1200-6200 rpm. |
#3615 |
Any news on the 30024V version of this ?
Any actual dynos of it? ALso I understand the 24V gets charged by the controller, what is the approximate current draw when it is engaged and what is the current CHARGE to the battery when the system is disengaged? |
#3616 | |
are you Jeff Vader?
Drives: Black BRZ Limited
#3617 | |
are you Jeff Vader?
#3618 |
Time Traveller
#3619 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
I have to say... You new guys are fricking awesome. Love the love!
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#3620 |
Time Traveller
| The Following User Says Thank You to DAEMANO For This Useful Post: | VR46 (02-14-2014) |
#3621 | |
The tq300 with accompanying mods and e85 is going to be very close to 240hp. The date this will be available is unknown.... It will be a modular swappable upgrade to the current 250kit. The dump pack charges back at 25amps if I'm not mistaken. When boost is highest I believe it is 200amps or there abouts. Sent from my HTC One using Tapatalk |
#3622 |
If this kit is using a brushless controller another thing is to consider the use of a slightly better FET. Again I'm not sure what it uses but for 200 amp currents I'm pretty sure 4-6 irf3077 in parallel and properly heatsinked will suffice per phase. Their Rdson is one of the lowest at less than 55v of operation.
Can someone give more details about the controller etc? There should be a separate board handling the charging I'm pretty sure. Pretty interested in the 30024v version. Damn you guys for bringing these near the tax refund season!!! |
#3623 | |
#3624 |
Drives: FR-S,GTI
I got my tune and was able to flash it to the car all by myself. Thanks Shiv. Now the car runs as good as it looks. It feels almost like a rotary motor. So smooth. I followed the tutorial Shiv posted in the Tuning Section and was able to upload the .dev file with no problems. If I can manage this OFT than anyone can!
Speaking of problems: I attempted to do the relay mod yesterday. Don't be a don't bee be a do bee. Don't do what I did. What I did was I cut the wire that goes to arming switch near the glove compartment because that's where my relay is powered by the power plug there. I was expecting to interrupt the green and yellow wires there. But, SURPRISE There are no yellow and green wires. So I thought I had the wrong wire. So I cut the other wire. SURPRISE, No yellow or green wire there either. Well, the way the harness is made, the colored wires are spliced to black cables and the splice is covered by the loom. So, today I'm going to cut the green and yellow wire under the hood and run cables to the glove compartment relay and back. I have yet to remember to turn off the switch. I left it on all night last night and my battery was a little weak this morning. I'll call it "conditioning the battery." In guess that the arming switch drains power from the starter battery and not the dump batteries. |
| The Following 3 Users Say Thank You to WNDSRFR For This Useful Post: |
#3625 | |
Drives: 2013 FR-S whiteout
| The Following User Says Thank You to SloS14 For This Useful Post: | DAEMANO (02-14-2014) |
#3626 | |
I've loomed my relay already but I'll try to see if I can take a couple shots for you guys. No guarantees for today though since I'm in Disneyland today.
| The Following User Says Thank You to Sojhinn For This Useful Post: | DAEMANO (02-14-2014) |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
