Old 02-11-2014, 12:04 PM   #99
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Originally Posted by Aleksander View Post
Hi, i have a quick question
I know atle and Andreas from the Norwegian forum, and it sounds very convincing with your custom tune, the thing is i live at Svalbard and we have snowy roads until may/june, can i buy the EcuTek stage2 tune now and start the tuning in the summer?
Also i was thinking of getting me a full exhaust inc a catted header before i start tuning, and if it will add even more power i'm willing to get a new intake, maybe perrin? or whatever is the most cost/performance effective
You could go with our Stage 2 tune now and we could fine-tune it this summer. My base map will run your car better than the stock tune (think off-the-shelf tune), it is still conservative but you will have gains and the car will run smoother than stock as it is an overall improvement across the entire rpm range including part-throttle and full-throttle operation.
I have only seen a very small power increase on the top end of the rpm range with a properly tuned aftermarket intake. The stock intake with a drop-in filter is quite good. I understand some have reported a slight power increase at high rpms with the stock intake by modifying the snorkel part of the stock intake (removing an airflow restriction).
Having said that, the Perrin intake is a really nice intake and tunes very well (accurate), with good, even airflow.
I've PM'd you some details.
- Bob
Circuit Motorsports is offline   Reply With Quote
Old 02-11-2014, 12:37 PM   #100
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
3rd PM Sent, still awaiting follow up.
R.S-HawK is offline   Reply With Quote
Old 02-11-2014, 12:53 PM   #101
Circuit Motorsports
Just sent you the full quote
Old 02-12-2014, 12:47 PM   #102
w00t692
Drives: 2008 Civic Si
Originally Posted by mad_sb View Post
That almost works.... except that if the dyno is calibrated to read higher the gains will also be skewed by the same percentage as the baseline.... so if the baseline is skewed by 10% the gains are also skewed by 10% etc etc
Doesn't work this way. Gains are absolute, not percentage based
The engine makes what it makes as a baseline, and it makes what it makes after tuning. There's nothing there to skew the numbers.
What you're suggesting is that the baseline and final numbers are related by a percentage, and that's simply not true.
w00t692 is offline   Reply With Quote
The Following User Says Thank You to w00t692 For This Useful Post:
Circuit Motorsports (02-13-2014)
Old 02-14-2014, 09:47 AM   #103
atledreier
Drives: GT86 DGM
Ok, consider the extreme example:
You have a dyno that reads VERY low, it reads the baseline peak whp as 100hp. After some Bob-lovin' the engine output 5% more, so the peak hp is now 105hp, 5hp gained.
So you're saying that if I take the same car on a dyno that reads high I will see the same absolute gains? So it reads 200whp stock, 5hp power gain, and the gain is now 2,5%. So I made 5hp by driving to the other shop? Or did I lose 5hp on the first dyno?
Does dyno still not matter for absolute gains?
By the way, latest low-rev wizardry by Bob is awesome! :-)
atledreier is offline   Reply With Quote
The Following 2 Users Say Thank You to atledreier For This Useful Post:
Andreas83 (02-15-2014), Circuit Motorsports (02-15-2014)
Old 02-15-2014, 12:21 AM   #104
Circuit Motorsports
I lol'ed at this
-Tristan
Old 02-15-2014, 11:56 PM   #105
Andreas83
Andreas83's Avatar
I am really looking forward to test the changes at low-revs that Bob has added to my latest revision of my tune.
Will flash my car at the heliport when I get back onshore.
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
Circuit Motorsports (02-17-2014)
Old 02-17-2014, 11:40 PM   #106
w00t692
To find out, why don't you find 2 dyno's that read 100% different first and you can answer your own question.
The simple answer is if you gained 5 horsepower on one dyno, you should gain 5 horsepower on another dyno. It's simply measuring a difference in torque at the tires.
Whether one reads your torque at 150 ft/lbs and the other reads it at 140 ft/lbs, the difference should result in a 5 horsepower gain regardless.
the amount of differences the guy was arguing about anyways are within the range of dyno error tbh... Pointless really.
Old 02-18-2014, 02:07 AM   #107
atledreier
Drives: GT86 DGM
We're arguing the principle, not the numbers.
Besides, if your two dynos read the torque at the same rpm (likely) then one would read a higher hp number than the other, that's simple mathematics. If we for simplicity say that the peak torque occur at 5252rpm, then one will read 140hp and the other will read 150hp, no matter what you call it. If one read 130 and one read 150 there's a different percentage gain on the SAME engine.
Old 02-18-2014, 02:58 PM   #108
w00t692
Yes but that's not the dyno's fault, that's the dumbest argument ever. If that's what you're saying... WHO CARES.
What one dyno shows vs another dyno, the point is to get your gains from one mod to the other. Arguing about how the dyno shows those gains is insanely stupid.
This is like arguing about who has more money, the guy with a dollar or the guy with 13 pesos.
See what i mean?
What i'm saying is, why would you bother arguing this, these numbers are from a mustang dyno anyways, there's not much way to tamper with it.
Old 02-18-2014, 04:04 PM   #109
atledreier
Drives: GT86 DGM
Of course, as long as you stay on one dyno you can argue your point.
My point is, if dude #1 has a tune and goes on a dyno and get 4hp gain. and dude #2 goes on another dyno with a different tune you might as well compare apples to coconuts. Not even the gains are comparable.
Old 02-18-2014, 11:21 PM   #110
Circuit Motorsports
To get this thread back on track here's a video of a Local BRZ we tuned and added in our custom Launch Control feature. Oh and we installed a sweet Tomei Titanium 60s too
[ame="http://www.youtube.com/watch?v=NpZo2hLhGHY"]Tomei Expreme 60S Exhaust - 2013 Subaru BRZ - YouTube[/ame]
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
Andreas83 (02-19-2014), atledreier (02-19-2014)
Old 02-19-2014, 01:53 AM   #111
atledreier
Drives: GT86 DGM
Sounds nice. Not a fan of single exits for this car, but power is power! :-)
Old 02-19-2014, 06:01 PM   #112
Aleksander
Drives: 2013 Toyta GT86
Nice sound, can't wait to get my tune with launch control and of course the exhaust, hopefully all the way from the engine
http://ft86speedfactory.com/ft-86-dr...lete-1299.html
They have a cover for both sides
But then again, it will look better with the dual exit like the stock exhaust imo.
Aleksander is offline   Reply With Quote
brz frs ecutek, brz tuning, circuit motorsports tunes, ecutek tuning, frs tuning
Circuit Motorsports schtebie User/Vendor/Sponsor Reviews, Feedback, Comments 70 03-04-2014 01:59 PM
Circuit Motorsports - EcuTek Tuned Stock BRZ: 191whp / 163wtq: +17whp & +12wtq!! Circuit Motorsports Engine, Exhaust, Bolt-Ons 16 09-24-2013 12:17 PM
Circuit Motorsports Bu-Tang User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-24-2013 07:08 PM
HKS Hi-Power Spec L Cat-Back Exhaust on Sale @ Circuit Motorsports! Circuit Motorsports Engine, Exhaust, Bolt-Ons 64 04-12-2013 01:26 PM
