Drives:
I need help with camber
Hey guys I'm completely new to camber so I'm really lost do I need just lca's or lca's and coils please help I like slammed look but I'm not willing to go that low I would like to get out of my driveway without planks I'm not going to track the car hopefully more of a show car but it is a dd
Sent from my SCH-I545 using Tapatalk |
#2 |
To go low, you will need either air suspension or coilovers.
To get your wheel/tire alignment within reason (so your car goes straight when the steering wheel is at 0), you will need camber, toe, and if possible caster adjustment as well. This is where products like an adjustable lower control arm and offset bushings come into play. If you cannot understand the difference between coilovers and LCAs, you shouldn't be futzing around with your suspension at all. Read and learn first. |
| The Following User Says Thank You to sshole For This Useful Post: | juliog (02-06-2014) |
#3 | |
Drives:
#4 |
That's an issue of if you're looking to have adjustability in the front of the vehicle (camber plates, camber bolts, full-on-race-ready-LCA) or in the rear of the vehicle (LCA, camber bushings).
#5 |
LCA's control the rear camber/toe depending on the one you get.
You do need them together with coilovers unless you do not go low. Otherwise, you will have crazy negative camber in the rear (-2.5 and higher). I had almost -3 camber in the rear after lowering with stock arms. |
#6 |
Drives: '13 BRZ Ltd
#8 | |
Drives: 2005 Toyota Camry
Camber is modified by: camber plates (upper mounts w/ front coilovers) eccentric bolts ("crash bolts") front LCA (rare but possible) rear LCA rear adjustable arms lowering the car etc You can pick your poison. But if these are still unclear to you, you need to figure out what you want to do because "I like slammed look but I'm not willing to go that low I would like to get out of my driveway without planks" is about as vague as "I want eggs for breakfast but I don't like yolk but I'm okay with sunny side up" We need context, such as: your driveway entrance (how steep it may be) what is "slammed" to you? what is your definition of "slammed" vs "not willing to go that low" etc Fill in the blanks, please, because there's so many of them. -alex |
#9 |
Drives:
Ok so to clear things up to me slammed is on the floor but I want to go as low as possible without scraping everything it would be nice to make it over a speed bump
#10 | ||
Drives:
#11 |
Drives:
Sorry for my dumb questions
#12 |
To adjust front camber you'll need crash/camber bolts or adjustable camber plates. To adjust rear camber you'll need adjustable UCA bushings, adjustable upper control arms (UCA) or adjustable lower control arms (LCA).
#13 | |
Drives:
#14 |
Why do you want rear camber? Are you needing it for clearance with your wheels? Unless you need clearance, or are adjusting camber for grip (with testing hopefully) you should stick close to stock specs.
| *FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Adjustable Camber Arms vs. Whiteline Camber Bushings | digital_assassin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 70 | 06-02-2013 06:06 AM |
