Old 02-11-2014, 02:42 PM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Venator View Post
I have found the JR Supercharger online and it puts "285whp" according to their dyno with stock header and exhaust.
Does anyone have one installed that can tell me if this is right or not?
The important thing to take away from that dyno plot is the 96 whp and 66 ft-lb delta between the stock dyno and the JR dyno. I can tell by the fact that the stock dyno was 186 whp that this is a very high reading dyno
Mine was dyno'd on Mustang dyno. Maybe dyno in first post is on dynojet??
It is not on a Dynojet, it is on a Dynapack which is a hub dyno.
Originally Posted by MAPerformance View Post
Keep in mind, these numbers are on a hub dyno, which can read higher than a roller type (Dynojet, Mustang, DD, etc.)
They can read higher OR lower depending.
We do. That dyno is accurate.
Don't focus on the absolute numbers. Focus on the % gain.
48.96% gain ((282.7-186.5)/186.5)
Depends on how you define accurate. I would trust those % gain numbers, yes.
Originally Posted by PrimeMotoring View Post
Low reading Mustang dyno here compared to a hub dyno.
Hard to say without knowing more about the Mustang dyno's settings. They can definitely be configured to supply Dynojet equivalent numbers. I will agree that the Dynapack does seem to be reading high only showing a 7% drivetrain loss.
sklimo (02-11-2014)
Old 02-11-2014, 02:42 PM   #16
CSG David
CSG David's Avatar
The percentage gain is more important than the actual numbers. Every dyno will output a different value based on their particular calibration.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Jackson Racing (02-21-2014), sklimo (02-11-2014)
Old 02-11-2014, 02:45 PM   #17
jamesm
those are some pretty impressive gains for a centrifugal sc on a mustang. about what my turbo puts out @ 8psi. rotrex is where it's at if that's the route you want to go.
Old 02-11-2014, 02:50 PM   #18
tendogy
Why does the FI forum have so few stickies?
OP, these should probably be stickied, and will be a good resource for you:
Forced Induction Buyer's Guide
Supercharger Comparisons
Supercharger/Turbocharger Dyno Thread
tendogy is offline   Reply With Quote
The Following 5 Users Say Thank You to tendogy For This Useful Post:
1086 (02-11-2014), CSG Mike (02-11-2014), DAEMANO (02-11-2014), Namuna (02-12-2014), SirBrass (02-11-2014)
Old 02-11-2014, 03:05 PM   #19
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
Didn't we agree that this is a dynapack? Why is everyone saying mustang?
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 02-11-2014, 03:14 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@sklimo's dyno at Prime Motoring was on a Mustang dyno and was used as a comparison since he has the JR kit as well.
sklimo (02-11-2014)
Old 02-11-2014, 03:17 PM   #21
Zach3794
Was it the same tune as well? Again, not that any of this is outside the scope of dyno to dyno differences
Old 02-11-2014, 03:21 PM   #22
sklimo
No I got custom tune
Old 02-11-2014, 03:38 PM   #23
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
any dyno can be adjusted to say whatever you want. our settings are default mustang settings and we have had a few unhappy customers with the numbers it has provided.
PrimeMotoring is offline   Reply With Quote
Old 02-11-2014, 03:40 PM   #24
PrimeMotoring
We have another customer doing a JR kit soon with stock fueling and stock exhaust with their tuning. Once finished we will be dynoing the car and can compare the difference between his and @sklimo 's car. that should clear the air. same dyno in a climate controlled room. bone stock car with JR tune vs full exhaust and our tune.
The Following 2 Users Say Thank You to PrimeMotoring For This Useful Post:
OICU812 (02-11-2014), sklimo (02-11-2014)
Old 02-11-2014, 03:41 PM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Have you considered giving them Dynojet equivalent numbers then? Find a local Dynojet and get a correction factor. That was what I was going to do when I nearly opened up my own shop based around a Mustang AWD-500 dyno.
Old 02-11-2014, 03:47 PM   #26
PrimeMotoring
two closest dynojets are about an hour south and east of us that i know of. someone would have to be willing to make the trips.
Old 02-11-2014, 04:00 PM   #27
sklimo
Maybe when we put JR oil cooler in and other shit we take a ride???
Old 02-11-2014, 04:01 PM   #28
PrimeMotoring
there might be a dyno jet up by you though. CT has a few shops with dynojets
The Following User Says Thank You to PrimeMotoring For This Useful Post:
sklimo (02-11-2014)
KDT 925 installed. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 08-14-2014 04:29 PM
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? husker741 Southeast 2 08-16-2013 04:59 PM
anyone have this lip installed? taimysho0 Cosmetic Modification (Interior/Exterior/Lighting) 2 05-31-2013 07:53 PM
Innovative SC Installed!!! Pics and dyno installed. uspspro Forced Induction 15 04-02-2013 01:09 AM
Just Installed RS-3 Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-27-2012 10:41 AM
